When my monitor connect to TV card (Realview XGA TV Box, it shows the dialog "Out of Range 64 KHz/60 Hz" only with black screen. But when pressing remote then all work is done such as channel change, volume and others but no screen, only dialog. When this monitor connect with laptop as duplicate monitor it works well... Please solve the problem...
SOURCE: monitor problems
Try setting your resolution lower via the control panel; it appears the resolution picked by Windows is beyond the monitor's capabilities.
SOURCE: When I open game the monitor become black and
Your resolution or screen refresh rate sounds like it is too high.
Try dropping your resolution to 1024 x 768 and see if the issue persists.
If it does then perhaps your game is trying to force you into a higher resolution output and faster screen refresh rate than your graphics card or your screen can handle.
Assuming that the graphic output is fine when your not playing this game and just using windows?
Thanks
Pete McDowell
Geek2Door Ltd
http://www.geek2door.com
SOURCE: How to a solve "
You need to set your PC video resolution to the native resolution of this monitor. Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Please read here: http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
http://en.wikipedia.org/wiki/Capacitor_plague
SOURCE: I got on the screen
Your PC video resolution is too high for this display to work. it should be set to the native resolution for best pictures: 1280 x 1024 @60Hz. Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
SOURCE: out of range 64.0 KHz / 60 HZ
It might be because of wrong screen resolution. This problem can occur because of hardware as well as software change.
To rectify this issue you will have to set your screen resolution to lowest visual settings. For this purpose you can try restarting your PC to safe mode and then modify your screen resolution.
Sometimes setting your monitor to factory defaults can also rectify this issue.
You can view http://www.techyv.com/questions/why-do-i-get-out-range-message-my-monitor for more information.
I hope this would be of some help.
