Question about SanDisk Sansa e250 MP3 Player
Do I have a Bent Pin In Connector (see photo)?
My PC will no longer connect to my Sansa e250. It was working fine for a year, now when i connect it nothing happens. I have tried everything. No I think I have a pent pin, but how would I know for sure? Here is a link to a photo of my connector (yes it really is a photo of my connector).
  • 80 Answers
Re: Do I have a Bent Pin In Connector (see photo)?
Call the company dont try to fix it on your own or you might breke it even more.
Posted on Aug 09, 2007
0 characters
3 Points
What does the charging cable look like? I can't find one that seems to fit my Sansa....I've had it for 3-4 years.
It has a standard USB connector at one end and a special Sansa 30-pin connector at the other end. You can order one directly from SanDisk at
Feb 03, 2011 | SanDisk Sansa e250 MP3 Player
While switching on the mp3 player... it been hanging.... refresh database error
Reset the sansa by pressing on the reset on the device , this is usually a small pin hole through which an office pin can be put in and pressed.
Now connecct your player to the PC and scan for virus, copy out all the files and format, the reinstall safe files.
The player will work fine.
Sep 01, 2010 | SanDisk Sansa e250 MP3 Player
Sansa will not detect
If you are using a USB connector [that connects extra ports to your computer] it sometimes doesnt work... so if possible hook the USB sansa cable to the main ports in the back of the server. It might also work to hook it in, and then go to 'My Computer' and see if it shows up there. Good Luck =]
Jun 05, 2009 | SanDisk Sansa e250 MP3 Player
2GB Sansa e250 won't connect to my PC
Try connecting it to different USB!!
Nov 02, 2008 | SanDisk Sansa Clip MP3 Player
Sansa e250 Connecting Writing
is there a charger (cord plugged into the base) plugged in?
Jul 29, 2008 | SanDisk Sansa e250 MP3 Player
Is the e250 Rhapsody compatible with BMW audio??
You might want to try a casette adapter, if your BMW comes equipped with a casette player - multi-adapters (generic) can generally be found for $10-15. BMW audio books appear to be in Mp3 format, so they should work with the Sansa player.
Mar 29, 2008 | SanDisk Sansa e250 MP3 Player
I have a pretty big problem with my sansa e250
Linux = problems - go to Linux forum after grabbing as much software info as you can from Sandisk's website.
Aug 18, 2007 | SanDisk Sansa e250 MP3 Player
Bent pin in USB connector
call sandisk technical support. :D if its the pin of the player not the cable call them if its the cable try purchasing a new one there are lots of electronic shops out there.
Jul 28, 2007 | SanDisk Sansa e250 MP3 Player
Deleting files from Sansa e250
The only way I know to delete music files or voice or FM recordings, is straight from the User's manual on the CD: 1. Set the e250 to MSC mode. 2. Plug it in to your computer with the USB connector. 3. Open the Sansa e250 drive in My Computer and browse to the MUSIC folder (or RECORD folder)and delete the files there. (That's where you also add music files, by dragging from other explorer windows.) To delete (or add) photo and video files, you have to use the Media Converter, which you install from the disk that came with the e250.
Feb 18, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
48 people viewed this question
Top SanDisk MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk MP3 and Digital Media Player Expert? Answer questions, earn points and help others
