Question about Acer Aspire Computers & Internet
Smart Failure Predicted
I cannot boot up into windows, I cannot get into BIOS. I can only keep getting the message "SMART Failure predicted on hard disk 4: WDC WD5000BEVT-24A0RT0-(S1) WARNING: Immediately back-up your data & replace your HDD. A failure may be imminent. Press F1 to continue." I press F1, & it restarts the cycle. I couldnt back up anything if I wanted to. I can never even see Windows attempting to load, & I've been trying to reformat my Windows for like a month now. Boot up problems left right & centre. Acer Aspire 7551 Laptop. Windows 7.
5 Suggested Answers
marked
  • 6487 Answers
SOURCE: Laptop will not boot up
THis error is telling you that there's a problem with yoru laptop hard driver where the operating system is installed that's why it cannot boot, so the best thing to do here is to replace the hard drive then after that , if you have important file on that old hard drive from your laptop you can buy a hard drive enclosure and make the old hard drive a external drive and that way you should be able to retrive some of your data that is save on it.........
Hope that helps.......
Posted on Sep 27, 2008
Report
  • 50 Answers
SOURCE: SMART Failure Predicted on Hard Disk 4: Hitachi-(S1)-ToshibLaptop
that will be expensive. i just went to microcenter and asked them, they said many hundreds of dollars just to look at it, then like 1600 for the cheapest recovery...
I would
1. stop using it immediately. (after an error like that, you may have only minutes of life left on it)
2. get a 25 dollar external enclosure to put the drive into. If it's IDE make sure you get an IDE enclosure, if SATA, get SATA compat. external enclosure.
3. get another computer, o rgo to a friends house, etc, and try to read your data on their computer after plugging in your hard drive inside the external enclosure.
4. if you can see it, rush like mad to copy the data thats important to your friends computer before the drive is 100% dead.
microcenter and similar stores have external hard drives at $129 dollars for a terabyte. BUY ONE! :-)
Good luck
PS: rumors go around that if you freeze the hard drive in your freezer for an hour, it helps get the data off, dont know if this is in fact true. Once the drive is dead, it's dead. You cant do much about it unless youre willing to part with a lot of money.
Posted on Feb 02, 2009
SOURCE: SMART FAILLURE PREDICTED ON HARD DISK O:WDC
Well this error message means that the automatic drive checking software that runs all the time has detected that the drive is failing, either the electronics or the media. You need to backup any data to a DVD or external drive. The press F1, is so you can continue on and do so. You can burn/copy the data to DVD or copy to a USB hard Drive. Then you will need to get a new drive and reinstall your Operating System & data again.
Posted on Jan 30, 2010
SOURCE: SMART Failure Predicted on Hard Disk 0: WDC WD3200BEVT-75ZCT2-(S1) WARNING: Immediately back-up your data and replace your hard disk drive. A failure may be imminent. Press F1 to Continue
SMART failure error means your hard drive is dying and there is no way to make it working for a longer period of time.
Soon, your hard drive will fail permanently and won't give second chance to work and so prevents you to access any of your important data.
So, before disaster strikes, you're highly recommended to backup and replace your hard drive as soon as you can. Otherwise, you might be in big trouble.
Hope it helps!!
Posted on Jan 08, 2013
Smart failure predicted on hard disk repair
This means either your hard disk is about to fail or it already has in which case you will need to purchase a new HDD (hard disk drive) and then contact acer to purchase recovery disks or if it is still under warranty then contact for service.
Jul 19, 2014 | Acer Computers & Internet
I plugged in a 120gb internal toshiba mk1234gax hdd2d16 hard drive and when turn laptop on it says SMART failure predicted on hard disk. how should i go about fixing this
Try turning off SMART in MotherBoard Settings (BIOS Settings) and if it won't work, Call a Computer Professional. If Warranty is alive, Call Authorized Service Center.
Mar 29, 2014 | Toshiba MK1234GAX 120GB 5400 RPM 8MB Cache...
Acer Aspire 5570 getting SMART failure error on HDD
Definitely a hard drive problem, you'll need to replace the drive and reinstall all the software.
Apr 04, 2010 | Acer TravelMate 507T Notebook
Smart Failure Predicted on Hard Disk 4
Are you sure you don't have a usb or other device plugged into your computer. Your main hard drive should be disc 0. Disc 4 is usually a disc further down the line, like an external or something like that. If it indeed the case then you may be having a problem with the boot in your primary drive. Try booting the disc with a windows installation disc. load the dosc and boot, when it says so, hit any key to boot off cd. When windows loads, hit repair this installation. It will reboot when it is ready. If that doesn't take care of it, reload the disc again and try to restore the drive to an earlier time, like a day or two ago. If this doesn't work, you may have to get another hard drive and reload the system. Don't get rod of the other hard drive though because you may still be able to access the personal files off of it as long as it hasn't had a mechanical or electrical problem keeping it from spinning.
Sep 13, 2009 | Dell Inspiron 1501 Notebook
Hard Disk Problem
That failure is predicted by the SMART reporting system. Its a status chip on the drive that reports to apps that can read the smart data from the hard drive. Its not always accurate but it usually is.
Time backup your data on that drive ASAP and then buy a new drive.
Sep 07, 2009 | Toshiba MK1637GSX 160 GB IDE Hard Drive
Smart failure predicted on hard disk toshiba mk4025gas ( pm )
This means your hard drive is bad or about to go bad and needs to be replaced. If you can still access the drive, immediately back up anything important to you. You will then need to replace the hard drive. Thanks and please take a moment to rate this solution with a fixya rating, even if the news isn't what you wanted to hear. Thanks! :c)
Feb 14, 2009 | HP Business Notebook NX9110 Notebook
Acer 1642 laptop is giving me much trouble. Was working fine until, fapoot... now i receive a message: SMART failure predicted on hard drive 0:ST6100825A-(PM), please help if you can
A SMART failure means that your hard drive is predicted to fail
soon. Fortunately these warnings are not right 40%-50% of the time. Go to the command prompt (start- run- type in "cmd")
In the prompt type in "chkdsk"
This will run tests on your hard drive and tell if there is anything wrong with it.
Dec 28, 2008 | Acer Aspire 3610 Notebook
SmaT FAILURE PREDICTED ON HARD DISC
okay you have seen that message simply because it did not detected any hard-disk. If you know how to open your computer all you have to do is press all the wires in there it maybe dew to loose connection. then try booting it up again be sure it has a system already. If still didn't work out no other solution but to replace the hard disk.
Dec 14, 2008 | Toshiba Satellite M30X Notebook
When you turn the computer on it says SMART Failer predicted on hard disk 0: HTS54108G9SA00-(S1)
S.M.A.R.T. (Self-Monitoring Analysis and Reporting Technology) is a diagnostic method originally developed by IBM that at that time referred to as "Predictive Failure Analysis". This technology was developed for IBM mainframe drives to give advanced warning of drive failures. Based on this diagnostic, Compaq announced IntelliSafeTM, which was submitted to the ATA/IDE standards committees and the resulting standard was named S.M.A.R.T.
S.M.A.R.T. analyzes many of the mechanical attributes; over time, some failures can be predicted by detecting if the hard disk drive is moving out of tolerance. While the S.M.A.R.T. technology can detect upcoming issues, not all hard drive failures are predictable.
All this means on most modern drives is the hard drive is coming close to the maximum tolerances
I usually switch off in the bios smart monitoring.
This system is trying to predict a possible failure, which may or may not occur..
Mar 30, 2008 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
