Question about Phonic Powerpod 740 Plus 2X220W 7-Channel Powered Mixer with Digital Effects
Can i connect an amp to my powerpod 740 plus to use as a monitor speaker
3 Suggested Answers
robotek
  • 1512 Answers
SOURCE: connecting a guitar amp to a mixer amp
Hi cliff
Connect either of the XLR DI output of the Behringer directly to a MIC IN channel on the Powerpod using a standard Microphone cable. If you wish to push a stereo sound then connect both(L + R) of the XLR DI outputs from the amp... that's about all you need to do. The only reason you need to use stereo(both XLR Outs) from the Behringer is if you want a full stereo FX output from the amp, otherwise you can get away with 1 connected. You may need to back the gain off for those channels on the power pod. You can get a manual for the Powerpod from here
and user manual for the acx900 here
Hope this has helped you, If not, feel free to ask any questions. Cheers.
regards
robotek
Posted on Aug 18, 2008
  • 357 Answers
SOURCE: I have speakers plugged into
Yes it's possible. I'm assuming you'd like to use the keyboard amp as a "monitor". In which case, take a 1/4inch TS (instrument cable) jack out of "Aux Send" into the input of your keyboard amp. Make sure the keyboard amp is turned up to a good level and that the Master SEND is turned up on the Desk.
Now you can make your own "monitor mix" for on stage use without effecting the F.O.H mix by turning up the aux pot (knob) on each channel you use.
You can use the CTRL ROOM output also, but make sure it's not giving a "Powered Output" from the internal amplifier in the mixer as you will damage the keyboard amp.
Posted on Jan 16, 2011
When I try and turn on my phonic 740 plus 2x220w powered mixer there is no lights that go on, it seems like it isn't getting any power?
The most likely cause is a blown fuse and fuses are cheap. I would replace the fuse and try it again. The fuse may be hard to find so I would take the fuse and try Radio Shack Fry's or any where known for electronics. If it's not the fuse it could be the power cord you could try any computer power cord to check that. If it's not any of that you could take it apart and look for the problem. I can walk you through the basics if you want.
Jun 21, 2014 | Phonic Powerpod 740 Plus 2X220W 7-Channel...
Can a pc be connected/used with a k12 power mixer
As long as your mixer has a line output jack ( L & R or MONO ), yes.
Oct 19, 2013 | Phonic Powerpod K12 Plus 1000W 8...
I am needing to replace my piezo drivers for the S715 cabinets and they are 8 ohm 15 watt drivers. Will these cabinets only safely handle 15 watts, or can I replace them with higher wattage drivers? I am...
No worries here, in fact you can attach a non-piezo hf driver, coupled with a 2.2uf/3.3uf MKT filter and that should do the job with ease, even better than with piezoelectric devices, hope this helps...
Sep 14, 2013 | Phonic Powerpod 740 Plus S715 PA System
How to use an amp with the powerpod 820 mixer
you always keep your sound in line. what i mean by this is if your powerpod is a PA then you would want to run your instrument-pedals-amp-PA. Not saying this is the only way but it is the standard way to configure your components.
Jan 11, 2013 | Music
Sound keeps turning off after ten muients
I've had this problem with other sound equipment. For me, it was a heat issue and there was an auto shut off feature to save the unit from over heating. I would especially think this is the case if it turns back on without problem after another 10 minutes of being off.
You could try turning off phantom power if it isn't needed to run your mics. Or making sure it is in a spot that allows maximum air flow through the head.
Hope this helps! Don't forget to rate!
Jun 26, 2012 | Phonic Powerpod 740 Plus S715 PA System
Phonic Powerpod 1860 - One channel xlr input stopped working. What could cause that?
Several things could cause this... connecting it to a piecee of equipment powered from a different wall receptacle cound result in ground bounce on the building power that could destroy the input circuits. Another thing is if a static discharge hit it... There are bypass capcitors at the inout that could have shorted. Of course the fader could have failed...
Aug 12, 2011 | Phonic Powerpod 1860 Plus Powered Mixer
I have speakers plugged into my phonic powerpod 820 right now but I want also to have the output of the mixer to go through an instrument amp, is this possible? If so, where do I connect the instrument amp...
Jan 16, 2011 | Phonic Powerpod 820 / S712 PA Package
I have a phonic powerpod 7. the speaker connections are A & B main 1 & the same main 2 in the middle there is 1 1/4 jack socket that says bridge. it says dont connect any speakers to a or b when...
In bridge mode, the left and right amplifiers are in essence connected together. Typically, the speaker connections are to the positive connectors for each channel for this mode. WIth the speakers still connected, you essentially shorted the outputs to ground and smoked the output section. The unit will detect this now and not turn on the output section. Your unit is in what is usually called "protect" mode. This unit will require repair. Expect to have the output transistors replaced at the very least. I would estimate around $16-$40 for parts.
Dan
Jul 01, 2009 | Audio Players & Recorders
Connecting a guitar amp to a mixer amp
Hi cliff
regards
robotek
Aug 08, 2008 | Phonic Audio Players & Recorders
Phonic Powerpod 740 Plus 2X220W 7-Channel Powered Mixer with Digital Effects Logo
Top Phonic Audio Players & Recorders Experts
Greg Cann
Greg Cann
rhodesworks
Are you a Phonic Audio Player and Recorder Expert? Answer questions, earn points and help others
