Question about Samsung Stainless Steel 26 Cu. Ft. Side By Side Refrigerator Rs267tdrs
Water filter How to install a water filter
  • Samsung Master
  • 4,654 Answers
How to change the water filter is explained on page 30 in the RS267TDRS User Manual I will be here should you have questions Thanks Sea Breeze
Posted on May 03, 2013
I have a water tank behind the top drawer of my LG. Itseems to be empty I have checked the supply to the fridge and it is fine. I removed the filter and pressed the lever, water comes out. put filter
Sounds like a problem with filter. Was it having problems before installing new filter. Filter may be in backwards. I recommend reinstalling the filter
Dec 10, 2014 | Refrigerators
Jen Air Refrigerator (JCD2290HEW) developed problem with having low water flow at water dispenser and water hammer after changing water filter and depressing water dispenser to remove air. Have changed the...
I understand the correct manufacturers number for the PuriClean II water filter for your refrigerator should be UKF8001 or UKF8001AXX, that you have the correct filter, and you have plenty of water out of the dispenser when the filter is not installed. If all that information is accurate you have 30 pounds or more water pressure (although the minimum is 20 pounds the higher the pressure the better for flow will be), then I would try holding the filter under the faucet to be certain the water flows through the filter without a lot of resistance. If that checks out, I would look for a gasket or some other part from the old filter that is stuck in the filter housing.
Nov 03, 2013 | Jenn-Air Refrigerators
WHIRLPOOL W8RXEGMWQ TOP FREEZER FACTORY INSTALLED ICE MAKER, CAN I ADD A WATER FILTER OR WHERE DO I PUT WATER FILTER.
although this unit not equipt from factory with water filter,an add on can easily by installed. many different "in-line "water filter options are available, depending on installation, a filter can go either behind the refrigerator, or just passsed the initial water supply connection
Oct 27, 2013 | Whirlpool W8RXEGMW 17.5 cu. ft....
What is the main purpose of a portable water filter?
Portable water filters are used mainly by campers and hikers. They are the most effective way of cleansing fresh water to ensure purity. In essence, they remove contaminants from the water by capturing them inside the filter, thus preventing you from ingesting them.
Aug 26, 2012 | Brita Camping, Backpacking & Hiking
No water coming out of the dispenser
Hello there and welcome to fixya
Dispenser Does Not Operate
  • 1 Ensure that the water supply line is installed according to the manufacturer's directions. Turn the water supply shutoff valve counter-clockwise to fully open it.
  • 2 Replace the water filter or remove the filter and install the plug. A clogged filter will prevent the water dispenser from functioning properly.
  • 3 Place a large container under the water dispenser. Press and hold the dispenser lever for at least two minutes to remove air in the water system.
Does Not Dispense Water
  • 1 Inspect the supply line and shutoff valve for clogs. Call a plumber to remove clogs in the line or shutoff valve.
  • 2 Replace the water filter cartridge or remove the filter and install the plug.
  • 3 Ensure that the filter cartridge is installed properly. Remove it and reinstall the filter cartridge. The cartridge will lock into place when installed correctly.
Read more: Troubleshooting GE Refrigerator Water ' eHow.com http://www.ehow.com/how_7170675_troubleshooting-ge-refrigerator-water.html#ixzz1XoEkLTk8
Sep 13, 2011 | Refrigerators
Water won't flow, water line clear and has water running thru it....
Then you have to replace the water filter of the refrigerator. It is having some blockage that is why water is not flowing in it.
Filters situated in the interior liner of the refrigerator compartment of samsung-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Remove the old filter by grasping it and slowly making a one quarter turn to the left.
  2. Pull down gently on the filter to remove it from the mounting bracket assembly. Be careful to not tip the filter, as water may spill out of it.
  3. Discard used filter.
  4. Remove the new filter from its packaging. Apply the appropriate month sticker to the filter to remind yourself to change it again in six months' time.
  5. Fill the filter with water from the tap, and then line the arrow on the filter up with the arrow on the cartridge holder inside your refrigerator.
  6. The filter automatically pulls itself into position as you turn the filter to the right and lock it in place. Be careful to not over tighten the filter into position.
  7. Run water through your dispenser for about three minutes to clear the system. Keep in mind that a newly installed water filter could initially cause water to spurt from the dispenser.
Water by Culligan filter cartridges need to have a water filter adapter installed. This is a one time installment, and once you have this adapter installed, it stays in the refrigerator for all future filter replacements. If your refrigerator already has this adapter in place, do not remove it to replace the filter.
Smart Water filter cartridges do not require the use of the water filter adapter. If for some reason your refrigerator has an adapter in place already, you will have to remove it before installing a Smart Water filter cartridge. The adapter is removed in the same manner as the filter itself: with a gentle quarter turn to the left.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Hope this was helpful to you. Thank you for using fixya.
Jan 27, 2011 | Samsung 26.1 Cu. Ft. Side-by-Side...
Where is the water filter for the ice maker located on a GE tfx24zr side by side refridgerator located
Filters situated in the interior liner of the refrigerator compartment of GE-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
Jan 26, 2011 | GE Refrigerators
No ice or water, new filter was working when installed
check filter again. clean area before installing. check water. check to make shure power is on.
May 24, 2009 | GE Refrigerators
Kenmore elite water filter
just leave your filter installed
Dec 11, 2007 | Refrigerators
Samsung Stainless Steel 26 Cu. Ft. Side By Side Refrigerator Rs267tdrs Logo
87 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
