Question about Stoves Ovens
Thermador cook and vent gas stove 024-00218-02 CAV 2
I can't see the temperature or the time any longer is there an LCD light inside and is it a DIY project?
5 Suggested Answers
shivam4529
  • 150 Answers
SOURCE: Thermador Professional Oven
hey man don;t worry i have too much solution if i explain u every thing then you confused so i explain one and if u want another then e-mail me on mango4529@rediffmail.com so listen carefully
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
An oven that won't heat can occur for a variety of reasons.
and if not then open this link http://home.howstuffworks.com/how-to-repair-an-oven.htm
Posted on Nov 23, 2007
vest6
  • 196 Answers
SOURCE: Oven not cooking evenly, outside is getting brown but inside is undercooked
Sounds like the igniter is not operating at full capacity. What happens is that the oven does not light when it should. Instead, the oven is cooling down much too far so when the oven does light it has too heat more rapidly. This causes the outside to brown/burn long before it should.
Posted on Jan 26, 2008
EllaWatson25
  • 725 Answers
SOURCE: My Thermador Oven model med302es does not reach
You need a new control board on this for it to work properly. Call us with your complete model number and we can ship the correct part out to you right away! We look forward to working with you!
Posted on Oct 19, 2009
  • 491 Answers
SOURCE: 1937 anitque American Stove came with Magic chef
THE PILOT LIGHT IS IGNIGHTED BY AN ELECTRICAL WIRE THAT IS LOCATED BESIDE THE GAS JETS SO MAKE SURE THE ELECTRICAL IGNITION SYSTEM HAS POWER YOU NEED TO LOCATE THE WIRE AND FOLLOW IT TO FIND THE POWER SORCE THEN CONECT THE POWER SUPLY TO IT , GOOD COOKING.
Posted on Nov 22, 2009
Where can I get a replacement knob for a Thermador Cook n Vent gastop. The model number is CV2136
try contacting the company that makes to stove, there should be a stag on the back to tell you who made it
May 06, 2016 | Ovens
Nov 23, 2007 | Thermador POD301 30" Pro Series Deluxe...
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=53
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts - RepairClinic.com
www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
Dec 19, 2015 | Thermador C272 Electric Double Oven
Have a frigidaire gas stove has worked great for 6 years. Now we are getting a strong smell of gas when it is heating up or cooking. Have checked to make sure flame is on and it is. It also seams like it...
Try changing out the regulator for the stove. Does the flame seem weaker than it used to? If so, your regulator is probably going out and the gas you smell is the residual leaking out when the stove is on.
Jul 01, 2011 | Frigidaire Ovens
I have an Amana AGR5715QDS and when I turn it on and set it for any temperature, lets say 350 degrees, it does not turn on or heat up. The stove top burners still work fine and the door appears to be OK,...
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Feb 05, 2010 | Amana Ovens
1937 anitque American Stove came with Magic chef cook book and Loraine thermostatic temperature regulator. Having problems getting Oven pilot light to light. Have checked thoroughly for leaks but have...
Nov 22, 2009 | Ovens
Thermador Oven SEM272
I have a THERMADOR 6 burners gas unit, if the door is not completely stright, sometimes cause this kind prblems.try to move up and down several times first.
Jul 05, 2008 | Thermador Ovens
Jan 24, 2008 | Whirlpool SB160PEE Gas Single Oven
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
150 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
