Question about Watches
Watches The back piece will not snap on firmly..can anybody help me
  • Watches Master
  • 18,394 Answers
Here is video
Posted on May 03, 2013
I can't snap the back on to the watch. How do I do that? I have the stem slot lined up with the stem, but I can't get it to snap back on. Help???
Jerry, Poping the watches back on, can be the hardest part of the job a lot of times. If Tom C. recommendation does not work, take into a jeweler and they will pop it on, they have a special type pliers or press, sometimes no charge.
Watch Repair Watch Back Being Tough To Put Back On
How to Close Watch Back Mulitple Types
Apr 30, 2016 | Michael Kors Watches
How to re-close the back plate on a Dakota time/date warch?
Some of these watches have a notch where the stem goes. If you don't have the back in place it will not snap back into place. Also some are a slight screw back and will snap off, but when putting them back you must kind of screw it back in place. Good luck.
Jan 28, 2015 | Dakota Watches
Timex fmdpu004 How do you remove back of watch
The watch you're talking about has a snap on case back. They make special tools to remove them but any sturdy, thin piece of metal should work to pry it off. The trick will be to get it to go back on. That can be very difficult and you may need a special press to get it back on. If that is the case, I'd take it to a jewler and have them doo it.
May 26, 2012 | Timex Ironman Watches
Need to replace battery in my Colibri pendant watch. Can't figure out how to open case to change it.
Thank you for contacting FixYa.
  • Place the tip of your pocket knife in the slot on the back of the watch. Pry the back off.
  • Take your tweezers and grasp the metal piece that is hiding the battery.
  • Once that metal piece is out the battery should come out too.
  • Put the new battery in and cover it with the metal piece.
  • Put the back of the watch back on and snap it into place.
  • Best wishes. Jewel
    Oct 04, 2010 | Colibri PWS-95877-N Pocket Watch
    Watch not working replaced batt. worked for an hour then stopped
    often batteries loosen over time check to make sure it is firmly in place a small piece of paper will usually help hod it in place
    Sep 14, 2010 | Watches
    My battery wend dead. the store will not open the back of the watch to change it. how do i open the back to change the battery?
    Most Skagen watches have a snap-in, snap-out back. You will need a case back opening tool ($3 to $14) or a slotted jeweler's screw driver or knife blade to pry it open. Do this over a counter or towel in case the battery pops out. Examine and make note of which side of the battery is up. Get the number off the battery, better yet take it with you to Wal-Mart, Radio Shack or anywere else they sell batteries. Buy a replacement, install it, and try to reinstall the back. Good luck!
    Do not try placing your Skagen watch face down on a soft towel, on a hard surface, and then then try to mussle in the back, or tap it with a mall or hammer. You very likely will break the crystal.
    Without a Case Closing Plier ($15 to $20) or a Case Closing Press ($15 to $50) you will not be able to get the back to snap back in. You could try a conventional vise and size some vinyl or plastic washer to to fit the bezel and protect the crystal/face of the watch, and some flat vinyl/plastic that covers the back of the watch. Align the front and back plastic pieces with the back, carefully insert it in your vice, and tighten until the back snaps in. This could be fatal if you mess up!
    A simpler solution is to take your watch to a place that specializes in selling and servicing a variety of watches, hopefull Skagens, maybe a jewelry store, and have them replace the battery. They should have the closing tool and you can expect to pay $10 to $15 for the battery and installation.
    If you like Skagens, you can go on-line and find the appropriate tools to do this. Or, pay the watch store. Many Skagens use up batteries at the rate of every 10 to 15 months. Also, you can look up Skagen on line and see if they will service your watch. They are located in Reno, Nevada
    Aug 28, 2010 | Skagen 358XSSLPD Wrist Watch
    I have a diesel watch model dz-2136 I need to know how to remove stem
    I dont know why you want to remove the stem but here you go.
    To remove the stem you must first loosen the set lever screw, then you can pull the stem out.
    You only need to turn the set lever screw a couple turns to release the stem. Some movements use a button instead and in that case you would simply push the button down lightly with a pointed tool and while holding the button down pull the stem out.
    For watches with one-piece cases where the movement comes out the dial side and the case has no removable back, you will not be able to get at the set lever screw. For this type of watch you must grasp the crown firmly and pull it out, or use plastic or soft brass tweezers to get behind the crown and pop it off. These watches have two-piece stems that have male and female ends that snap together. Then remove the bezel and let the movement come out into your hands. Then remove the hands and the dial and put the movement face down into a movement holder. Now you can remove the stem as described above
    Aug 26, 2010 | Diesel Audio Diesel Watch
    How do you open the back of a movado watch
    It could require several tools.
    If it is a screw down back you will need a case-back opener (sold at Harbor Freight for $2.99). It is adjustable to fit most case backs. Make sure the wrench fits the notches on the back and rotate counter-clockwise
    If it is a snap on case use a knife type case back opener.
    Look for a small indention on the case-back that allows you to snap the back off. (some watches have the indention, some do not)
    You need to be very careful not to scratch the back
    You may need a case-back press to put the snap case back on. Some you can snap on with your fingers other will require the press.
    Aug 01, 2010 | Watches
    How do I remove the crown/stem to take the watch movement out of the case? thanks Marc
    Apr 04, 2010 | Watches
    How do I open my gucci watch to change batteries?
    Get a #0 1.6mm precision Phillps screwdriver (these are brittle) or similarly strong, thin piece of steel.
    Hold the watch upside-down across your index finger while gripping the straps tightly between your index finger and thumb on one side, and index finger and middle finger on the other (ie. squeeze the strap around your index finger).
    On the underside of the watch, stick the tip of the screwdriver under a square slot where the watchband is connected at an angle perpendicular to the strap. Firmly pry upwards on the cover on one side, then the other, until the cover pops off.
    The battery is a Renata 379.
    To put the cover back on, align the square slots precisely with the ends of the straps (keep these out straight), then firmly push the cover straight down until it "snaps" shut.
    Dec 31, 2007 | Watches
    Watches Logo
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
