I have the ion tailgater with the slide up handle, and i just got it BRANDNEW! i ordered it online and it works fine...when its plugged in!! when i charge it, the light goea on for like 10 seconds, and then just goes off, and then when i unplugg and try it without the cord, it says low battery??? Its brandnew, i shouldnt be having battery problems!! Anybody no anything, i really like it and really dont wanna return and get my money back, i just want it fixed.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 51 Answers
Reinstall windows, or Factory reset...
Posted on Jun 06, 2013
4 Suggested Answers
silveradoman
  • 58 Answers
SOURCE: battery won't charge
sounds like the ac adapter isnt working.Test the adapter with a volt meter.The sticker on the adapter should tell the output voltage.
Posted on Mar 25, 2008
Benzschwagel
  • 33 Answers
SOURCE: HP Pavilion dv4000 battery won't charge
all you really need to do to find out if it might be broken is to check and see if that DC Jack on the computer is "wiggling" around, if the center part is moving around. If it is, then there is a chance that it is broken. I used to work at a computer store where the owner would resolder new DC power Jacks into laptops, but he was the only one in town who did that. So you might want to check around at the local computer repair or electronics stores to see if someone does that type of thing. Also, have the power supply checked out, it could just be dead.
Posted on Mar 25, 2009
  • 181 Answers
SOURCE: Battery will not charge/ keep computer on. laptop
Sounds to me like the transformer circuit that enables the batery to charge. If you have bought your machine within the last 12 months it should still be covered by warranty so go back to the supplier. If not covered I wouod still try as it is not beyond reasonable expecations that the machine will operate perfectly in very way for more than 1 year.
Posted on Feb 13, 2010
Does the AEG Compact Travel Hairdryer with ION Technology work in the USA?
It depends on the fact if it can work with 110 Volt. On the item it does have an indication if it does work and has a switch in order to work.
I had an old aeg hair-dryer from the 80s (a travel one) and it did have a switch on the handle in order to select the working voltage.
Also it came with a special adapter in order to be plugged to US type female plugs.
Sep 10, 2013 | AEG Compact Travel Hairdryer With Ion...
The door handle on my Hyundai sonata was broken off so I need some help finding a the part and replacing it
Try 1A1 autoparts online. I needed a tailgate handle for my truck. A local dealer quoted me thirty six dollars for a crappy plastic handle. I ordered one from 1A1 for six bucks plus about 4 or 5 dollars shipping.
Nov 08, 2012 | Cars & Trucks
Tail gate will not lower. Handle seems to be working fine. Can see rod running from handle to left side of tailgate but I can not see any rod running from handle to right hand side of tailgate. Is there...
yes theres 2 rods. inside the tail gate is 3 bolts hold the latch in place. they are very center of the tailgate remove these to get the handle out
Jan 22, 2011 | 2005 Chevrolet Silverado
How do you get the old tailgate latch out of the tailgate?
The latch or handle? both will need you to take the bezzel off from around the handle on the tailgate. Careful but dont feel bad if it breaks 9/10 will usually. Then there will be 2 rods coming from each latch connected with a snap over plastic clip carefully move those off the rods and now the rods can be removed. If it is the handle you are replacing then unbolt from the backside and change. If it is the latches unbolt from the sides and it will slide out of the handle opening. Steve
Jan 08, 2011 | 1997 GMC Sierra
I have an ION Tailgater which doesn't seem to be charging. The unit power doesn't have to be on whilst charging, but approximately five seconds after plugging in to charge, the charge light goes out, and...
I just bought four units, 2 of them work fine but the other two have problem, but one of the unit did get charged up even without the charger light on. I switch on the unit, leave it plug in for a few days and the unit come back charged. I try with the other one, but it is not working.
Dec 20, 2010 | ION Audio Tailgater Portable PA System...
The tailgate handle on my 2005 Freestar came out. How do I reattach the handle so that I can open my liftgate?
pop off the 2x2 cover on the gate. there is a wire towards the back. Pull it to the right. It should open. My wire snapped, so I had to push a notch so that a small metal bar with a hole can been seen if you can work thru that two inch hole stick a screw driver in it pull it to the right tailgate will open. Than take off back panel you will see a bar that slides, place handle back in a slide bar so it fits in the grove on the handle. NOW for the important part take wire and wrap around the bar so that it doesn't slide again. It should be fix. Took me about 15 minutes. I am a 54 yr old female so it's not that hard.
Aug 07, 2010 | Ford Freestar Cars & Trucks
2003 chevy s10 blazer back hatch wont open
This is how to replace it on a 1996 Blazer 4dr.
First, go buy the part you need at Rockauto. The link is for a 1996, but make sure you order it for your vehicle. Just do a search for a Window Actuator Rod Retainer. Rock Auto requires you order a pair of these, so make sure you order two. Each one has two of them in there so you will have 3 extras.
Window Actuator Rod Retainers - RockAuto.com
To open the window in the mean time while you are waiting for the part, do the following.
1. Remove the two screws on the door handle so you can pull back the door panel.
2. Pull back panel on top in the middle where it rises.
3. Reach in with a screw driver or your fingers to push down the lever. It's a metal piece on the left side against the wall to the inside of the blazer.
4. Open window and tailgate and remove screws on the sides of the tailgate. There is one on each side. Make sure it is the one fartest out and on the plastic panel.
5. Once the screws are removed, pull up on half the panel that is farthest out from the truck. Slide out away from the truck. The panel should come off with a little effort. Do not pull up on the panel closest to the truck, you will break the hooks that hold it in. I broke two on mine. The panel will slide away from the truck pretty easily.
6. Remove the screws holding the middle metal panel down. There are about 12 screws. They are the 9/32 socket screws.
7. Pull the metal panel up, first dislodge the metal poles connected to the two white clips on each side in the center of the panel.
8. You will now see your actuator with the broken blue clip.
9. Pop off the blue retainer from the actuator. This will take some effort but it will pop off. (here's where you can replace the actuator if it's not making a sound)
10. Place one end of the retainer into the loose metal piece that rotates (left arrow in third picture) and then pop the other end back on to the actuator.
11. Replace the metal panel and clip the poles back into the white clips.
12. Make sure your door handle rod is clipped into the lock before you close the tailgate. If not, you have to work at opening it again by sliding you arm down between the plastic panel and it's not easy.
13. Replace everything. Before you close the door, make sure the door handle works and make sure the actuator is connected.
14. You should now be able to use your tailgate window again!
I am taking a guess your trying to remove the tailgate panel to fix this problem???
Dec 23, 2009 | 2003 Chevrolet Blazer
2002 Ford Ranger Exterior Tailgate Handle Broken
There should be an access panel on the bed side of the tail gate. If you have a liner installed on the tail gate you will need to remove it to gain access to the panel. Panel is probably held on with torx screws but you may get lucky and have regular bolts. just remove panel and the lock rods are held to the handle with little clips, just pop them off and remove the nuts that hold the handle assembly onto the tailgate, install is just the revers order.
Jun 21, 2009 | 2002 Ford Ranger Regular Cab
2003 Ford Explorer back door latch will not open
Mine just did the exact same thing. The latch may be moving freely because it is not hooked to the latching mechanism anymore. In my case, the handle had broken where the handle hooks to the rod that operates the mechanism. Go to the Ford dealer and buy a new handle. Here in S.C. it was $24. You can't get this at the parts houses. Start by removing the plastic "Ford" cover that is over the liscense plate lights. You then have to remove the aluminum rivets that hold the handle to the tailgate from the outside and remove the broken latch. Remove the pull handle loop on the interior side of the tailgate (2 screws), unsnap the inside plastic tailgate interior panel, and pull down the black plastic sheeting that is underneath the panel to make access to the mechanism inside of the tailgate. There is also a hard plastic cover that you will see that needs to be pulled loose to open another access hole. Install the new tailgate latch handle by sliding back into the mounting holes and attach with two 10-32 screws and nuts. The new handle will come with a new yellow rod attachment piece on the handle. You will see inside of the tailgate a small rod hanging down, most likeky it will have the same rod attachment piece as the one on the new handle. Note the position of the yellow piece on the rod, as you will connect the new piece in the same place. Once the rod is hooked up, relubricate the metal mechanism with a light machine oil, replace the black plastic cover, replace the black plastic sheeting, (secure with a small amount of duct tape), replace the tailgate interior panel, replace the pull handle loop, shut tailgate, replace "Ford" cover over lights, and you're done!
Mar 23, 2009 | 2003 Ford Explorer Sport
I closed a tailgate with some coolers inside the bed that were a tad larger than the bed itself. I had to slam the tailgate shut in order to get it latched. Now I can't open the tailgate at all. The...
remove the tailgate handle trim cover, disconnect handle from side that's not working & pull on rod manually. ( thats if it's not broken already) You have probably broken rod from handel.
Aug 13, 2008 | 2006 Chevrolet Avalanche
Computers & Internet Logo
David Payne
David Payne
