Question about Jandy Pool & Spa
Clicking noise Jandy pump making clicking noises and shaking pipes. What causes this
    Top Expert:
  • Jandy Master
  • 4,292 Answers
Water going through heater too slow pump impeller might have restriction manual bypass spring in header might be defective check to see if filters are clean
Posted on May 02, 2015
4 Suggested Answers
StepehnD
  • 78 Answers
SOURCE: My Hayward H model makes a heavy clicking noise
I am a little confused about the fan issue. Are you talking about the fan in the heater as in a Lo-Nox? Sorry but I just need to pinpoint the area... BTW, the bypass that is in the unit is in the header manifold that the other poster explained.
Posted on Jun 27, 2010
app_3rp12317
SOURCE: Loud noises, shaking, visible white powder in chlorinator
See this page:https://sites.google.com/site/haywardpoolheater/
For info about the part that breaks and how to fix it. YMMV.
Posted on Jan 06, 2012
badfish6686
  • 563 Answers
SOURCE: My Jandy lite 2 natural gas heater has a loud clicking noise. It fires up and heats my pool nicely. My problem is.... as it is heating there is a loud clicking noise from the gas valve area. It acts a
I would suspect that it is not the valve making the noise. I would bet it is the thermal expansion of the metal that you are hearing. Other than that, I have seen cases where there is a flow control valve, and depending on its operation, when it opens or closes on spring power it will over shoot and make a loud clicking noise as the clutch overshoots. This will usually only be about 2-4 clicks though, and around pool equipment I doubt you would hear much of it. I would bet more on the thermal expansion. Kind of like the clicking noise you will hear after you have parked your car and the engine is cooling down.
Posted on Apr 10, 2013
On the jandy 400 lt its displaying the AGS code... what does that mean?
Per your owner's manual:
AGS
(automatic gas shut-down)
1. Oscillating pump pressure.
1. Clean filter or identify and repair cause of pump oscillation.
2. Low gas supply pressure.
2. Identify and repair incorrect supply pipe size or pipe line blockage.
Refer to qualified service personnel.
3. No flame at burners.
3. No flame at burners. 3. Identify and correct loose wiring connections, or problems with igniter, flame sensor, gas valve, or ignition control.
For more info the manual is here:
http://www.jandy-downloads.com/pdfs/LXandLT_H02140B.pdf
John
May 03, 2011 | Jandy Laars Lt 400,000 Btu Heater
New jandy LxI 400 natural gas pool heater makes a howlering sound which starts after it runs for about five minutes. The noise starts soft and continues to get louder. The noise is loud. Once I shut the...
Your bypass valve is bad. Probably because you did not pay attention to your water chemistry. It is located where the pipes enter the heater. You remove it from the side of the manifold that is outside the heater. It is not a difficult job. Just make sure your pump does not come on while the heater manifold is open!
Apr 16, 2011 | Jandy LXI 400 NATURAL GAS POOL HEATER -
Noise at pump
Your problem is just a little vague. Noise could be several things including.... vibration can cause noise especially if the pump is not sitting solid on the ground. Cavitation around the impeller can cause the pump to be noisy. something stuck in the impeller can not only cause a number of irregular noises, but also affect performance. If the bearings are going bad they can make a number of bad sounds; anything from just sounding a little noisier than normal or a loud grumble to a loud high pitched squeal the can make a banshee turn and run.
Sep 18, 2010 | Jandy PHP High Head Pump 2 HP Up rated
The pipe is making loud shaking noise
which pipe, i assume you are referring to an exhaust pipe, do u have a loud (more than usual) exhaust sound, if so, the exhaust pipe is cracked or split, if not, then the exhaust hangers (mahe of heavy duty rubber) are split/broken, causing it to shake OR is the engine shaking as well, or just the exhaust, too many questions, need to specify
Jun 11, 2010 | 1993 Oldsmobile Cutlass Ciera
JANDY JHPU 2.5 PUMP is making a noise.
Thank you for posting your question here on Fixya.com.
Your motor bearings are failing. It is most often caused by a leaking pump seal. It is a relatively inexpensive repair if it is caught early enough; before the shaft is damaged from the corrosive water eating into the steel. Take it to a local electric motor repair shop for inspection. It will likely need a set of 203 bearings for the motor and a mechanical seal for the pump. All told, depending on the labor rates, it should be less than $75.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Feb 28, 2010 | Jandy PUMP SHAFT SEAL - FITS PUMPS
Whirlpool top load washer makes noise on filling
Its mainly caused by back pressure when the inlet valve suddenly shuts off the water to the machine. The pressure causes your plumbing pipe work to shake inside the walls.
You can turn down the pressure by closing your water tap and only having it slightly open. Or you can get pressure limiters which join on the hose.
Regards
Ash
Oct 26, 2009 | Whirlpool Washing Machines
Looking to buy pvc pipes to fit Jandy pool heater in and out flow pipes live in slough uk
jandy in and out pipes are 2" schedule 80 cpcv and should beavailable at any plumbing supply house. buy on 16" nipple and cut in half.Thread into headers then pvc cement the unthreaded end to tie into pump/filter system
Aug 21, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Pilot lit clicking noise no burner
make sure knob on gas valve(inside heater)is turned to on position.3/4" should be fine as long as heater is not larger than than 175,000 btu
Jul 14, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
1 year old hayward h1001d pool heater clicking
Actually, the clicking is likely causing the shaking. Inside the manifold of a H100 is a stainless steel diverter plate that send some of the passing water into the heat exchanger and lets the rest past and back to the pool. When it breaks, you will hear a 'clicking' noise at it rattles in the water path. When it breaks, the flow to the heat exchanger is intermittent and you will begin to boil the water, causing the shaking. This situation is dangerous, especially without a pressure relief in the heater or pipe. As long as your water chemistry is sound, Hayward will usually cover this under warranty even if the unit is over a year old. Contact them to get a factory authorized repair rep out at: http://www.haywardnet.com/locator/
May 27, 2009 | Hayward H Series Induced Draft Abg 100,000...
Pool & Spa Logo
52 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
