Question about Miller Big 20
Welder want put out current
My Miller big 20 engine runs fine, but I can't get the generator to put out current, what could be my problem.
RixsFixes
  • 2200 Answers
SOURCE: looking for an instruction manual for my miller 225g plus
You can get this manual from the following link http://personafile.com/Miller-Welding-Equipment-BOBCAT-225G-P9207349821373.htm
Please remember to rate my answer. Many thanks.
Posted on Jul 07, 2009
SOURCE: I have this Miller
go to the miller website and download the manual. the scematic is in the manual
Posted on Mar 29, 2011
luis_david
  • 407 Answers
SOURCE: Miller Roughneck 2e generator and
Hi:
Your machine overloaded and the Fuse F1 must be open, just change it. Here's the link to the owner's manual:
http://www.millerwelds.com/om/o420l_mil.pd
Check section 6-4 for more details. ' Good Luck!
Posted on Sep 07, 2011
precisionfen
SOURCE: miller bluestar 6000 welder/generator.
wont run
Posted on Sep 19, 2012
  • 1249 Answers
SOURCE: I have a miller welder / Generator 225G plus that does not have any power output
These rigs are notorious for developing bad connections in switches and wiring, as well as getting stuck or burnt brushes in the generator. If it has been sitting for some time, I would definitely do maintenance on the brushes and check switches for rusty or burnt contacts. http://www.millerwelds.com/om/o175104b.pdf
Posted on Dec 14, 2014
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and forth to high then to low idle?
The unit may need recalibrating the idle/run setting. Instructions found in manual at 8-6 (subaru engine) and 9-5 (kohler). Idle speed around 2200rpm. Simple screw adjustment. PDF manual here :- http://www.millerwelds.com/om/o4434l_mil.pdf
Aug 02, 2014 | Bobcat Miller 225 Welder Generator 907209...
Miller welder problem
If it has a timing belt it broke or lost a few teeth. The camshaft became disengaged from the crankshaft. Any Automotive mechanic can fix it.
Jul 30, 2014 | Miller Big 20
Gas runs out of carb drain on miller welder generator 301g trailblazer
if it is the float bowl drain leaking, close the drain. If it is the vent, clean float bowl and needle and check level. Next time, drain the fuel out of float bowl after you run it if not planning to run it for 30+ days. That is why they put drains on generator carbs. Modern ethanol turns to gum real quick. Tell you congressman you think ethanol sucks and the new 15% ethanol the farm lobby is trying foist off on us is going to be a disaster for small engine owners.
Apr 10, 2013 | Miller Trailblazer 301g Cc/cv, Ac/dc...
Engin boggs down while welding
have you had the cables tested,welding weares them out.how old are they a welder is like a big old coil or armature the contact points on it gets corroded causing it to work harder causing your bog
Apr 08, 2012 | Miller Trailblazer 302 Welder Generator...
Bobcat 225 does not produce ac current 110 or 220?
Probably you need to act the braker, put the idle at max (pull throtle) and let it run for a minute, that will reset the braker.
Dec 03, 2010 | Bobcat Miller 225 Welder Generator 907209...
Miller Big 40 will not weld and has no current at the A/C outlet
open inspection door,which also the fine tuner knob is ,there's a 2x4 size circut board that snaps out with little force to remove,this is the voltage regulator board,look for 4700 ohm resisitor burnt into,tv tech can fix or order new board at $227.00 what i paid.
Jan 23, 2009 | Welding Tools
Miller Big 20 Logo
35 people viewed this question
Top Miller Electrical Supplies Experts
littlewheel
Level 1 Expert
Lawrence Oravetz
jeff5may32
Are you a Miller Electrical Supply Expert? Answer questions, earn points and help others
