Question about Husqvarna 675 hp 21" Honda Rear Bag Push Lawn Mower with High Wheels CA Mo
Husqvarna Repair Manual
How do you replace the pull cord
2 Suggested Answers
  • 4234 Answers
SOURCE: husqvarna pull cord problem
I had this happen after about 15 uses. I just exchanged the unit. The pull start mechanism can be ordered and is easy to replace. There are parts inside that are nylon and break easily. Any local dealer can order the part for you.
Dan
Posted on May 03, 2010
Im having truble puting the starter cord and springs back in my husqvarna weed eater 128ld
You have to take it apart, get the spring back in, then wind the cord around around it. Not an easy task if you've never done it. A small engine repair or lawn mower repair shop will fix it pretty cheap and fast.
Apr 22, 2016 | Husqvarna 128 LD Weedeater
Starter cord will not pull
The pull cord or rope works on a tight spring just under the cover that the rope is in. Usually three to four small bolts on the edge of the cover to remove to repair/replace either the spring or the rope. First I would try to turn the motor manually with your hand on the flywheel, it should move around either direction freely with no effort. If it does not the motor itself maybe stuck not the rope. Then you have a seized engine and a different problem to deal with.
Dec 27, 2013 | Husqvarna 41 141 41 136 36 Recoil Pull...
Have you used the correct fuel and oil mixture.?
If its new and still under warranty then take it back to your local dealer.
Here's the parts manual
May 08, 2013 | Husqvarna Backpack Leaf Blower 350 Bt Yard...
My husqvarna 288 wont start, has extreme high compresion and cant pull cord with the spark plug in it. easy to pull with spark plug removed
http://www.ebay.com/itm/HUSQVARNA-288-CARB-REBUILD-KIT-COMPLETE-TILLOTSON-NEW-/140290773535 Your carb.may need rebuilt,remove and inspect,did you leave gas in it while it was stored,if so then carb is suspect.About 80.00 for a shop to repair,14.00 for you to do it.
Oct 10, 2012 | Husqvarna Garden
Husqvarna 325L x-series pull cord repair.
From my experience, the trick is to pull the cord all the way out, then attach the pull assembly to the engine, and let the pull rope win back in place. hope that helps.
Aug 28, 2012 | Cars & Trucks
My Husqvarna 232R brushcutter pull cord will not start
There should be several 'dogs' exposed after removing the starter assembly. These 'dogs' should rotate into the flywheel nut when the cord is pulled causing the engine to turn. Check with a Husky servicing dealer for parts. Good luck!
May 24, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna pull cord problem
Dan
May 03, 2010 | Husqvarna 28cc Gas Line Trimmer
I tried to start my older Poulan Chain saw a day after I had been using it. I find it almost impossible to pull the starter cord...there is too much resistance. If I take out the plug and pull the cord...
Did you remember to mix oil with the fuel before you put in the tank?
Remove the spark plug wire and the spark plug. Remove the muffler. Shine a light through the spark plug hole and inspect the cylinder through the hole where the muffler was. Is it smooth and shiny? Use the starter to move the piston up and down slowly. Is it smooth or does it appear scratched and gouged?
I suspect parts of your piston are adhered to the cylinder wall. If that is true it will probably cost more to repair it than to replace it.
You needn't take it to a poulan repair center. Most Stihl outlets employ good mechanics and can repair any saw. HTH
Lou
Shh... my Husqvarna gets serviced by a Stihl dealer... The Husqvarna dealer is actually closer to me. I feel better about the Stihl mechs.
Sep 30, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Lawnmower Starting Pull Cord Replaement
There will be a piece of casing that holds the starter mechanism in. Usually held by 4 screws (probably torx screws unless it's an old machine).
Undo these screws and you will find the cord carrier inside.
Observe how the starter dogs are located, and how it all goes together.
You may be able to remove & replace the cord without taking the carrier off the casing, but it is probably easier if you do.
Then you simply remove the old cord, thread a new cord through the hole & tie it. Reassemble the carrier onto the casing. Thread the cord out of the casing & through the handle, tie that end.
Then wind the cord around the cord carrier until there is a slight tension on the spring.
Screw the casing back on the mower and you're away.
Sep 20, 2008 | Garden
Husqvarna 675 hp 21" Honda Rear Bag Push Lawn Mower with High Wheels CA Mo Logo
24 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
