Question about Craftsman Building Materials
Craftsman tx2028 remote
One of the hand held remotes stopped working. The one that stopped is hardly ever used. The one regularly used has no problem. What to do?
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: craftsman 1/2 HP garage door opener, remote keypad stopped working
Try removing the battery and see if you can reset it.
Posted on Jun 01, 2008
  • 3197 Answers
SOURCE: Craftsman new 315MHz Garage door remote programming with old openers
The radio frequency has been changed so the two are not compatible.
Posted on Jun 01, 2009
  • 3197 Answers
SOURCE: I have Craftsman TX2028 remotes (139.53753) with
Make sure the green light in the wall control is not blinking. If it is, press and hold the 3 seconds the lock button.
Posted on Nov 29, 2010
Why wont my 3 remotes (hand held & factory in remote)only work to open the door ? They no longer work to open the door.I did replaced the batteries and reprogramed, craftsman 3/4hp chain drive
It could be that your door is binding on the way up and so it stops automatically. Try releasing the emergency pull cord and move the door up and down by hand to see if it is binding, probably near the bottom. The track may be misaligned or there could be something rubbing against the door.
Dec 15, 2014 | Craftsman 3/4 Hp Garage Door Opener System...
Why wont my 3 remotes (hand held factory in remote)only work to open the door ? They no longer work to open the door.I did replaced the batteries and reprogramed, craftsman 3/4hp chain driven garage d
SOUNDS LIKE SOMEONE MAY HAVE PRESSED THE LOCK / VACATIONS SWITCH ON YOUR WALL CONTROL. IF STILL NOT WORKING AND THE LED IN THE WALL SWITCH IS NOT FLASHING TRY AGAIN TO PROGRAM YOUR REMOTES.
GOOD LUCK
STEVE
Sears troubleshooting
craftsman garage door openers are made by chamberlain.. Give them a call on their 800 number with your craftsman model number and they will help you
Aug 23, 2014 | Sears Craftsman LiftMaster Chamberlain...
I have a hampton bay remote that just stopped working. I have installed new batteries, have checked the code with another remote so I know the problem isn't the fan. The light on the remote does not...
If the light on the remote is not lighting when you push a button, check the batteries to make sure they are in the proper position. If one is turned the wrong way, the hand held will not work. You may also want to check the replacement batteries to make sure they are fully charged. If all this fails to solve the problem, you will need replace the hand held remote. Since Hampton Bay Fans are a house brand for Home Depot, they stock and sell replacement hand held remote controls.
Hope this helped you. Please let me know. Thanks.
Jul 13, 2011 | Hampton Bay Heating & Cooling
The hand held divice stopped working and the mounted pad light flashes quickly. The mounted pad does work.
The most likely problem here is that your wall control is bad. I would disconnect the 2 wires going to it and I think you will find your remote works. Replace the wall control.
Sep 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Last night none of the remote controls worked (the one that came with the garage door opener or the remote Home link from our vehicle) The keypad also did not work. This morning, I erased all of the codes...
First thing I would do is remove the wire from terminal #1 on the rear of the motor unit and try your remotes. This wire goes to the wall control and it sometimes causes the remotes to quit. If this doesn't correct the problem then I suspect a bad logic board. Especially if you have had any electrical storms.
Aug 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
HomeLink works in vehicle... unable to program hand held or remot
When did your remote and keypad quit working? Was it when you programmed the Homelink? It sure sounds like you have a bad logic board.
Jul 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
41 people viewed this question
Top Craftsman Building Materials Experts
richie46
ray gallant
robert
Are you a Craftsman Building Material Expert? Answer questions, earn points and help others
