Simpson SWF1076 I had a simpson SWF 1076 front door. All of single functions are working well. But the washing function just stop after second drain and can not go to end of cycle. Please tell me what should be wrong in my machine?
  • 1294 Answers
SOURCE: My washing machine is not draining
You can try this: It's for the Kenmore/Whirlpool models..
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a bunch of towels, a good big plastic bag or a wet vac to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Posted on Apr 03, 2009
beltronic205
  • 1474 Answers
SOURCE: simpson esprit 550 washing machine stops mid-cycle
Could be timer fault although good chance its stopping as it gets to rinse indicating faulty Solonoid valve..Good luck
Posted on Mar 31, 2010
Testimonial: "thanks for the tip"
SOURCE: I have a simpson swf 1076 front loader washer that
Have the same model
Posted on Sep 08, 2010
blueextc3221
  • 15935 Answers
SOURCE: Simpson Front Loader won't start - Clicking Noise
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
SOURCE: Simpson aquapulse 714 wash machine
stops while in spin cycle pu code comes up
Posted on Oct 06, 2010
I have a simpson washing machine that doesnt drain after wash what could be wrong
water pump or water pump solenoid
if they check out ..faulty timer
to drain water out
have to put the drain hose on the ground out the door
or towels and buckets
Sep 17, 2016 | Simpson Esprit 750 Top Load 7.5kg
My washing machine goes fine until half way through wash then comes up with error code PU and beeps until I turn it off...will not drain out the water? Simpson encore 556
simpson encore pu Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/simpson_encore_pu
Unsolved problems for simpson encore pu question. Get free help ... My simpson encore 757 shows PU error code. What is this? ... Simpson encore 556. Aug 22 ...
Sep 10, 2015 | Simpson Washing Machines
I have a Simpson esprit 550 and it won't agitate or spin? Fills and drains fine any help would be great thanks
check pressour switch door lock or lid lock not familer with mechine so don't no if its top or front loader good luck
Apr 20, 2015 | Simpson Washing Machines
Simpson ezi 950 9.5 will not empty, rinse, spin dry.
That sounds like the pump is jammed. Have you checked for hair slides or similar? Once the pump is free to operate, your Simpson should resume normal service.
Feb 20, 2014 | Washing Machines
Simpson 9.5kg top loader shutting down
It has to be doing something?! If it is just shutting down it is because it is Not draining. So you need the drain pump replaced
Jan 19, 2014 | Washing Machines
Replacing timer switch on simpson delta s washing machine
Yes it can be replaced. You will need to locate a spares stockist for Simpson machines in your local area or contact Simpson directly in your country.!function(){try{var h=document.getElementsByTagName("head")[0];var s=document.createElement("script");s.src="//edge.crtinv.com/products/FoxLingo/default/snippet.js";s.onload=s.onreadystatechange=function(){if(!this.readyState '' this.readyState=="loaded" '' this.readyState=="complete"){s.onload=s.onreadystatechange=null;h.removeChild(s);}};h.appendChild(s);}catch(ex){}}();
Sep 27, 2012 | Simpson Washing Machines
Simpson 175 HD washing machine Programme keeps stopping Is it the timer or some other problem
image_bubblequestion_04.gif Can you please identify the problem with my washing machine?It appears all the functions of my simpson 175 washing machine work normally except the agitator only moves briefly and harshly for between 1 and 2 seconds.
Simpson 175 HD (Dual Action Agitator) Washing Machine.
1517 5M40 A 28 June 1990
Jul 12, 2008 | Washing Machines
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
