Panasonic air conditioner cs cu pe12dke - Heating & Cooling
4 Suggested Answers
skdeepak88
  • 232 Answers
SOURCE: need filters for air conditioner
https://spares.bigwarehouse.com.au/index.php?cPath=137_176_4994
Use this to buy your product online :) rate this!!
Posted on Aug 17, 2009
Testimonial: "thankyou so much your help is greatly appreciated fantastic "
  • 534 Answers
SOURCE: Panasonic CS/CU-A242KR Air conditioner leaking water
OK lets see what we can help you with here. The condensate drain is clogged. There are a couple of ways to clear this clog so lets give it a try. If you know where the drain for the a/c is located outside (usually by the outside condenser unit) it will be a pipe that is just sticking out of the side of the house, if you find it take a wet/dry vac and place it on this pipe and turn the vacuum on and make a seal with your hand this should unclog the drain. If you don't find this pipe outside the house then go to the furnace and you will see at the bottom of the furnace a pipe (PVC) white, this is the drain for the unit inside. Take the wet/dry vac and have it at the ready in the event the clog is further down the line than at the furnace itself now the fittings on this pipe should not be glued together due to the ability to access for this very purpose. Take the pipe apart at one of the fittings and place the wet/dry vac on the end of the pipe towards the furnace and using your hand make a seal and evacuate the line. Do this to both sides since you don't know where the blockage is. If you are unable to separate the pipe at any fitting you will need to cut the pipe and at the spot of the cut you will need to repair it with a sleeve. Remember that the drain pipe is plastic and is made of pvc so you can get a repair coupling from any home improvement store for this repair.
Hope this helped you some
Dave
Posted on Feb 21, 2010
hvac1960
  • 2133 Answers
SOURCE: FAULT CODE H19? WHST IS
H-19 Error code means indoor fan mechanism locked. replace fan.
Posted on Dec 12, 2010
Panasonic CS-A12DKD Air conditioner does not
This could be an inoperative reversing valve or bad reversing valve solenoid coil.
Oct 31, 2013 | Panasonic Heating & Cooling
Panasonic heat pump timer light flashes
check if it is poor contact .or current is too small.
wall light
May 20, 2012 | Panasonic CU-E18JKK-1/CS-E18JKKW-1 Wall...
PARTS OF CU PC24DKQ
Hi
You can buy the parts from any of these links:
Link 1
Link 2
Hope this helps...please post back for further assistance.
Daniel
Jan 19, 2011 | Panasonic CS-A12C Air Conditioner
FAULT CODE H19? WHST IS IT? panasonic air conditioner cs/cu-e18jkr.
Dec 12, 2010 | Heating & Cooling
Panasonic air conditioner CS-E24GKR...The unit stops and the timer indicator blinks. Also displays error code H 11...Help...Please...its hot in here
H-11Indoor / outdoor abnormal communication. Check • Internal / external cable connections
• Indoor / Outdoor PCB
Jan 04, 2010 | Panasonic CS-A12C Air Conditioner
Air con timer flashes cs/cu-e24fkr
likely it is low on battery juice . open it and replace
Jun 04, 2008 | Panasonic Heating & Cooling
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
