Question about Visioneer OneTouch 7100 Flatbed Scanner
Lock On Error
I get Locked scan head error When I try to scan. I figured out that the scanner looks for black, then white on the underside of the flatbed at the beginning of scan cycle not seeing this it assumes the head did not move and it therefore locked. Lamp works. Stepper motor drive system works. One touch software detects scanner as present. I found 4 expled 100 ufd 15 V caps on logic board and replaced them. No help. The circuit appears to be similar to a series 5 V regulator in my Radio Shack Power Supply Book. I think part marked TR3 is blown. TR3 screened onto logic board. Chip is 3 lead + heat sink tab transistor and has B A R U printed on it as part ID in 2 lines. I cannot figure out exactly which lead is which except that tab is collector. I tried replacing with both PNP and NPN transistors and neither help. Unit draws 470- 480 ma at 12 v from a lab quality DC supply.
  • 1 more comment
  • ArizonaHiker Aug 09, 2007
    Silverdragon-
    Thanks for the thought. The physical lock is not on. In the first inch of travel the scan head passes pure black, then pure white on the underside of the flatboard glass mounting frame. The software looks for that difference in output to calibrate, I think, but also to decide that the head is moving. When it does not see the black/white pattern while the stepper motor is running it thinks the head is not moving and produces the Locked error message. In fact the head is moving but no output is being seen somewhere. I'm hoping it is just power to the A-D chip and if I can fix the power problem I will have a working unit. That is why I am trying to find info about the TR3.
    ArizonaHiker
  • healy62 Nov 26, 2007
    Did you guys ever figure out a fix?
  • sios012003 May 14, 2008
    The same thing, mi 7100 doesn't run in win sp2, everything seems to work fine,  find  the scanner, paperport also works, light is on, but whe is going to scan always got the lock error (of course it's unlocked) ¿you now how to fix that?
  • 12,061 Answers
Um just as a thought, but often there is a physical "head Lock" thats used when transporting the unit, are you sure this hasn't been activated? Just a thought.
Posted on Aug 09, 2007
SOURCE:
I cannot use scanner Lide 25.. because show error : "release the lock switch,detach the I/F cable and reconnect" How solution?
Sounds like the scan head is locked. This is usually done so you can transport the scanner without bouncing the scan head out of alignment. Look under the scanner and you will see it. Make sure it's in the UNLOCKED position. You may need to power the unit off/on to reset it or restart your computer to get a fresh attempt at the scanner.
Mar 05, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
Error: power off power on
This is a typical problem with this printer also followed with scanner error. Most likely cause is scanner optics dirty causing the scan head to be unable to find home position ( white strip on the underside of the glass). Note cleaning the scanner optics requires technical know how as its fairly difficult to remove the glass. Damage to optics may cause image defects on output.
Feb 17, 2010 | HP LaserJet 3330 All-In-One Printer
Unit makes a clicking sound at end of the power-up sequence
Sounds like the scanning mirror might be locked - during shipping, the mirror is locked to prevent damage. Look around the back or the underside of the unit and look for a slider with a lock/unlock picture on it. Slide it to unlock and the mirror should be free to move.
Nov 20, 2009 | HP OfficeJet 6110 All-In-One InkJet...
L1 subcode 00
L1-00 indicates feeding is not completed
within the specified time after starting feeding.
(The scan head locking switch is locked)
The white area and the black marking on the shading plate are used to obtain the difference in the CCD level values for judgment of lock. When the difference in the levels of which and black is small, it is judged that the black mark could not be scanned by lock and the trouble code “L1” is displayed.
Apr 23, 2009 | Office Equipment & Supplies
I can not get my scanner to scan
If the lamp simply will not move then the green latch on the bottom of the scanner is locked and holding the scan head in the locked position.
If it is a scan to network issue or scan to E-mail you need to use a USB or parallell cable and you may have to change the USB port speed, But without knowing which problem you have I am not sure exactly where to head with this problem.
The scanner lock is located on the underside of the scanner. If you look in where you reach to remoce your copies, you will see on the bottom of the scanner a green latch, about 2 inches long and a half an inch wide. Push it in then pull it toward you until you feel it snap locked . Then power the machine off and back on.
Feb 02, 2009 | Xerox WorkCentre M15i Laser Printer
HP LaserJet 2840 Scanner Error
when poering on this HP 2840 it says" Scanner Error 5"
what does it mean? How to get a solution?
Apr 16, 2008 | HP LaserJet 2840 All-In-One Printer
Error: Release the scanner lock switch:
The scanner lock is locked pls unlock it dude...
Mar 15, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Officejet 7310: Scanner Failure
If you get a "Scanner failure" message then the problem is the motor itself. Notice how the motor works fine when the scanner is moving slowly, like copies or faxing with the original laid on the glass. HOWEVER, the scanner failure comes up when you use the automatic document feeder on top. Why? Because the scanner assembly has to move to the other side of the printer at high speed to get into position, and it's the high speed movement that triggers the error on the printer. The motor is expensive, part number Q3450-60003. Many other models use the same motor, maybe you could find one cheap somewhere and swap the motor?
Jan 10, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Visioneer OneTouch 7100 Flatbed Scanner Logo
165 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
Thomas F. Schneider
Ekse
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
