Question about Welding Tools
My millermatic mig welder won't turn on - Welding Tools
5 Suggested Answers
  • 3 Answers
SOURCE: mig welder tripping power supply
the breaker could be bad. try to change the breaker
Posted on Jan 16, 2009
luxur4
  • 92 Answers
SOURCE: mig welder powers up but only clicks when trigger is squeezed
1] Remove the power cable from the power. (socket on the wall) remove the top cover there should be a fuse located on the wiring panel.
2] perform all your house keping- like, all plugs and socket are tight, the correct contact tip with the the right wire size, roller/s are also the correct ones for the wire size and are turning if they are turning but not feeding the wire, then, the rollers need to be tightend , get back to us.
Posted on Jan 23, 2009
  • 19 Answers
SOURCE: Clarke MIG welder parts??
what model is your clarke? i have a 125en which is the exact same welder as a craftsman, you could probably get a new feed motor or other parts for the welder itself from sears, the gun is a tweco style gun same as lincolns, so if you need tips or anything you can get those just about anywhere welder stuff is sold. i hope i helped.
Posted on Apr 22, 2009
  • 105 Answers
SOURCE: SIP turbo 150 mig welder instructions wanted
for welding cars or similar thickness steel use it on number1 setting speed 6-7 and practise max and min should be used when you want a bit more power A gose onto number 2 and then 3 these are amp settings and are for thickness of steel to be weled your welder can weld up to 8mm of plate steel on setting 3 max i use 0.9mm gasless flux cored wire great for working out doors the wind tends to blow gas away on standard wire yours is easly converted to gasless as so was mine
Posted on Dec 15, 2009
What make & model mig gun is fitted to this machine
Mig Guns & Mig Gun Spares - The Welders Warehouse
www.thewelderswarehouse.com/Welding/Mig-Welder-Gun.html
We have Mig Guns and spares to suit a wide range of Mig Welders. ... Torches are usually Euro Fitting and are typically fitted to professional mig welding machines of ... attitudes from people one is giving money to ! its great to get good service.
[PDF]POWER MIG ®(140, 180 MODELS) - Lincoln Electric
www.lincolnelectric.com/assets/...public/.../im890.pdf
Lincoln Electricshipment must be made by the purchaser against the transportation company at the time the shipment is received. SAFETY DEPENDS ON YOU. Lincoln arc welding and cutting equipment is designed and built with ... properly fitted and with proper grade of filter plate .... Semiautomatic DC Constant Voltage (Wire) Welder.
Millermatic® 211 MIG Welder - MillerWelds
Dec 20, 2015 | Welding Tools
Can a millermatic 35 mig welder be changed to use fluxcore wire ?
with flux core wire the torch is supposed to be negative but there are people using the fluxcore without changing polarity.
its as simple as swapping the polarity to the torch and and return clamp
Feb 15, 2015 | Welding Tools
Ak matic 1200 welder
Akmatic 12000 is a Millermatic 200
Akmatic 1250 is a Millermatic 250
May 24, 2014 | Miller Welding Tools
Can I run a millermatic 252 mig welder off of a ranger 305 g auxillary power outlet?
not sure what a ranger 305g is but a mig welder of that size would require an output of at least 10kva from a generator maybe more due to the start up current
Oct 27, 2013 | Welding Tools
Our MillerMatic 175 wire feed cannot be adjusted down enough. The rheostat seems to function, but even the lowest setting is now way too fast.
Your Millermatic 175 has syncronize wire speed-voltage feature in order to reduce the wire speed first reduce your heat (voltage). Try again.
If this was useful to you please vote. thanks.
Feb 10, 2011 | Miller MATIC 180 MIG w/cart/AND SPOOLMATE...
What mig welder would you I buy to restore a old car.
I always tell my customers that the best machine for a body shop is a millermatic 212 if you have 220V available if not, go to a Millermatic 211 this is one is a dual voltage unit 110V/220V. if you can afford it buy a spool gun SG100 for all aluminum parts, the machine will cost you 999.00 and the spool gun 215.00. Best investment ever for your shop.
Oct 28, 2010 | Clarke Power Products Clarke 130EN Mig 110...
Welding Tools Logo
73 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
