Question about Car Audio & Video
Bypass security system
Will not display will not turn on
  • 54 Answers
Plz give details of your unit? name and model number?
Posted on May 05, 2013
How to bypass security system on 19984 Bonneville
You can either buy a security bypass online or wire in two 15k resistors into the three ignition wires. Pink, green and brown.
Nov 17, 2017 | Cars & Trucks
Is there a way to bypass or shut the se curity system off
Usually not, except maybe on some after market security systems installed. But if it is manufacturer or factory installed, I don't know of any that have a bypass or a way to turn off the security.
May 08, 2016 | Cars & Trucks
Need to find out how-to reset security system on 99' Pontiac S S E turbocharged
Is the security light lit on the dash ? Turn the key to the run position , not start ! Leave the key on till the security light goes out ,about 10 minutes , then turn the key off an wait a couple minutes . Then start the vehicle . If it doesn't work you'll need to take it to a repair shop ,have codes read an go from there ! Or you can bypass the system , that involves find the right wires an soldering in a resistor of the proper resistance . You can google how to do a bypass on GM anti-theft system .
Aug 14, 2015 | Pontiac Cars & Trucks
Can i bypass the security light in my 1992 88 oldsmobile
Yes you can, go to this link for info and 2 ways to bypass your security system.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
May 23, 2012 | 1992 Oldsmobile 88
Engine wont turn over. getting fire and gas starter working ok.
what year is it. If it is just clicking, you might have a problem that plauged gm, your security system could be malfunctioning. there is a way to bypass this, you can find it on youtube. The passlock security system has been a real problem, just go to youtube and type in passlock security system bypass.
Jun 09, 2011 | Pontiac Bonneville Cars & Trucks
How do i bypass the security on my chevrolet s10 so that it will crank
YOU CAN CRANK VECHICLE BY PUTTING KEY IN THE IGNITION SWITCH IN ON POSITION FOR 10 MINUTES UNTIL SECURITY LIGHT TURN ITSELF OFF.THEN TURN OFF IGNITION SWITCH FOR 5 SECONDS THEN START ENGINE.YOU CANT BYPASS THE THEFT SECURITY SYSTEM BECAUSE ITS A FEATURE THAT CAME WITH TRUCK.THEFT SECURITY SYSTEM IS CONTROL BY BCM AND PCM. IF YOUR IGNITION KEYS AND SWITCH IS FAULTY ALSO THE BCM THEY ALL HAVE TO BE REPLACED AT DEALERSHIP AND REPROGRAMMED CANT BYPASS SYSTEM YOU HAVE TO GET IT FIXED.
Mar 12, 2011 | 1999 Chevrolet S-10 Pickup
Car won't start. Just had oil change, new starter, gas tank full, new battery. It shut off while I was driving. Information display shows there is no fuel and the battery power is zero, but I am still able...
Use a test lite and follow voltage from battery B+. The positive and negative battery connections have to be good on both ends. Check for voltage at fuses in fuse box, some fuses are hot all the time, some go hot with key on. Check for fusible links, I forgot to look in diagram?
I also looked at wiring for your starter motor, it shows a security system. The security system will disable starter motor. I can't be certain your security system is the problem? Does your key have a pellet in it? Any applicable trouble codes? Unless you can do some testing, I'm not sure which route to take? Is it an electrical issue or is your security system involved?
YouTube has a bunch of videos about bypassing the vats/pass key system. If that is the problem. My info on your model year, isn't that great.
Aug 14, 2017 | 1993 Cadillac Seville
Car wont start
as long as security theft system is on, car wont start.
don't you have the remote key to disable the theft system?
you can bypass security but you have to have wiring experience and splicing before you can proceed.
tnx 4 using fixya,
drcool
Oct 14, 2008 | 2000 Cadillac DeVille
Car Audio & Video Logo
18 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
