Question about Nintendo Wii Console
Remotes i cant seem to get the conection on my wii remotes to work. on one remote, one light on the far left is blinking. on my other remote, all the lights are blinking. I have no idea how to solve this problem, or how this problem was caused. it just seemed to happen.
  • 34 Answers
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Posted on Mar 09, 2009
    Problem Solver:
  • 5 Answers
When the lights are blinking like that, it's indicating the battery level, and also indicates that the wiimote is not connected to the wii. Replace the batteries in the one with the left light blinking and see what happens. Try turning off the wii, and pressing the power button on one of the wiimotes. It should turn on the wii and then the far left light will turn solid. Then press a button on the second wiimote and it should connect. If it doesn't, press home on the first wiimote, go to the settings at the bottom, and click Reconnect. Then follow the onscreen instructions and the problem should be solved. Note: my account name is supposed to be ryanriopel28..
Posted on Aug 09, 2007
SOURCE:
How do I synce wii remotes
instructions
  1. You will first need to make sure your Wii remotes have batteries. Then, turn on your Wii and go to the Wii menu.
  2. Open the little white door on the front of the Wii game console (this may require using your fingernail). You will notice a little rectangular red button.
  3. Open the battery compartment of your Wii controller, which may require removing the rubber jacket. You will notice a little round red button there.
  4. Press and hold the red button on the Wii game system and the red button on the Wii remote at the same time for at least 2 seconds. I usually hold down the remote button, then press the game console button for 2 seconds because it is easier for me. You will notice the 4 little blue lights on the front of the controller blink many times. The lights will eventually stop blinking and one of the four lights will remain on. The light that remains on tells which number Wii remote you have. The one on the left is number 1. The second from the left is number 2, etc.
If you bring your remotes to a friend's house to play, don't forget to sync your remotes back to your Wii console when you get home.
All the best!
Tsunami Dan
Read more: HERE
Mar 29, 2011 | Video Game Consoles & Games
My dog ate the instruction book for the intec wave plus for wii. I don't know how to sync back to the wii.
The Wii console has a small door in the front of it that covers the slot for a mini SD card and the red "Sync" button. With the Wave battery in the Wii remote you cannot push the corresponding "sync" button on the remote with your finger but there is a small hole that you can poke something thin like a paper clip through to push the button.
Push the red button on the Wii console and use a paper clip to push the button on the Wii remote. Both buttons do not have to be pushed at exactly the same time, there can be a few seconds delay.(This may take a few tries as the "sync" button is a bit hard to hit on the remote though the small hole.) All four lights on the remote should blink a few times then only the first light to the left will stay solid indicating that the remote is synced. If the lights blink and then all turn off, try to sync again.
Jan 07, 2011 | Video Game Consoles & Games
I just got the wii fitness but my wii remote does not want to conect the lights flash and then just stops and the remote don't work what can i do
have you tried syncing the wii remotes ?
Note: Make sure you have placed batteries in the Wii Remote.
  1. Press the Power button on the Wii console to turn it on.
  2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and press the SYNC button just below the batteries. The Player LED will blink.
  3. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 to 4).
This procedure must be followed for each additional Wii Remote added to your system.
Dec 26, 2010 | Nintendo Wii Console
My console keep on blinking i cant seem to operate on the screen
you have to sync the remotes to the wii box[consol]
On the wii box there is a door under the power/restart buttons, in there is a red button push it..
next on the remotes open the battery cover, look for the red sync button,
push the sync on the wii box first then on both remotes to sync [synchronise] them.
it can be a pain in the... but keep trying untill it sync's
Apr 28, 2010 | Nintendo Wii Console
The Wii Remote for the second player does not work. Once in awhile the blue lights flash. We have tried to follow the instructions for synchonizing the remote with the console. And we have put in fresh...
Our grandson emailed the solution.
Turn on the Wii and open the game menu.
Click on the Home button.
Click on the Wii remote settings at the bottom of the screen.
Press "Reconnect" and then hold 1 and 2 on both remotes.
We will have to follow these steps every time we want to use the Wii.
It seems like a 'bother', but it works. At least so far.
Dec 30, 2009 | Nintendo Wii Remote Controller
Hi my wii remotes arent working please help
Possible scenarios:
Out of battery:
Solution:
Replace batterries
Connection has been intercepted:
Solution:
Take the back off of the remote and then go to the Wii and open the little compartment left of the Wii. Then press the red button on the Wii remote and console simultaneously untill something happens like, connection restored on the Wii screen.
Dec 30, 2009 | Nintendo Wii Console
Yesterday i was playing on my wii at my friends house and whe i bring it back to my house cursor do not appear i can press a button and + - buttons but i do not see any cursor... my wii is 2 days old...
Make sure to the little blue light on the wii remote is on on the far left. You may have to sync it. Take the battery out of the wii remote and there is red sync button. There is another red sync button under the little flippy door on the front of the wii where the SD card slot is. press both buttons and wait for the wii remote to stop blinking. Then point it directly at the sensor.
Dec 02, 2009 | Nintendo Wii Console
The batteries went in my wii remote so i replaced them but now cant get the remote to work,,i"ve tried everything i could think of so now asking for your help,can you help please??
You may need to sync up your remotes to your console again.
If the 4 squares blink blue, then stop, your Wii Remote is not synced. Press the 1 and 2 buttons at the same time. This should connect your Wii Remote if it's been synced before.
If your 4 squares still blink blue, then stop, these last steps will do the trick. First, on the front of the Wii console, just underneath the disc slot, there is a small panel that opens down. Open it and press the small red button.
Open the battery panel of your Wii Remote and press the small red button. Replace the battery panel and observe the blinking blue lights. If 3 stop blinking, and 1 remains lit blue, your Wii Remote is synced with your console. Make sure to secure the wrist strap, and have fun!
Nov 24, 2009 | Nintendo Wii Console
Unable to connect drums and guitar for guitar hero world tour wii
i couldn't get the console to see the guitar, so after making sure the the remotes were synched with the console individually, i pressed the reset on the console and then started guitar hero software before putting the remote in the guitar, making sure the first light remained lit in the remote. (am only using the guitar). so far so good, seems to have worked.
Dec 26, 2008 | Nintendo Guitar Hero Wireless Guitar - Wii...
Brand New Wii Remote not working
tracey.....take the battery cover off the back of the remote....then go to the game system cons and open the front flap to the left of the cd slot (find the red sync button on the cons......press and hold the red sync button next to the batteries on the remote......now just press the button on the game system (do not hold button on the cons.)....watch the remote led lights on the bottom....when they are done blinking there should be a light left on (if this is the second cotroller, it should be the second light from the left that is on).
Dec 25, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
170 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
