Can UBHC 17J11NFD air handler be installed horizontal?
  • 20 Answers
SOURCE: Wiring Diagram
here is a basic wiring diagram for all air cond systems your thermostat consist of treminal r w y and c run a four conductor wire fromm thermostat to ai handler the air handler should allso have eather have red blue white wires or a teminal block marked r w c r stands for red w for white c for comon allso blue run color for color from the thermostat to ai handler with exeption of yellow yellow runs straigth to condenserand retuns in white wire to air handler wich gets conected to comon hope this help[s you
Posted on Jul 23, 2008
  • 124 Answers
SOURCE: vertical to horizontal
most all airhandlers have a second pan included . if not they can usually be purchased with directions to mount to the side of the coil for horizontal right or horizontal left application. remove the front panel and take a flash light look inside and you should see a cookie sheet looking pan on one side of the coil usually on the right side coil can usually be removed and reinstalled with the top of the coil facing the filter or the blower depending on how you want the air to go . just be sure the pan is under the coil and you will be ok . i have actually seen pros install them with the pan above the coil! and of course they flood the place. water of course goes down hill. the square donut pan used for vertical install stays in place as found. you will need to install a second emergency pan to catch any backup drips especially if you put it in an attic. you should find them at a sheet metal shop and they are basically a pan even bigger than the airhandler that catches any drip. it should be connected to a drain to the outside also and a float switch installed in case it fails to shut off the ac. better to get a no cool call than a flooded house call. try to put the second drain out over a door or window where it will be noticed before damage. good luck and remember you will have to relocate ductwork, electric drains filters refrigerant lines and if its in an attic a decked service area and a light and an outlet are required here in fla. good luckagain.
Posted on Oct 25, 2008
  • 74 Answers
SOURCE: Trying find a part # for my Ruud Return Filter
measure the old filter and go to the hardware store and buy one
Posted on Jun 17, 2010
jumptrout51
  • 3361 Answers
SOURCE: I want to check the blower motor and oil it if it
If it is less than 15 years old it has no oil ports.
It has sealed bearings.
Posted on Sep 06, 2010
heinzhvac
  • 229 Answers
SOURCE: Is this air handler capable
You have to move the drain pan from the evaporator coil to make it functional for the install position.
Everything else should be fine after that. If this helps please rate me and do a testimonial.
Posted on May 31, 2011
My system uses a permenant air filter. It's missing. It's a Ruud Model UBHC-21J18SHG. What size filter should I put in this system?
The Ruud UBHC-21J18SHG has a nominally 21" cabinet width. So the needed filter is 19.75" x 21" x 0.375" (502 mm x 533 mm x 9.525 mm). The Ruud part number for the filter is 54-23217-03 .
The specifications sheet for the Ruud UBHC series air handlers is available here: http://www.coburns.com/images/PDFs/h22-517rev1.pdf . The filter size information is on page 3 and page 12.
I've found the filter at one online vendor: http://www.patriot-supply.com/products/showitem.cfm/RHEEM_68_101807_03 . (This is a common filter that fits several manufacturer's air handlers.)
I hope this helps.
Sep 10, 2011 | Ruud UBHC Air Conditioner
I have a Ruud Model UBHC-17J11NFD in my basement. Water is coming from the bottom of unit and pooling onto the basement floor. What should I check first?
Hello, most likely you have a clogged condensate line, in order to clean it you will need a wet/ dry vac and attach it to the outlet of the line and the suction pressure should dislodge the clog. Also, if the unit uses a condensate pump make sure it is working, if its not it can cause water to pour out onto the floor.
Aug 09, 2011 | Ruud UBHC Air Conditioner
I have a ruud model no. ubhc-17j11nfd and i am having a problem with my heat. when the heat does come on, the thermostat says it is on auxilary heat. i am getting no suction from inside the house but the...
If you haven`t changed your furnace filter do so. If there still isn`t any air flow then the evaporator coil is plugged with dirt and needs cleaned. It is inside your furnace where the pipes from the outside unit connects. As far as the auxilary heat, this is normal when the house temperature drops to far below the thermostat set point and they will turn off when the house is close to temperature and lets the heat pump take over.
Feb 02, 2011 | Ruud UBHC Air Conditioner
Air handler motor stopped working
Check the capacitor before you replace the motor. It's a common problem that's easily fixed. Make sure the fan rotates freely.
May 23, 2010 | Ruud UBHC Air Conditioner
How do I change the filter in my Ruud Achiever series
I'd look in one of 2 areas.
1. often there is a central return in the house. This is the place where the air gets pulled back to the unit and is likely very close to your thermostat. Check for a filtered louvered grill there and see if your filter is located here. If so, you can access the filter by opening the filter frame with a screwdriver or even a coin.
2. Otherwise I would expect that your filter is on the return-air side of your air handler (where the blower is) Older models have the filter actually inside the air handler in the blower compartment. Newer models may have a small separate filter door. I'd look in these areas.
hope this helps
ghoff
Feb 21, 2009 | Ruud UBHC Air Conditioner
Need to find ac coils for RUUD ac in the Air Handler
follow the copper lines coming into the air handler.1 will be large and insulated and the other smaller and uninsulated.They attach to your evap coil.
Aug 18, 2008 | Ruud UBHC Air Conditioner
Wiring Diagram
Sep 02, 2007 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
