Need to know what receiver should I get with recoton home theater model wht421
2 Suggested Answers
SOURCE: i want to connect the Audio from tv to Surrounding audio system
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Posted on Dec 17, 2008
Cant get hd sound through home theatre system
Hi,here is my simple solution...
to listen your TV on your
Panasonic Home Theater System
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out "of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
Panasonic Home Theater System RECEIVER corresponding your RCA or Optic or HDMI connection
There you go..Your TV sound is on the
Panasonic Home Theater System Receiver..By this means whatever you watch on the TV (TV tuner, satellite , Xbox ..etc.) ,it's sound will come thru your stereo..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Thanks
Jun 26, 2011 | Panasonic Home Theater System System
I purchase a Panasonic Blu-Ray Home Theatre SC-BT330PCK with the intent of using it as a surround sound system for my TV and having a Blu-Ray as a bonus. Is it possible to have them work independently?
Hello there,
Yes it is possible and relatively simple to do. I suspect you have only connected an HDMI cable from the Home Theater system (HT) to the TV. This cable only sends audio and video to the TV from the HT system - it can't be used to receive the audio from the TV back to the HT.
To get audio from the TV channels through the HT speakers, you will need to connect a separate audio cable from the AUDIO OUT sockets on the TV to the HT. This can be either a Digital Optical cable (connects to socket ringed in green) or an RCA type stereo audio cable (connects to AUX sockets ringed in red).
If you are using a cable or satellite receiver, you should connect the receiver directly to the HT rather than the TV. You would also need to select the correct INPUT on the HT when you want to use the speakers for the TV channels. This will be DIGITAL 1 if using the digital optical cable or AUX if using the RCA stereo audio cable.
The audio connections are explained on page 16 of your user manual and input selection is explained on page 23. If you don't have a manual, please let me know and I can supply one.
I can draw you a diagram showing how to connect your TV to the HT and provide step-by-step instructions for setting it up, but you will need to let me know the brand and model number of your TV. If you are using a cable or satellite receiver, please let me know the brand and model number of this receiver as well.
Hope this helps.
Regards,
BElectric
Mar 22, 2011 | Panasonic SC-BT200 Home Theater Systems....
I have an RCA home theatre...model rt2910. I have hooked my PS3 via HDMI to the TV for the video and used an optical cable for the audio. I set the PS3 to send video via HDMI and audio via optical cable....
You should have the HDMI plugged into the Home theater unit. The theater unit then is attached to the TV using the HDMI out.
The home theater unit passes the HDMI through to the TV while playing the audio for you.
You will likely need to select the correct source on your RT2910.
Here is a link to the manual.
http://www.1800customersupport.com/productdocuments/RT2910_RCA.pdf
See the section entitled "Connecting to HDMI Components" for an illustration of what I have described above.
Feb 28, 2011 | RCA RT2910 Theater System
I have a rca home theatre and remote frome the rca and i want to youse the remote from the rca that i want to use for a panasonic PV-DM2792
From what I can understand, you want to use your RCA home theater remote on your Panasonic PV-DM2792. Unfortunately, you didn't say which RCA home theater system you have, so we don't know which remote you are using. We need you to tell us either the model of the remote, or the model of the RCA home theater system so that we can find out what model remote you have.
Feb 21, 2011 | Audio Players & Recorders
I have Home Theater Sony DAV- DZ151Kb. Display Push Power and then PROTECTOR. I need Help
Push power protect message appears when home theater got problem in amplifier output section and any output amplifier chip becomes bad, receiver set protection mode and refuse to power up to avoid further damage in circuit board.
It is very hard for novice to troubleshoot what output chip is defective out of six amplifier output ICs in unit, check by professional is needed to solve this issue.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Jan 14, 2011 | Sony Audio Players & Recorders
I have and lg tv and a samsung home theater
optical audio cable from home theater to tv. can be purchased on line for a few bucks.
Dec 21, 2009 | LG LHT854 Theater System
How to hook up my TV,home theater system, and digital receiver
To guide you on the exact cabling, I need to know more details like the model of the home theater and the TV model ..
However, to keep the things very simple; All you need to know is the direction of the signal. Now, we want the sound signal to travel "OUT" from the TV and travel "IN" to your Home theater home theater so that the signal gets amplified and is heard through Speakers of Home theater system so the cables run from
"Audio OUT" of TV ---------> "Audio IN" of Home Theater
All the cables are color coded.
Now Similarly.. You want the signal to travel OUT of your camera and IN to the TV so that you can see the larger image and louder sound .. so.. connect the cable that you received along with the camera into AV/TV "OUT" on camera to corresponding "INPUT" color coded ports on TV.
Please let me know if that was too complex to understand and I would try to simplify that further.
Regards,
Srinivas.
Apr 03, 2009 | Canon PowerShot A430 Digital Camera
Surround sound for my home theater.
you cannot output sound from your xbox to another dvd system , you can however send the sound to your tv and output the signal to a stereo or home theater system if your looking to have surround sound or looking for stereo sound , the tv should be set to video1-2-3 and thats where youll be able to have sound and picture , , thanks sincerely glenn
Mar 03, 2009 | Philips HTS3400/37 System
OVERLOAD Message followed by receiver shutting down.
The First step in this would be to Check the Ohms Limit in the Manual and Compair to the Ohms on the Speakers that you are running and the Ones that came with it. Usually when you By the "Kit" the Speakers are Factory Matched with the Reciever. Let me Know!
Jan 02, 2009 | Pioneer Audio Players & Recorders
21 people viewed this question
 Grubhead
Grubhead
