Question about Sunbeam Safety Glide 3891 Iron
Light comes on, but iron will not heat up
The iron is plugged in correctly. The light come on, however the stainless steel bottom remains cold no matter how long the iron plugged in to the power outlet. The power outlet is working ok, as I am using it to charge my phone, vac, etc. Please advise what can be done to correct the problem.
  • Anonymous Mar 09, 2008
    My will not heat also , same problem. I have had it less than 6 months.
  • lvalle Aug 17, 2008
    Same problem - owned iron less than 6 months - and it won't heat up even though red light is ON.
I have the same problem with my black and decker iron. I will not buy orrecommend this iron to anyone.
Posted on Aug 09, 2008
    Novelist:
  • 135 Answers
No electricity is getting to the heating coil inside the iron. It has to be disassembled to find out if the heating coils are broken, or just not connected properly.
Posted on Aug 09, 2007
2 Suggested Answers
SOURCE: Light comes on, but iron will not heat up
oliso iron turns on when plugged in green light flashes but iron will not heat up
Posted on Apr 11, 2009
Rowenta i ron stopped working
If you didn't keep it clean, it may have just burned out. Hard to say.
Dec 31, 2017 | Rowenta Irons
Brown muck coming out of the iron
Use CLR the r stands for rust It will descale the iron for lime while it is there. It would be better to own a quality iron that uses stainless steel or other non ferrous metal.
Nov 28, 2013 | Morphy Richards Jet Stream 42271 Iron
How do I use the self clean button in the DW5080 Focus 1700 Watt Steam Iron
please read carefully the owner manual and get the information about how to use the steam.
download from www. fitness.manualsonline.com
God bless you
Feb 01, 2013 | Rowenta DW5080 Focus 1700 Watt Steam Iron...
Iron won't come on or heat
Hi
The problem could be the power cord or the element.
Try replacing the power cord first and see what happens.
Feb 28, 2012 | Irons
How can I clean a burnt mark on the stainless steel iron
I have used the following for various iron cleanings. None have damaged my irons. Baking soda
Dec 16, 2011 | Rowenta Irons
Cap is stuck on Rowenta IS8100 water holder.
The stainless steel plug in the water station is stuck! I cannot unscrew it to rinse out the water station. Please HELP!
Sep 30, 2011 | Rowenta IS8100 Iron
My Rowenta iron was working fine the last time I used it. I plugged it in to use it today and nothing. The little red light on top comes on but the light on the side to let me know it is ready and hot...
Yes there is a solution, I have a DG580 with the same problem. I had to replace the electric cord which cost $17.00 and took 30 min to replace and now works like brand new.
Steve
Dec 02, 2010 | Rowenta Irons
Switch light goes on when pressed but goes off if not pressed
Switch light goes on when pressed but goes off if... OR iron does not heat at all even pressing the button to turn it on continually.
Don't understand which one question you are asking
But if there is no heat at all after switching it on, it needs to go to iron heaven but be sure to cut the plug of the end, Saftey reasons at the dump. BUT if lights are coming on the iron is working. the large dial on the water filler is temperature control. Turn this around to cotton or linen.
The light will come on and off while in use, it allows you to know that the iron has cooled and is going back to your select temperature( on the large dial)
Make sure that you use water in the iron as it will aid your ironing and make it quicker. Make sure that the iron temperature dial on the water filler is at the correct temperature for the item that you are ironing.
Hope this helps
Sep 17, 2009 | Black & Decker Steam Xpress AS250 Iron...
My Rowenta iron seems to be scortching my white clothes, the plate is stainless steel but seems to look iridescent
if its a light brown appering on the whites, its just to hot, lower setting. also make sure the plate is clean. the stainless changes colour from heat after a while, this is normal
Aug 08, 2009 | Rowenta Professional DM890 Iron with Auto...
Sunbeam Safety Glide 3891 Iron Logo
2,384 people viewed this question
Top Sunbeam Irons Experts
Wayne Fellows
Wayne Fellows
Craig Butler
Craig Butler
ray gallant
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
