Question about Taylor Crown C713-27 Soft Serve Ice Cream Sorbet Yogurt Machine Nice
R HPCO Compressor - Taylor Crown C713-27 Soft Serve Ice Cream Sorbet Yogurt Machine Nice
3 Suggested Answers
  • 15618 Answers
SOURCE: TAYLOR ICE CREAM MACHINE DISPLAYS HPCO COMPRESSOR.WHAT DOES IT MEAN AND HOW DO YOU REMOVE THIS CODE
HP co is a high pressure issue on the compressor. It could be a restriction in the orifice or the expansion valve. You need a valve and gage set.
Posted on Jul 16, 2017
Brad is correct, HPCO is an acronym for High Pressure Cut Out. The most common causes of this code are either an issue with the fan in air-cooled equipment, or an issue with water flow in water-cooled equipment. MOST of the time, someone has mistakenly shut off water to the unit, or moved the machine and pinched a water line with the caster wheel. A restriction at the expansion valve is a possibility but unlikely unless the refrigeration system has been opened recently, possibly to replace a compressor or other component.
If you would like to discuss your issue further with a technician, call 1-800-879-7839.
Soft Serve Parts Supplies
Posted on Jul 19, 2017
Jul 16, 2017 | Taylor Ice Cream Makers
Compressor hpco code comes up on panel of Taylor soft serve ice cream machine? Does that mean lack of water to machine?
There is a very good chance. Often the water has been shut off, or a wheel is pinching the hose.
HPCO stands for High Pressure Cut Out. The high side pressure is regulated by the water valve on water cooled equipment.
These are links to parts in the water cooling system.
046686 Water Regulating Valve 3 8
048287 Condenser for Taylor Water Cooled machines Taylor 035174 Scraper BladeReplacement 17
May 28, 2017 | Taylor Ice Cream Makers
Compressor hpco
Compressor hpco or (High Pressure Cut Out) means the high side pressure has went over the limit the machine has been set too. The safety is there to protect the compressor. If the machine is water cooled, the water flow has most likely been interrupted. So often the machine was moved for cleaning and the wheel is on the water hose. If the machine is air cooled, Either 1. the fan has stopped, 2. the condensers are dirty or 3. It's just too hot where you are trying to run the machine.
Soft Serve Parts C723
May 06, 2017 | Taylor Ice Cream Makers
If you would like to discuss your issue further with a technician, call 1-800-879-7839. http://www.softseveparts.com/
Sep 12, 2013 | Ice Cream Makers
One side freezes and the other doesn't. Also what does the small compressor do?
might have a bad compressor on one side and small compressor will run your hopper
Sep 08, 2011 | Taylor 632-27 Ice Cream Maker
Refrigerator light goes on, but compressor does not go on or the compressor fan.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | Ice Cream Makers
I hooked up my gauge run the unit and sees the high side pressure goes up, the compressor overheating and shuts off. I checked the water pressure regulator valve it good. so I unwelded the condensor coil...
It sounds like you may have unwelded the suction line to the compressor and blew the compressor out. That is not good. How a Taylor works is this: Compressor comes on and produces a lot of heat. There are 3 ways to dissipate the heat. If there is a big radiator like set of copper and aluminum finned coils near the compressor it is air cooled. If there is a water line going in and a drain line coming out, it is water cooled, the water runs the whole time the compressors are running, the third way is to have an outside remote condenser coil. I believe you have a water cooled machine. On the back of the machine is a copper fitting to hook up the incoming water lline. There is also a drain line and water will flow constantly from it if everything is running alright. It is ok for the compressor to get hot when running, it is supposed to get hot. If you broke into the freon lines by mistake, the freon is gone and it won't show pressure anymore. I don't see any way that oil would have gotten into the water cooling line. To verify which is the cooling water, the copper lines will go into the back of the machine and will be wrapped around the outside of the compressor and then back to the drain at the back of the machine. If you blew the oil out of the compressor it will very soon lock up and be destroyed. Look at the line that you cut into.
Oct 20, 2010 | Taylor 632-27 Ice Cream Maker
What brand compressor do saniserv use
Depends on the unit, goto to www.saniserve.com ,they can tell you the exact compressor by the model and serial numbers.
Feb 26, 2008 | SaniServ 401 20 Quart Ice Cream Maker
Taylor Crown C713-27 Soft Serve Ice Cream Sorbet Yogurt Machine Nice Logo
389 people viewed this question
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
