Question about Refrigerators
GX5FHDXVB03 Our Whirlpool Gold (French door bottom freezer) is pooling (and freezing) water at the bottom of the freezer. The ice sheets form more slowly when the ice maker lever is "off" leading us to think this is an icemachine issue. Any ideas?
SOURCE: water pooling and freezing inside bottom freezer
I had the same problem with my LRFC25750 and have finally figured out what's happening! The water that is pooling and freezing on the bottom of the freezer is definitely coming from the defrost cycle. It is pooling inside the freezer compartment because the drain inside the back of the freezer intended to carry the defrost water down to the external evaporator tray underneath is blocked with ice. As a result, the defrost water from the coils overflows the collector under the coils and runs down the inside back of the freezer, pools on the bottom, and re-freezes when the cycle is over. this continues until there's so much ice on the bottom that the water from next defrost cycle runs out on the floor. The "easy" solution is to unplug the unit and let it completely melt out (this could take 24-36 hours). I couldn't wait, so I removed the freezer drawers and their tracks and pulled out the back panel inside the freezer -- saw the ice in the collector and blocking the drain and I melted it away with hot water and verified that water could now flow down to the external evaporator tray. Unless you want to do this, I'd say give it a good 24-36 hours for all the ice to melt away. I think it all started when we left the freezer door ajar for a whole day and probably had a lot of frost build-up on the coils. The next defrost cycle was not enough to clear all the frost and things began to build up from there. Once the drain is frozen, though, you're finished -- the defrost heater doesn;t reach down that far and you have to melt it down completely or it will continue to leak forever. I've heard that you can get a drain heater to ensure that the drain never freezes over or at least so that it is sure to clear with each defrost cycle. I'll post an update if I locate one.
Posted on Sep 03, 2007
SOURCE: Water/ice pools in bottom of freezer
The real problem is that the drain which carries the defrost water away from the coils (and down to the external pan underneath where it should evaporate) has become plugged with ice (from having left the door open thereby icing up the coils and the drain). The problem you have now is that the normal defrost cycle was not designed to melt the ice plug that is blocking the drain. Solution: You have to either (1) if you're handy, you can remove the plastic panel over the coils in the back of the freezer and melt it out with a hair dryer or hot water -- or (2) unplug the unit, leave the doors open and let it melt out by itself. I don't know how long you'd have to wait for (2) to completely melt the ice plug -- I'm guessing at least 24-36 hours to be sure. I did (1) and it took me about 2 hours to remove the freezer bin and door, remove the main drawer slides, remove the internal drawers and their slides, remove the back inside panel, find the ice plug (lower left side of the drip tray under the evap coils), melt it out with hot water from a baster, verify that the drain was clear, reassemble in reverse order. But it worked. Problem completely solved -- no water since. By the way the drip tray was completely full of ice - right after a defrost cycle had completed -- so this problem will never resolve itself without intervention. Bear in mind, the whole cycle COULD happen again if the drawer is left open again and the excess ice builds up on the coils again. This is a design flaw in the unit itself. However, I read about a clever solution to prevent a new ice plug forming as a result of the open door. Just loop a length of 10-12 gauge bare copper wire around the defrost heater element and insert the other end of the wire in the drain hole. Heat conducted through the wire during defrost will clear any ice plug that may form.
Posted on Sep 09, 2007
aborcass
  • 2651 Answers
SOURCE: Excessive Frost and Ice Build up in Freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 20, 2008
  • 1073 Answers
SOURCE: Ice maker is not working
if you keep your hands out of the little beam slot on the paddel that is located on the left of the freezer and push it in the beam should shoot across to the reciever on the right and the light should stay on constant, that is if you have the switch on the right side turned on.
if it is turned on and the paddel is depressed and the light is still blinking the you need a beam kit part number 4389102
Posted on Apr 12, 2008
SOURCE: leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
Posted on Jul 03, 2009
Water pooling and freezing in lower freezer, whirpool gold french door? How do I rmove liner in fridge to follow line?
Sounds like a clogged drain. Remove food, remove bins and shelves. Remove ice maker if freezer is in the bottom. Remove back panel. .melt ice on drain pan and run hot water into drain.
Feb 14, 2015 | Whirpool Refrigerators
Ice is accumulating at the bottom of the freezer. I have a French door, bottom freezer whirlpool,gold.
Probably a clogged defrost drain overflowing during defrost cycle and then freezing.
Jan 29, 2015 | Refrigerators
I have a GEmodel GFSF2HCYAWW french door bottom freezer model. The ice maker seems to not be getting cold enough, resulting in drippin water that freezes all cubes that do form into one huge clump o
Sounds like your water inlet valve is leaky. Go to repairclinic dot com AnD type in your model number. they will have a fixit kit with all the icemaker gear in it for the big bucks, as well as the individual parts separately. Check that your fill hose has not failed or that the icemaker mech assembly is not cracked or broken.
Jan 12, 2015 | GE Refrigerators
Water under fridge sometimes
You may want to remove all the food, unplug your fridge, and the out the whole thing...melting the ice and cleaning out all the unwanted water. The drawer will be removable, and you can dry under it. Also check the overflow tray under the fridge, if there is one...it'll be full from all the melting.
Jan 24, 2014 | Whirlpool GX5FHTXVA Bottom Freezer French...
Water leaking from whirlpool gold refrigerator
When refrigerators leak water it usally is a sign that the defrost drain found inside the rear of freezer and behind the rear panel of freezer has become clogged with ice or gunk. Sometimes the pan below refrigerator has a crack and allows water to leak onto floor. Please click here=> Leaking Refrigerators Just What may Be HappeningYou will at times see water build up inside freezer bottom especially on bottom freezer refrigerators. This will take a little reading over to understand what may be happening. Click Here=> Leaking Refrigerators
I will be here should you have questions, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Hi I have a 1 year old Whirlpool french door refridgerator bottom freezer with ice maker. A couple of days ago I noticed a thick sheet of ice that formed on the bottom of the freezer. I cleared the ice...
Hello there,
When your refrigerator begins to have ice at the back, it is known as ice build up. There is no leakage anywhere, it is just that there is a component or the other that is being faulty inside the unit of the refrigerator. The defrost unit is where the problem is from.
The defrost process is done automatically and the process involves the defrost thermostat, the defrost heater and the defrost timer. Once one of them or more becomes faulty, ice will begin to form at the back of the refrigerator.
You will have to test the defrost timer, defrost heater and defrost thermostat in order for you to be able to tell which is faulty and need to be replaced.
You can go through these tips if you intend to fix this yourself. Defrost thermostat http://www.fixya.com/support/r10513592-test_defrost_thermostat http://www.fixya.com/support/r10513650-replace_defrost_thermostat defrost heater http://www.fixya.com/support/r10523771-test_defrost_heater http://www.fixya.com/support/r10523754-replace_defrost_heater defrost timer http://www.fixya.com/support/r10523722-test_defrost_timer http://www.fixya.com/support/r10523742-replace_defrost_timer
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | Whirlpool GX2FHDXVD (22 cu ft) Bottom...
Samsung rf265 series french door with freezer drawer on the bottom: Water collects under the veg drawers in the refrigerator part. What might be wrong?
I have the same problem!!! We need a class action lawsuit against Samsung for this problem on their French Door fridge. Instead of fixing it they want the consumer to pay for repair. NO MORE SAMSUNG PRODUCTS FOR ME!!!!!
Sep 04, 2011 | Samsung RF265AA Bottom Freezer French Door...
We have a whirlpool gold bottom freezer refrig. that has been leaking moderate pools of water on each side of the refrig. It also has ice that forms on the floor of the freezer behind the baskets. We took...
Do you have a thin layer of ice in bottom of freezer? If so, its a clogged drain - drain located "behind" back wall in "freezer" side (bottom).
If not, may be a broken or leaky water line or water valve - best serviced by an appliance repair technician... GL
Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC - Refrigerator repair Houston, Katy, Spring and Woodlands, TX!
Aug 29, 2011 | Whirlpool GI7FVCXWB (27 cu ft) Bottom...
I have a Whirlpool Model EV 200N Upright Freezer which is having ice freeze on the bottom of the freezer. What can I do?
If there is frost forming at the bottom to the door, your door gasket is leaking at that location. You may be able to relax gasket back in place with hair dryer, be carefull you can melt gasket. If it is sheets of ice, your defrost drain may be frozen
Aug 28, 2010 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Nov 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
