Question about Rainbow Rainmate Air Purifier
Why canti cant smell the oil that i put in my rainmate
2 Suggested Answers
  • 99 Answers
SOURCE: Is the rainbow rainmate like a essential oil diffuser?
If the instructions don't say so, I would not do it. Oils can clog air purifiers that are designed for such pruposes.
Posted on Jan 17, 2015
Jan 17, 2015 | Rainbow Air Purifiers
Rainbow Rainmate Air Purifier Looking for information if the aromas/oils are safe in households with birds! Also, where can one find the MSDS documents for the oils etc.
I'm not sure if this will help or not. I never thought about the aromas/oils possibly being bad for any birds in the house. I ran mine in the small room I use as an office and I have a parakeet in this same room. She didn't have any ill effects from it. So I would suppose it would be okay. That or I have a tough old bird (which she is).
Nov 23, 2010 | Rainbow Rainmate Air Purifier
How much water should i use
I run mine day and night while home and clean and re-fill it every morning. I also use one of the room odor eliminators in my Rainmate. Fill the water one inch above the line about an inch off the bottom of the water container.
Aug 20, 2009 | Rainbow Rainmate Air Purifier
Can you use other Fragrances
I have used other oil based fragrances and have had no problems.
Jun 06, 2009 | Rainbow Rainmate Air Purifier
I was just wondering if the fragrances contain oil in them?
You simply remove the spindle and wash it out, and the spin wheel too if ot gets a build up. I use an antiseptic sort of smelling scent in mine and it helps capture dust. That is part of the build uop on the spindle. Simply turn it on the spin wheel and remove it and then wash it under hot water and let the hot water course through the spindle to clean it out.
Feb 09, 2009 | Rainbow Rainmate Air Purifier
I just set up my new rainmate in my son's room with the eucalyptus scent (he has a cold/cough), and I needed to know how safe is it to leave the unit running overnight, and how long does it take for the...
Hey im a dealer for Rainbow. RockyNR1 is correct but let me just add that you can fill it to over the line if you want as long as the 'misting' still happens, be careful that the bowl is not near the edge of the surface as the spinning water might make it fall off the side. How long the water lasts is also very dependent on how large the room is that its in. Lastly you should be able to leave it run for 24/7
Jan 27, 2009 | Rainbow Rainmate Air Purifier
Cloudy looking water
Does it do this when you DON'T add any of the fragrance oils???? If so, it's yuck from the air. BUT, the fragrance oils are OIL and they don't mix with water, so as it swirls it tries to emulsify the oils into the water and that causes it to become cloudy.
I would still clean it at least every other day....every day would be preferable....especially if you live somewhere that mold flourishes like I do (Central Texas)
-D
Oct 10, 2008 | Rainbow Rainmate Air Purifier
Got Rainmate yesterday and either my house is REALLY clean or it isn't working
i had the same problem. The goo pulled from the air gums up the small orifice atthe bottom of the stem that sticks down into the water. If the water cannot be pulled up into the stem and expelled out towards the bowl at high speed, it cannot work. Take the upper, motor half off, unplug it hold the plate with one hand and twist the stem 1/4 turn and it comes right off. Clean the crud (yes, its your own skin cells) and the hole with warm water and soap. put it back together and refill with water and it works like new. this is now monthly maintenance for me
HTH
May 16, 2008 | Rainbow Rainmate Air Purifier
Air Purifiers Logo
Top Rainbow Air Purifiers Experts
jdthefixer
Andrew Taylor
Andrew Taylor
 Russ Hill
Russ Hill
Are you a Rainbow Air Purifier Expert? Answer questions, earn points and help others
