Question about Philips CDR785 3-Disc CD Recorder
Cdr tray/door won't open
I can't get the cdr door to open
  • rmarchetti Nov 06, 2007
    The message on both sides reads "locked". The left side 3-disc can be pulled out, but the right burn side will not open. I can pull down the right front flap door and see tray. I have tried several times to unplug and restart and press various buttons, but the locked mesage stays on and neither tray will open.
    IHHIUHDIHIHAHDLHAOHDAOHDOAIJPJSAFJOHHSFHOSHFSOIFSJFSPFKIUDOPFUJIO[PFUIUFDWIPFJIUFO[UIJOIOPKDL[PKFDOPS]UFIUFJEFWFKOPIFOPSIDO'FE-0ITITJEHJ IIUDJOJ'S;LKF
    President:
  • 1,257 Answers
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Posted on May 02, 2008
  • 112 Answers
'Locked' is a dealer lock function to stop browesers nicking the cd's from the tray. Hold the open/close button and stop button whilst powering up to disable.
Posted on Dec 08, 2007
    Problem Solver:
  • 11 Answers
You may see a very little hole under the cdr door. insert there a slim straight not bent wire???(bad english...) and try gently to push it inside.this will push a mechanism that will open the door. :)
Posted on Aug 10, 2007
3 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: phillips cdr 785 trays wont open
Hi....
Are there small round access holes in the underside of the player (usually with a turn symbol near it)?
Most mfgs put "panic holes" under the unit to get out stuck CDs when the thing wont work right
Also,how old is the unit?
Do you use it alot??
Posted on Mar 25, 2009
Hi I have do w this and taken the cd out but put it back together and still on standby thanks Emma
Posted on Aug 28, 2013
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
Philips cdr778 play side door
remove cover and disassemble the tray carefully, and see if it can be put back together/ reset in the tracks. Hope fully nothing is broke and your back and runnin.
Nov 13, 2007 | Philips CDR778 2-Disc CD Recorder
The cd door won't open on the tower
CD Drive Tray problems
There are two ways to open the CD drive door if the button just below the drive tray does not work.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you still having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Feb 16, 2013 | ZT Group Cisnet PC Desktop
Lg in door ice maker, water won't fill in ice tray
I had that problem and water was also leaking. I tossed the ice and kept the door open for about 20 minutes when the door open alarm started to go off. It's working again. The error code on the door was 1f
Feb 01, 2013 | LG LFX25960ST Stainless Steel French Door...
Tascam CDR-W5000 CD Recorder won't open the tray (drawer). Please help!
This could be a bad belt or a defective end sense switch. The parts are no longer available I am told for this unit by New Jersey Factory Service where the could be fixed. This is one of the older models.
Dec 06, 2012 | Audio Players & Recorders
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
I have a Harman Kardon CDR2 and the cd drawers will not open. Do you know how to fix this?
hi jlcady
sounds like the belts need to be replaced. for that the units eject mechanic assy has to be disassembled.
feel free to text for further assistance.
regards
Feb 13, 2011 | Harman Kardon CDR2 2-Disc CD Recorder
Recording trouble
Hi again,
I understand. Must be a glitch somewhere. Anyways, I already posted possible solutions here your original posting/problem. They were:
1. Power on the Philips FW-R7, leave the left tray empty and closed. Open the tray and put in a recorded CD (not a CDR but a regular CD from your music collection), close the right tray. Wait a couple of seconds as the FW-R7 reads the CD. Now open the tray, remove the music CD and insert your CDR. The FW-R7 should read the CDR without the error message and record to the CDR from any source. Let me know if this works for you;
2. laser cleaning or realignment (would need a service center);
3. try using lower then 40X blank CDs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 18, 2008 | Philips FW-R7 CD Shelf System
Samsung 52x cd writer
use memorex brand cdr they are the most compatable (readable media ) to many cd& dvd writers .
the reason the cd writer dosent open often is because its usually trying to read poor quality media use good quality memorex cdr you will see a big difference in performance.
Jan 09, 2008 | Ritek (R80JS52RDCB100) 100 Pack 52x CD-R...
Harman kardon CDR 26 cd recorder
It's the belt from the spindle motor to the gear. It's worn and can't grip the spindle anymore. If you elp it to start off it works. Open the unit, remove the cd tray and it's underneath at the front. You can replace with a similar size elastic band.
Nov 14, 2007 | Harman Kardon CDR2 2-Disc CD Recorder
Philips CDR785 3-Disc CD Recorder Logo
1,209 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
