Question about Toshiba Satellite A35-S159 Notebook
How to disasemble the unit ?
, I need to replace the hard drive. Any exploded view ? or technical manual ?
  • laztclimber Aug 10, 2007
    CanDo I really appreciate your help , your response is really close to the solution, this laptop have the HDD behind the CDROM , so first I remove the CDROM ( it takes just 1 screw ) and the treasure was behind.. the damage HDD.
    Problem Solved, Thank you
    Scholar:
  • 161 Answers
It is very simple. Just go to the bottom side of your laptop and check under the door that is about 2.5 in by 4.5 in and remove the cover. pull the screws that hold it down and slide it back and out. It may have a special adapter . mark how it goes on and remove it. put the adaptor on the new hard drive and reinstall it just as you removed the old one. Fasten it down and replace the cover. Now you are ready to boot your computer and install your operating system.
Posted on Aug 09, 2007
SOURCE:
I purchased a disasembled tomahawk pressure washer need exploded view for parts and resembley
Google online and see if you can find a pdf manual. If not see if you can find something in a book store manual wise.
Jan 16, 2014 | 1982 Yamaha XZ 550
I have a Huffy 3speed "Sea Trails" 26' mens
Best to take into a bike shop, Internal hubs are tricky even with exploded views. The only source for these views I know of is Barnett repair manuals (most shops have them), but they do not provide free product from Barnett.
http://www.sheldonbrown.com/sw.html
There are a number of brands and models of 3-speed hubs you need to know at least the brand and model to get an accurate exploded view and better yet the year as they change. Shimano and a few other manufactures do make exploded views available for replacement parts but the barnett manual actually tells you "how" to fix it.
Apr 23, 2011 | Cycling
I want to disassemble the lower unit on the 115hp mercury outboard and rebuild it and I need the schematic to be able to replace the seals and o-rings
you actually want gear housing exploded view and/or lower unit mid section exploded veiw-i have the mercury service manual for the inline series 75 thru to 150 2 strokes-but my printer/scanner down at moment -hopefully fixed this week so will be able to scan and send to you
Sep 16, 2009 | Boating
Exploded view of Berings and washer HELP ME!!! GE WSM2700W
Go to appliancepartpros.com and type in your complete model number. There are some excellent exploded view diagrams of your entire unit, complete with part numbers. Another source you can try is searspartsdirect.com. I hope this helps you.
May 29, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
Replace ge advantium door handle. how do i disasemble the door to replace the handle?
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
May 11, 2009 | General Electric Advantium 120 Microwave...
Replace DVD Drive in a Sony Vaio PCG-K23
Here is the service manual for your unit with an exploded view of the notebook. Post back here if the guide still help you solve your problem.
Feb 25, 2009 | Sony VAIO PCG-K23 Notebook
Betacam Sp Error Code
It seems mechanical problem and you need to apart unit.
I would advice you to get Maintenance Manual of BVW-75 before to open unit and get help from mechanical exploded section.
Below is picture of Maintenance Manual and part of mechanical exploded view...
It is high end broadcast model and needs care in maintenance.
Good Luck.
Nov 26, 2008 | Sony Betacam SP Small Videocassette 30...
REPLACING FUSE IN WHIRLPOOL MICROWAVE
It's hard to tell from the exploded views, but it appears to be on the floor of the microwave behind the control panel.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If the fuse is not the culprit, also check the two thermostats - one on the magnetron and one on the top of the oven chassis.
The mini manual / tech sheet will show you where they are and how to test them.
To check the oven thermostat, you will need to remove the oven from the wall. You can download Whirlpool owner's manuals and installation instructions here.
Nov 04, 2008 | Microwave Ovens
Toshiba Satellite A35-S159 Notebook Logo
64 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
