Question about RCA P52926 52" Rear Projection Television
Spider on screen
There is a spider crawling around on the inside of the plastic shield. How do I get it out?
  • 398 Answers
You must remove the top back cover, but be careful and handle it gently because the mirror is attached to the inside of that cover. When the cover is removed you will be able to clear out any spiders, spiderwebs and dust and be sure to clean the 3 lenses on top of the 3 picture tubes.
Posted on Aug 09, 2007
What is crawling in SEO?
Crawling is the process performed by search engine crawler, when searching for relevant websites on the index. For instance,Google is constantly sending out "spiders" or "bots" which is a search engine's automatic navigator to discover which websites contain the most relevant information related to certain keywords.
So there are basically three steps that are involved in the web crawling procedure.
First the search bot starts by crawling the pages of your site.
Second it continues indexing the words and content of the site.
Third it visit the links (web page addresses or URLs) that are found in your site.
When the spider doesn't find a page, it will eventually be deleted from the index. However, some of the spiders will check again for a second time to verify that the page really is offline.
The first thing a spider is supposed to do when it visits your website is look for a file called "robots.txt". This file contains instructions for the spider on which parts of the website to index, and which parts to ignore. The only way to control what a spider sees on your site is by using a robots.txt file. All spiders are supposed to follow some rules, and the major search engines do follow these rules for the most part. Fortunately, the major search engines like Google or Bing are finally working together on standards.
Techment Technology End to EndSoftware and app solutions
Dec 28, 2017 | Computers & Internet
Yellow spiders crawl up inside front window, from defrost vents w/ spider webs. for couple years.
If it's coming out the vents it means that it made a nest somewhere so best and easy option would be to try and use a insect repellent and spray it down the vents or u will have to remove the blower or dash even if the problem persist
Jun 22, 2015 | 2011 Hyundai Sonata
Burnt smell bits of plastic found inside
A WM1814CW does not have a built-in water heater, so I think your
load may have gotten trapped between the spinning tub and plastic
front tub cover..Roll back the gray gasket to expose and check the
plastic ring for signs of 'friction' burn..As long as the splinters are
trimmed away and doesn't leak water you should be OK..Watch your
loads..Don't Overload!
Aug 18, 2014 | LG WM1814CW Front Load Washer
Something inside the drum
if it is a nut or coin it would come out the sump if it is not a coin or nut it might b a bra wire if not id look at a rolled up sock in beetween drum and outet drum , u might have worn bearings or the spider might have a crak in it that is what holds drum up what make is it
Apr 15, 2014 | Washing Machines
Accelerate and noise on driver side sounds like flapping wooshing underneath car
Most all cars nowadays have several plastic water shields fastened under the front of the car.
I believe one or two of those black plastic shields is rubbing one of your tires, or a pulley or some other moving part.
Someone is needing to crawl completely under the car to find this out. Those shields are important, but if one or two is damaged,
removing them should not hurt anything.
Jan 13, 2013 | 2004 Lexus ES 330
How to replace driver door lock cylinder
You have to work from inside the door, so pull trhe inner panel off and the plastic water shield. Unclip the rod from the lock, pry off the lock retaining c-clip, and install new lock cylinder. When done, use new adhesive if necessary on the water shield, and then the inner door panel back on. The panel will be held by several screws, and plastic pins around the perimeter. After screws are removed, slip a flat blade under the panel to pop out the plastic pins, one by one.
Oct 13, 2012 | 1992 Nissan Pathfinder
I have a 1990 alero oldsmobile and tried changing the fuel filter the other day. I took it in and borrowed the tool used to compress the latching tabs on the filter but there is a plastic shield or...
CAREFULLY USE A LONG SMALL FLAT HEAD SCREW DRIVER.OPEN THE PLASTIC SHIELD.TAKE SCREW DRIVER STICK IT IN THE SHIELD PUSH IN CAREFULLY TO DISENGAGE THE SHIELD AWAY FROM FUEL FILTER CONNECTOR.WORK THE FUEL FILTER PULL IT EASY AWAY WHILE PRESSING INSIDE SHIELD IT WILL DISENGAGE WHILE PUSH IN ON SHIELD FROM THE INSIDE.BECAREFUL NOT TO DAMAGE THE SHIELD ON THE FUEL LINE BECAUSE THAT FUEL LINE GOES TO THE FUEL PUMP.
Sep 26, 2010 | 1999 Oldsmobile Alero
Spiders inside my Toshiba DLP TV.
This is an interesting problem. I'd say the most inexpensive bet is to place some spider traps outside the Television and let the sweet scent attract the spiders. It might work over the period of several days. More info here: http://hubpages.com/hub/Spider-Traps
Aug 16, 2009 | Samsung HL-P6163W 61" TV
My subaru forester has a rattle in the catalytic converter can it be repaired
I bet its just a the heat shield on the catalytic converter. Subaru uses very thin metal and the heat shield is bolted as opposed to welded together. This rattle is extremely common on subys.
mrmopar is right that you should replace it.
however there is a quick fix that will stop the noise. Go pick up a 6" stainless steel hose clamp at the hardware store. put the hose clamp around the cat. It should be obvious whats loose when you look under the car.
if you are a little handy its not a hard job to do your self. Just 4 bolts. You can get a catalytic converter for $200 online. Get the gaskets too. shouldn't take more than an hour or two.
You will need to put the car on jack stands or rhino ramps to get access. Once you are under the car, the parts are easy to get to.
Always, always chock the tires when your under the car. You do not want a car to fall on you.
Apr 21, 2009 | 2002 Subaru Forester
My mocrowave fell and the front plastic on the door broke. The inside is not affected. Is it safe to use the microwave
The front plastic bezel on the door does not provide any shielding from the microwave energy inside the cooking compartment. As long as that is the ONLY damage and you haven't compromised the door, door frame or protective gasketing around the door opening then you should be safe.
Sep 14, 2008 | Microwave Ovens
RCA P52926 52" Rear Projection Television Logo
517 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
