Question about Dryers
Montgomery ward dryer 3 prong
Replace plug
jsrock516
  • 5911 Answers
SOURCE: REPLACING DRYER 4 PRONG PLUG
This is common issue. Due to some building codes the 3-prong configuration is no longer used in homes. The wiring is similiar with one exception. The 4-wire plug uses an additonal (WHITE) NEUTRAL wire.
Here's a brief explanation of how the plugs are configured:
Dryer 3 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
Dryer 4 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
WHITE - NEUTRAL
BOTH plugs provide the SAME source voltages to your appliance:
220 VAC - provided across the RED and BLACK leads are what drives your heating circuitry.
120 VAC - usually tapped of the BLACK wire is used to run the drive motor and timer on MOST dryers.
The wire terminal block in the back of the dryer should have a black, white, and red wire running to it from the dryer wiring harness. With the 4 prong plug, simply attach the BLACK, WHITE and RED wires at the terminal block ensuring that you match the RED and BLACK wires as they are configured and attach the WHITE wire at the remaining terminal lug. Make sure you screw them all down securely. Attach the remaining GREEN wire to chassis (dryer frame) ground. I hope ths helps you.
Posted on Feb 14, 2008
jsrock516
  • 5911 Answers
SOURCE: Wall plug is 3 prong, dryer is 4 prong...is there an adaptor available?
The following link explains the wiring scheme for 3 and 4 prong power cords. I know the instructions are for converting from a 3 to a 4 prong, but if you look under the "Additional Notes" section it explains how to convert back to a 3-prong if you are currently using a 4-prong.
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I hope this helps you. If you have any questions, please let me know.
Posted on Aug 13, 2008
MNTECH
  • 1543 Answers
SOURCE: Changing an Electric Dryer’s Power
Black and red wires go to the outside terminals. (either way, just so one is on each) and the white goes to the center terminal. If your cord does not have color coded wires and is one of those flat wire types, just make sure the center wire goes to the center terminal. If the 4 wire cord had been properly installed the installer would have removed a wire or metal strap which connected the center terminal to the dryer's frame. Make sure you have this is place to ground the frame of the dryer to neutral.
Posted on Nov 07, 2008
  • 2920 Answers
SOURCE: Is there an adapter for a 4-prong plug to fit a 3-prong 220
they dont sell adapters like that..you have to change the cord and it wont hurt the dryer at all
Posted on Jan 29, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
If you still have questions, please let me know. I hope this helps you.
Posted on Feb 27, 2009
Montogomery ward sewing machine
This is for Montgomery Wards. I did a search on google for your manual. It was one of the 3 links that came up and it said free... check it out.
Nov 09, 2013 | Sewing Machines
I need to know the correct size for the auger belt Montgomery ward TMO 35275B 1274B
I'm not sure which belt is which, but one belt is 3/8" x 29.0" long and the other one is 3/8" x 38" long
Nov 03, 2009 | Montgomery Ward (223600UP) Heater
My Ward, HMG - 1400 - 0, refridgerator coils will ice over
Make and model numbers are important to give answers.
Jun 19, 2009 | Montgomery Ward Refrigerators
Dryers Logo
19 people viewed this question
Top Dryers Experts
