Question about GE JKP45 Electric Double Oven
Ge Electric Double oVen
Model # JKP45WP -- Ovens work intermittingly - go on work for a few days - then we get a constant beeping noise and the ovens won't work - Clock is on - but ovens won;t turn on - turn circuit breaker off to reset - sometimes it works - sometimes not -- any Ideas what it could be and a solution
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 68 Answers
This may be related to a problem I have helped others solve. The solution is available free at my website. I have at last count helped over 1000 oven owners with a similar problem. http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf Hope it works for you too.
Posted on Aug 09, 2007
GE monogram double oven . Self cleaning top oven and F9 in red showing and beeping noise
F9 is a problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.
A common problem on many built-in GE ovens (you don't say if yours is built-in or free standing...) is air circulation in the control panel. The fan that keeps the panel cool either stops working or gets clogged with dirt/dust and can't move any air. This causes the panel to overheat and can cause all kinds of odd problems and error codes. If you have a built-in, check to make sure the fan is working and the mesh screen behind it is clean.
Jul 17, 2016 | GE Monogram ZET3058SHSS Stainless Steel...
Both ovens stopped working
good day,
hope this link below will solve your problem.
ovens
May 03, 2010 | Maytag CWE5800A Electric Double Oven
GE Oven door won't unlock after cleaning cycle (and cool down).
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 24, 2010 | GE JKP45 Electric Double Oven
My GE Profile oven is beeping every minute. I've
if its an f-7 error code its due to a stuck error code
Feb 06, 2010 | GE Profile JT955 Electric Double Oven
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
BEEPING
http://www.geappliances.com/service_and_support/literature/
Go to this web site. You have to enter the entire model number in order to get your manual.
Good luck and hope this gets it done for you
Jun 26, 2009 | GE Profile JT912 Electric Single Oven
The F7 code appears with a beeping noise. How do I turn off the beep for good.... selecting clear/off only works for a few seconds
Well, F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Thanks
May 27, 2009 | GE Built-In 24" Double Electric Wall Oven
Frigidaire double ovens F8 error and beeping
good day,
ovens
Mar 23, 2009 | Frigidaire PLEB30T8A Electric Double Oven
After self cleaning ge oven, door won't unlock
I turned off circuit breaker to the oven and tried to open it. It did not. I did it again and waited for a few minutes, it worked and I was able to open the door.
Dec 24, 2007 | GE Profile JKP56 Electric Double Oven
GE JKP45 Electric Double Oven Logo
583 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
