Question about Panasonic KX-P2023 Matrix Printer
Tractor feed epson lq-510 drive for windows 7
3 Suggested Answers
  • 224 Answers
SOURCE: How do you get Panasonic KX-P2023 to print 8.5
for 32 bit
Use EPSON
LQ Series 1(80)
INBOX Driver*
1 INBOX Driver is Printer Driver that is included in Windows 7.
Posted on Mar 31, 2010
cnavarro
  • 2460 Answers
SOURCE: Unable to custom select paper size of 8.5in x 7in
Ouch. You're going to have to emulate an Epson LQ-850 or Proprinter X24 so you can send the proper page length command (Esc "C" 07 or 42). I assume you have a magic USB to Parallel cable and you're going to have to do this only the first time you send the setup string to the printer.
Best I can do, since I'm not familiar how Simply Accounting sets the printer up.
Carl
Posted on Jun 20, 2011
Preprinted 4 part paper crunching up when being printed in epson lq680 printer
Mustafa:
The printer is not meant to use multi-copy carbon invoices. The cause of your problem is the double-feed prevention pad below the paper pickup roller. When the first form is fed, the double feed prevention pad will stop multiple paper feeds. With multi-page carbons, the paper feed roller is trying to feed the form, and is pulling the top page of the form into the feed rollers while the double-feed prevention pad is stopping the bottom form from feeding and the top and bottom pages are sliding because of the carbon paper between the sheets. The only solution that I know of is to buy a printer with a tractor feed and pre-printed fan-fold forms with tractor feed strips on the sides of the forms.
Oct 13, 2012 | Epson LQ 680 Matrix Printer
I wan epson lq 580 driver for window 7 32bit
try windows xp 32bit driver
manufecturer link for further information windows xp driver will support in windows 7
tech.epson.com.au/downloads/category.asp?sCategory=Dotmatrix&id=lq580&SelOS=Y
link for download
http://tech.epson.com.au/downloads/product.asp
Sep 23, 2011 | Epson LQ 580 Matrix Printer
CANNOT INSTALL THE EPSON LQ 300+DOT MATRIX PRINTER ON THE WINDOWS 7 NEW PC
Epson LQ 300 does not have Win7 latest driver. Please use your old PC (xp or visita) to continue with the Epson.
Aug 28, 2011 | Epson Dot Matrix LQ-300+II Printer
How do you get Panasonic KX-P2023 to print 8.5" x 7" tractor feed using Windows 7?
for 32 bit
Use EPSON
LQ Series 1(80)
INBOX Driver*
Mar 18, 2010 | Panasonic KX-P2023 Matrix Printer
EPSON LQ 1070+ PRINTER DON´T WORK ON WINDOWS 7
Unfortunately, no Win7 drivers exist for this printer.
You are better off running a Win98 or XP virtual machine on Win7 (like in VMWare), and installing your printer that way. There's no guarantee that would work, but it's at least one more thing to try.
Good Luck!
Jan 23, 2010 | Epson LQ 1070+ Matrix Printer
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Jun 23, 2009 | Epson LQ-2090 Matrix Printer
EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
Oct 28, 2008 | Epson LQ-2180 Dot Matrix Printer
Wrong adjustment using epson LQ-2180
Check to see if the pinch roller is set for standard sheet feeding the printer must feed by the tractor feed only.Does the paper get damaged when you try to feed or reset the page beginning, What we are looking for is a piece of one of the sheets loged in the pinch roller.Also check the pressure adjuster on the right side if you are not using multiple copie printing it should be set to medium . Let me know what you found... Be mucho blessed... Mark
Jun 27, 2008 | Epson LQ-2180 Matrix Printer
Printer Epson LQ 2090 out order
Light Pattern Beep Pattern Problem
Solution
________________________________________________________
* Paper Out light An unknown or serious
* Pause serious error has occurred
** Tear Off/Bin ..... ______________________
*** Font Light Turn off printer and leave it
*** Pitch Light off for several
seconds; then turn
on the printer again
Jun 11, 2008 | Epson LQ-2090 Matrix Printer
Epson lq 2080 printer problem
These steps apply to a Windows system.
1. Click on "Start", "Settings", "Printers".
2. Right click on the icon for your printer and left click on "Properties".
3. Click on the "Paper" tab. Here you should see a "Paper Source" option.
4. Make sure that "Tractor" is selected and not "Manual" as the paper source.
5. Once this change has been made click on "Apply" to save the change.
6. Now try printing a document.
Apr 26, 2008 | Epson LQ 2080 Matrix Printer
Panasonic KX-P2023 Matrix Printer Logo
41 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
