Air Purifiers Logo
A
Anonymous Posted on May 03, 2013
Can t smell my oil that i put in my rainmate
When i first got my rainmate i could smell the fragrance threw my whole house now i can t even smell in one room. what is going on?
2 Related Answers
Anonymous
  • Posted on Jun 15, 2009
SOURCE: Can you use other Fragrances
I have used other oil based fragrances and have had no problems.
Anonymous
  • Posted on Nov 06, 2009
SOURCE: where do I buy the fragrance in my area for the
http://hosted.where2getit.com/rainbow/
2answers
I have a rainmate and I am tired of spending money one the oil scents. I like the spice scent. What other product can I put in my machine besides these expensive oils?
You can use vanilla extract or other extracts, your favorite perfume, other oils. Just not use anything with excessive chemicals, such as household products (pinesol, etc) Be sure and keep your unit clean, move stem that goes into water and use vinegar to remove any hard water deposits. It should last many years if taken care of. I am a Rainbow distributor.
Rainbow Rainmate Air Purifier Looking for information if the aromas/oils are safe in households with birds! Also, where can one find the MSDS documents for the oils etc.
I'm not sure if this will help or not. I never thought about the aromas/oils possibly being bad for any birds in the house. I ran mine in the small room I use as an office and I have a parakeet in this same room. She didn't have any ill effects from it. So I would suppose it would be okay. That or I have a tough old bird (which she is).
3helpful
2helpful
I was just wondering if the fragrances contain oil in them?
You simply remove the spindle and wash it out, and the spin wheel too if ot gets a build up. I use an antiseptic sort of smelling scent in mine and it helps capture dust. That is part of the build uop on the spindle. Simply turn it on the spin wheel and remove it and then wash it under hot water and let the hot water course through the spindle to clean it out.
1helpful
2answers
I just set up my new rainmate in my son's room with the eucalyptus scent (he has a cold/cough), and I needed to know how safe is it to leave the unit running overnight, and how long does it take for the...
Hey im a dealer for Rainbow. RockyNR1 is correct but let me just add that you can fill it to over the line if you want as long as the 'misting' still happens, be careful that the bowl is not near the edge of the surface as the spinning water might make it fall off the side. How long the water lasts is also very dependent on how large the room is that its in. Lastly you should be able to leave it run for 24/7
1helpful
3answers
Cloudy looking water
Does it do this when you DON'T add any of the fragrance oils???? If so, it's yuck from the air. BUT, the fragrance oils are OIL and they don't mix with water, so as it swirls it tries to emulsify the oils into the water and that causes it to become cloudy.
I would still clean it at least every other day....every day would be preferable....especially if you live somewhere that mold flourishes like I do (Central Texas)
-D
Top Rainbow Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
jamse ales
jamse ales
Are you a Rainbow Air Purifier Expert? Answer questions, earn points and help others
