Flickering 32" Westinghouse led tv
It keeps flickering and showing lines. seems like the lines are getting worst with time. tv version number tw-63001-u032d. serial number 6300y11400334. model number ls-3260. input 19.0v
    Top Expert:
  • Televison & ... Master
  • 75,178 Answers
Cross-talk with polorizer and glass inside panel might be the cause. If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. More than Nine and half Lakh viewers cannot be wrong.
Posted on May 17, 2013
salt56
  • 373 Answers
SOURCE: White horizontal flickering lines
If still under warranty, take it back. but first check your cable input connections or cable signal may have went bad. Lastly it could be the signal module inside.
Posted on Jan 02, 2008
techman
  • 3130 Answers
SOURCE: vertical flickering color lines instead of pictures
Soory man there is no deflection yoke or vertical output IC in a plasma TV set.LOL This person has a problem with whats called the substain power supply or bad caoacitors in the main supply. there is also a possibility that the set has a bad tuner. Only performing test on the set will determine the problem.
Posted on Mar 23, 2007
  • 103 Answers
SOURCE: Sharp Aquos LC-32D41U
The unit has bad drive ic's,which is part of the lcd panel.It is not cheap to fix.
Posted on Mar 05, 2008
  • 8 Answers
SOURCE: Westinghouse 32" LCD TV
It seems your pixelsare burning out. contact the NY Service Center for Westinghouse. web is www.asnyonine.com
Posted on Jun 30, 2008
budmrtn
  • 11361 Answers
SOURCE: Flickering problem with Tv.
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
PARTS: http://www.shopjimmy.com/catalogsearch/result/?q=vizio+l32
Please post back what you find.
Posted on Dec 17, 2009
LED TV pulsing
How many have 'blinking' issue with Samsung led tv - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJan 26, 2011 - I am trying to get the number of people affected by this nagging blinkingissue with the latest Samsung led tv's. If possible it would be useful to ... Samsung LCD TV Screen flickering (LN55C630K1F)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung LED with flashing standby light on front
Apr 17, 2014
More results from www.cnet.com
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical ...
Jan 18, 2016 | LG Televison & Video
Need fix how do i make it stop flickering
Coby lcd tv keeps flickering Flat Panel Televisions ... - Fixya
www.fixya.com > ... > lcd tv keeps flickering > Flat Panel Televisions
Coby flat panel televisions lcd tv keeps flickering related questions and answers. Ask your Coby ... Why does my Coby 40 TFTV4028 LCD TV keeps flickering.
Coby adjust air fuel mixture Flat Panel Televisions ... - Fixya
www.fixya.com > ... > adjust air fuel mixture > Flat Panel Televisions
Coby flat panel televisions adjust air fuel mixture related questions and answers. Ask your Coby ... Coby 32 in tv ... to last channel, and will stop, and will display the first channel it has got. Then we have to make adjustments on channels. ... Ad. Question about 40 TFTV4028 LCD TV. 1 Answer ... Flickering can be adjusted.
Won't turn. on red standby light changes to on but then
Jan 04, 2016 | Coby 40 TFTV4028 LCD TV
Luxor 40 914 tvb
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | Televison & Video
No power Westinghouse LD4655BX
- Flickering screen
- Dim screen
- Slow start
Apr 04, 2014 | Westinghouse Televison & Video
Vertical lines showing up after being on for awhile
Eh, I can't be too sure, but it sounds like it's either a heat issue, a signal issue, or a backlight issue. Either way, if it's still under warranty I'd send it in.
May 06, 2013 | Sharp LC60LE835U AQUOS Quattron 60" 3D...
I have a 52" westinghouse
Ok you have a lot of things going on here. Your first thing with the lines can be your T-con board or your Signal board or the screen itself. The second thing black screen you would have to be more specific? Is your back light on and you have no image? If that's teh case then I would replace the T-con board or the Signal board. If by black screen you mean there is no light on the screen from the backlight inverter then your BAcklight inverter or the backlight itleft might be bad. and ontop of that you might have the problem that we started with also. You can get westinghouse parts from www.interliquidparts.com You have to order by part numbers so you have to get the number from the actual part of your TV.
Jun 13, 2011 | Televison & Video
I just purchased a vizio 32' LED RAZOR The picture flickers.. I have had my dish network technician out to check and everything is fine...he says it is the tv... it is very irritating...what is...
first try too use a dvd player in the same input. that will tell u if it is your tv or not. if not then thier are some things too change on the dishnetwork as a tech for dish now i'd change out the lnbf (the eyes on the dish) then the cable connected between the tv and the dish reciever but the flickering is called pixlating. if it keeps flickering then it is your tv.
Nov 18, 2010 | Vizio L32 32 in. LCD HDTV
Jun 24, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Picture Flickers Briefly Shortly After Power on
If the set is only a few weeks old you should put a claim for a warranty repair or exchange I believe is the back light(lamp)doing the flickering and should not be doing that at all and it will not go away by itself,it might get worst. Let Us know how it goes or if you need more information.
Nov 03, 2006 | Hyundai Q320 32 in. LCD Television
Flickering Picture?
Your set might have a high voltage leak and that is the noise you hear when is showing the screen problem or even maybe an arking too ,either one is related to the high voltage and it can be dangerous,if you are familiar with tv service you can try to see where is arking and replace the part with an exact replacement but if the set has a leak you will not see it and is not safe to be close to it,if you are not too familiar be safe and call for assistance from a servicer.
Oct 27, 2006 | RCA F35731MB 35" TV
Televison & Video Logo
250 people viewed this question
Top Televison & Video Experts
