Question about Bushnell Velocity Speed Gun
Bushnell Velocity Radar Gun "Stuck"
I'm getting readings at stationary objects. It worked fine for one and a half practices, but now I'm getting a reading of low 80s MPH always even when pointing at a wall. I know my kids can't get a ball that fast. I pull the trigger and immediately it's 84 MPH or similar without any movement. I removed the new batteries for a while and put them back in. I changed to KPH. I changed back to MPH. Should I return?
  • Steeler10 Jul 01, 2013
    Same problem only 117mph! when it worked if I pointed it at the groung I got no reading, now it is 117 mph no matter what I point at.
3 Suggested Answers
SOURCE: Bushnell radar gun always displays the same speed
Ever if Your radar gun don't display "low voltage" icon - change Your batteries, use only the best alkaline batteries (High Power) od NiMH rechargeable batteries. That will fix Your problem.
Posted on Apr 24, 2009
  • 10 Answers
SOURCE: The gun has new batteries, but when the trigger is
I have two of these radar guns and they both work well, you have to be at either behind the ***** or behind the catcher. Hold the gun and point directly at the target, pull the trigger and hold the gun still, after the ball is pitched and caught release the trigger. Remember this is an inexpensive gun, so it won't work if you are pointing it at the ball as it goes past you, you must be infront or behind the pitcher, but it is very accraute and well worth the money.
Posted on Oct 25, 2009
Blood pressure male age 82
Any blood pressure at the magnificent age is good :>)
An Overview of High Blood Pressure in Seniors - AgingCare.com
https://www.agingcare.com/articles/an-overview-of-high-blood-pressure-108019.htm
Jun 10, 2016 - Normal blood pressure is lower than 120/80 mmHg. Prehypertension is blood pressure between 120 and 139 for the top number, or between 80 and 89 for the bottom number. For example, blood pressure readings of 138/82, 128/89, or 130/86 are all in the prehypertension range.
New Guidelines: Treat High Blood Pressure in Over-80s - WebMD
www.webmd.com/healthy.../new-guidelines-treat-high-blood-pressure-in-over-80s Apr 25, 2011 - High Blood Pressure Treatment Extends Life in the Very Elderly ... one in three men and only one in four women over age 80 have their blood ...
Blood Pressure Chart - High - Low - Normal Readings - Disabled World
https://www.disabled-world.com/artman/publish/bloodpressurechart.shtml 35-39, 123, 82. 40-44, 125, 83. 45-49, 127, 84. 50-54, 129, 85. 55-59, 131, 86. 60+, 134, 87. Blood Pressure Chart for Children. Age, Males (mmHg), Females ...
Blood Pressure Chart by Age and Weight for Men PDF Download
Mar 29, 2017 | Health & Beauty
I have a 92 grand Marquis. It's reading 10 mph
change speed sensor on transmission.
Mar 24, 2013 | Cars & Trucks
Speedo and rev counter reading even when engine is off!
I have a similar problems on my 2005 9-3. It has developed a number of minor electical issues. including dial and false warning light triggers. I have fixed most of them by simply going round the car disconnecting the electical connectors and spraying "switch cleaner" (Maplin or Radio Shack).
The only problem I have left is the rev counter occasionally starts reading high, removing the fuse (end of dash panel - 4th fuse down) for about 30s with engine off normally resets everything back to normal.
Hope that helps.
Feb 09, 2013 | 2006 Saab 9-3
What's your problem?04 dyna low rider, riding down the street and everything went dead. the speedo read like 30 mph and tach accordingly, prob speed i was going when stalled. I pulled fuses out to
Hi Kim, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below. Good luck and have nice day.Harley Diagnostic Codes 04 to Present
Feb 08, 2013 | 2004 Harley Davidson FXDL - FXDLI Dyna Low...
Troubleshooting a/c
Checking the pressure with the system not working won't tell you anything. A system with just a half pound of freon will read outside air temp on both gauges with the compressor off.
I guess my first few questions would be - - is the compressor running at idle, what are the gauge readings at idle, and is the cooling fan running at idle ?
The two gauge readings at idle with the compressor running should be 30-45 low and 200-250 high.
Jul 15, 2012 | 2006 Audi A4
Wipers won't work when stationary at lights only
The wipers on that vehicle work with vacuum, if the vacuum is low, (which it would be sitting at an idle) then the wipers will slow or even stop,, try reving the motor just a little to see if that improves the problem, if it does, Lube the mechanical portions of the wiper assembly ,,
Aug 11, 2011 | 2006 Mercedes-Benz C-Class
Looking through the eyepiece everything is dark. The lens cap is off but I can't see anything
First the picture in your post by FIXYA-- shows a reflector style telescope that is mount BACKWARDS! Notice that the eyepiece -focuser is on the DOWN end of the tube. The scope is pointing at the ground!
So if your scope looks like the picture -- turn it around and put the focuser on the UP end of the tube. Then take the scope outside during the day time. Put the eyepiece with the LARGEST number written on it into the focuser. DO NOT USE the 2x barlow if you have one. Practice focusing on a distant object during the day time; and read my tips on my profile page. DO NOT POINT the scope at the sun!! It will instantly blind you-- just point it at an object a good distance away and practice focusing.
Also read this page so you understand the different types of telescopes.
http://texasastro.org/telescope.php
May 29, 2011 | Tasco Luminova 40114675 (675 x 114mm)...
I need manual for my bushnell refractor telescope.i can not see anything.
All of Bushnell's manuals are on this web site:
http://www.opticsplanet.net/bushnell-warranty.html
Look down the page for your telescope. The manual will NOT tell you how to use the telescope. It is only assembly instructions. Take the scope out in the day time and practice focusing on a distant object. DO NOT USE the 2x barlow if you have one. Just put the eyepiece with the LARGEST number written on it into the focuser. Turn the focus knob to the right and or left until you get a sharp image on a distant object during the day time.
Read my TIPS on my profile page.
Apr 22, 2011 | Bushnell SkyTour 78-9960 (700 x 60mm)...
Bushnell Velocity Speed Gun Logo
233 people viewed this question
Top Bushnell Baseball & Softball Experts
NOEL
NOEL
Ned Halaweh
Ned Halaweh
Andrew Taylor
Andrew Taylor
Are you a Bushnell Baseball and Softball Expert? Answer questions, earn points and help others
