Question about Garden
How do i adjust the governor on a kohler k17qs the engine dies under the mower load
SOURCE: I have 16 hp Craftsman riding mower with a Kohler engine.
It may think you are in reverse and is killing the motor to keep you from backing up with the blade running. Look for switch that is telling it when you are in reverse, maybe it is stuck with grass or other debris. another possibility is that the blades are jammed and they are stalliing the motor. Mines stalls easily when cold.
Posted on Mar 12, 2009
SOURCE: Weird under load symptom briggs 17.5
a couple other checks would be to dump the carb resevoir where the float is, water under the float could be accumulated and closing the fuel off, due to density. out here on the farm we never use the gas to the last drop from the can. also the linkage between the motor fan blade, (govenor) might have been connected to the carb incorrectly. or a bad switch interlock on the mower blade.
some briggs motors are hooked wrong straight from the factory, where the throttle linkage is concerned. ( and the little spring is pretty hokey too)
Posted on May 17, 2009
  • 13 Answers
SOURCE: 2 mowers 19.5 hp and 27hp kohler, both die when you let off brake
Sure sounds like an elusive safety switch to me. There's usually one on the seat, the blade control, and the brake.
Posted on Jun 04, 2009
mowerman1857
  • 389 Answers
SOURCE: Engine revs wide open when starting
Check to see if the throttle shaft on the carburetor is actually moving (with engine off) Does it slow down when you move the throttle control on the dash?
Start it up and try moving the linkage on the governor shaft, if there is little or no resistance but the engine slows when you move it, most likely you have a broken governor gear inside the engine. Another possibility is that the screws that hold the throttle plate to the shaft have come loose and the plate is jammed in the throat of the carburetor
Posted on Sep 14, 2009
backwoodsctr
  • 169 Answers
SOURCE: Kohler engine carburetor adjustment on John Deere Model 112
When u adj a kohler carb you adj fuel not air. Always adj the high speed then low speed. Then adj the curb idle. 1.5 turns out is a good starting point. Then tweak it after its warmed up. Hope this helps
Posted on Nov 20, 2009
How do I adjust the governor on a 2009 Kohler Courage 20 HP engine?
loosen the pinch nut for the gov arm. have throttle at full. rotate the gov shaft in the same direction that the arm is for full throttle and tighten the pinch bolt.
Jun 06, 2016 | Garden
Honda Gv 100 works well if grass is short to medium loosing power with high grass any idea
Patrick, Ensure mower has good gas, good spark plug,Is the blade good and sharp. Clean any dirt, grass etc, form around the carburetor and governor linkages. It is possible the governor on engine may need adjusted, or spring off or a dirty carburetor needing cleaned internally. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Governor Adjustment and How They Work Honda Briggs Tecumseh Kohler etc
How Small Engine Governors Work any governor setup
honda governor adjustment Google Search
Apr 07, 2016 | Honda Garden
Kohler V-Twin (624 cc) RPM on the engine does not stay stable , It will raise and lower the RPM in any Throttle Range. Could the Governor be going bad???
Try a static governor adjustment first as it simply be out adjustment.
Static Adjustment Procedure
Make this adjustment whenever governor arm is
loosened or removed from cross shaft. Adjust as follows:
1. Make sure throttle linkage is connected to governor
arm and throttle lever on carburetor.
2. Loosen nut holding governor lever to cross shaft.
3. Move governor lever toward carburetor as far as it
will go (wide open throttle) and hold in this position.
4. Insert a long thin rod or tool into hole on cross shaft
and rotate shaft clockwise (viewed from end) as far
as it will turn, then torque nut to 6.8 N·m (60 in. lb.).
Aug 23, 2014 | Garden
Toro 52" deck with 19hp kawasaki engine runs fine when not under a load, when blades are engaged the throttle constantly goes up and down. I am assuming it is a governor problem, and have made sure the...
Could also be a carburetor issue, remove air filter and make sure that its not clogged, even try running it for a short time under the same load. If problem persist tske it to rdpair shop bc there are several other issues it could
Aug 19, 2013 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Do you not know how to reset governor
go to youtube they have videos on how to adjust governor
Apr 14, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I HAVE A CRAFTSMAN KOHLER THAT WILL RUN WHEN
the foat could be plugged or not alowing enough fuel to get into carb.
Jul 08, 2010 | Craftsman Garden
Governor shaft doesn,t react to engine speed,
THE GOVERNOR GEAR MY BE SHOT IN THE ENGINE
Sep 21, 2009 | Garden
Craftsman lt 1000 wont stay running
Take a paperclip and clean out the small hole on your gas cap. And yes I am being serious.
Jun 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
