Question about Hitachi CS33EB16 16" Rear Handle Chain Saw
How can I adjust oil flow on hitachi chainsaw
Husqvarna chainsaw oil leaks
I have 4 husky\'s and they leak a little. On the bottom of the saw there is a oil flow adjuster screw turn it down a little also check oil cap gasquet.
Sep 21, 2014 | Husqvarna , No.455 Rancher, 20" Gas -...
On the poulan 42cc chainsw how do i adjust the flow of bar oil
To adjust the automatic oil flow, Turn the chainsaw upside down. Turn the screw marked with a "+" or "-" toward the "+" sign. If too much oil is present turn the screw toward the "-" sign. Repeat the oil test and adjust as necessary.
Read more : http://www.ehow.com/how_7767305_adjust-bar-chain-oil-flow.html
Jul 01, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
No oil getting to my new stihl 251
On the underside of the saw is the oil flow adjusting screw should have icons to show min/max oil flow adjust as required.
Jun 28, 2014 | Stihl Garden
How do I adjust the amount of oil that goes on the blade. It seems to dump a lot of oil on the blade and blade guide. Goes everyplace
Sorry but this model is not equipped with an oil flow adjustment screw.
The clutch cover area must be saturated with lubricant to properly lubricate the bar and chain and
to ensure the long-term durability of your chain saw.
One thing you could try is to purchase a slightly thicker oil. I got some once at a auto part store and it had anti-sling ingredients.
Mar 29, 2014 | Poulan PRO Chainsaw. PP5020 20 in. 50 cc...
HOW TO CONTROL THE OIL FLOW AND ADJUST THE CHAIN FOR AN ELECTRIC CHAIN SAW
The oil flow is not adjustable
Check the bar to see if it has something that looks like a flat head screw that you can turn, it is possible that it is equipped with an EZ adjust bar where you can make tension adjustments without loosening the cover. If not, loosen the bar nuts and use the tension screw on the back of the cover to make your adjustments.
Aug 31, 2011 | Poulan 14" Chainsaw
On the poulan 3300 chainsaw how do I adjust the flow of bar oil?
The adjuster screw is on the r/h side of the machine, turn the machine on its side ( starter side down ) now at the bottom l/h side of the drive sprocket you should see a screw, undoing it will increase the oil flow.
Apr 09, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Can i alter oil flow to chaimac 436
Most hobby saws do not have an adjustable pump, if it is adjustable there will be an external screw close the the clutch and sprocket, would would not need to remove the bar and chain to acsess it.
Feb 12, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have a Poulan 20" chain saw that keeps leaking out the bar oil every time I put it in the container and store it. What causes this and can it be fixed by myself?
Most chainsaws have an adjustment for bar oiling and its quite normal for a chainsaw that is stored for long periods of time (weeks or even days) to leak out the bar oil. This is normal for chainsaws stored for several weeks or more.
Some of it may be reduced by adjusting the rate of flow for the bar oiler, read your manual carefully before attempting to adjust it. Adjust to too slow a flow rate will have adverse effects on performance and can lead to premature chain or bar failure.
Recommend that if you are going to store your chainsaw for more than a couple of weeks, drain the bar oil back out if it into a container (strain it through a paper towel before returning to your bar oil can). Also, you really should drain almost all the fuel and then run it until it shuts off if you are storing it for a month or more.
Aug 05, 2009 | Poulan Pro Chain Saw 46cc 20"
Hitachi CS33EB16 16" Rear Handle Chain Saw Logo
78 people viewed this question
Top Hitachi Garden Experts
Phil Walker
Phil Walker
Are you a Hitachi Garden Expert? Answer questions, earn points and help others
