Question about Garden
I have a Husqvarna YTH18542. When I engage the blade the lawn mower loses power and acts as if it is going to die. It is fine when not engaged.
GM Elec
  • 1000 Answers
SOURCE: Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
Posted on May 10, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 9 Answers
SOURCE: 2007 Husqvarna Riding mower blade will not engage
Sounds like you electric blade clutch is bad. I just had the same thing happen to my exmark mower. I was cutting grass and the engine just shut down. It would not crank over. Checked the fuses and replaced one blown fuse. The engine wanted to crank over but it was locked up. I looked the engine over and seen that the bearing in the electric clutch seized up causing the clutch to melt.
Posted on Apr 25, 2010
Testimonial: "Thank you! That doesn't sound like an inexpensive solution. We appreciate your help, though."
SOURCE: I have a 15.5 HP Sears Craftsman 42
I'm betting that you need a new safety kill switch - probably the one underneath the seat (the spring-loaded plunger switch that won't let you use the machine without your *** in the seat). Could also be the one behind the "dash" that is associated with the blade engagement mechanism.
I know that the under-seat-switch cannot be bypassed or it will disable the machine in the exact way that you described. Why do I say this? Because I just tried to bypass my own "***-in-the-seat-safety-switch" on my very own 15.5 HP, 42" Sears tractor, and it responded by punishing me - the absense of the switch caused the motor to cut out when I tried to put the machine in gear AND/OR engage the blade. It seems to have some measured capacitance - the absense of same seeming to interrupt the ignition timing enough to shut the motor down when you attempt to get anywhere past neutral or engage the blade. These "safety" switches may be needed by a very few who prefer to be drunk while they mow lawns on steep slopes that their tractor mowers were not designed for, but I find these items to be troublesome and enfuriating. My trees shed a lot of sticks in high winds, and I can't stand shutting the machine down and restarting it EVERY SINGLE TIME I have to dismount to clear sticks or other obstructions out of my mowing path. This is an obnoxious, "nanny-design" feature that desparately needs to be discontinued. It also makes both jump-starting the tractor and electrical troubleshooting much more difficult than they should be. The tractor should let you dismount without shutting down, as long as you have disengaged the blade and shifted into neutral. It should also let you jump start with jumper cables - impossible to do with your rear end in the seat. By the way, call Manufacturer's Supply, Inc. at 1-800-826-8563. They may have a replacement - their item number 31-9664 might do it, but talk to them first. I'm calling them tomorrow. Good luck.
Posted on May 17, 2010
Testimonial: "VERY THOROUGH - THANKS"
SOURCE: Blades will not engage on Husqvarna riding mower.
I have a Husqvarna GTH2548 and the blades will not engage. It is free from all debrie
Posted on Sep 04, 2010
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
BY pass red blade engage of quick check for a 2013
Are you sitting in the seat? Usually you can't engage blades if you're not in the seat.
Jul 28, 2014 | Husqvarna 46" Zero Turn Lawn Mower...
Husqvarna riding mower smokes when cranked and dies when engaging blades
If it dies when engaging the blades it's not getting enough juice to do so. Test the battery and make sure you are getting at least 12 volts. If not, charge it. If so, the solonid is going bad.
Apr 13, 2017 | Husqvarna Garden
Ihave a yth2448 husqvarna lawn motor. mower stall out as soon as i engage it. i have noticethe battery is discharging even when mower is not engage. any suggestion. i justv replaced the starter and...
check the belt as it bound, if you do not think so then take it off(the belt) and engage the PTO if it does not die then it is: the belt, pulley, or blades are/is the reason why it is stalling Tim
May 29, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a yth18542 riding mower and the blade do not engage. no objects in deck and belt is fine. any solutions?
Make sure the "engagement pulley" assy. is moving when the blades are engaged. This can sometimes "freeze" and not move to tighten the belt. You may also make sure the cable is intact as well. These have also been known to brake inside the housing and even though the lever moves, the cable does not pull. These are just a few of the common issues you may want to check. Hope it gets you in the right direction.
Mar 01, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My LGT 2554 Husgvarna mower engine tends to die when the mower blades are engaged. When the engine runs with the blades off at low idle it is ok. When you advance the throttle fast to full it loses power...
A common problem on the 21 & 23HP models is bent valve push rods on one cylinder. With this the engine runs and seems fine, albeit a bit quieter, until you put a load on it like engaging the blades which causes it to nearly die. So you may want to eliminate this as a possibility by running the engine with one plug wire removed and then the other. If it runs with one wire on alone, but not with the other wire on alone, then you have a nonworking cylinder even though it is receiving spark. Just a thought.
Jul 30, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Could be a broken belt, loose belt (stretched) or something is under the mower deck jamming the blades. (stick for an example)
Apr 14, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
