Question about Vacuums
Sunbeam S-4C iron
Need to replace the cord
Iron will not heat up
See the causes and proceed according, fix it. God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord. Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
Sep 23, 2012 | Unknown LAURASTAR PREMIUM S3 Ironing...
I NEED A MANUAL FOR SUNBEAM GCSBRS 101-000 CONVERTIBLE STEAM IRON
Hi there.
You can download Owner's Manual at http://www.sunbeam.com
Regards.
Jul 14, 2011 | Vacuums
I need to replace the plug in cord on my rowenta iron. I would replace but I paid $130 for iron and my cats have chewed on the cord so I thought it "might" be a simple replacement.
This is the second cat-chewed-a-wire question tonight.
The only thing to do is to replace the entire cord. You could cut out the chewed section and splice it with **** connectors and electrical tape, but you have a nice iron with a 12' cord. I believe Rowenta uses Torx screws on their irons.
Rowenta has customer support and a list of service centers online:
If you are in the U.S., go to:
http://www.rowentausa.com
and then click on the 'CUSTOMER SERVICE' link on the gray bar below center of the page.
In the 'After Sales Services' column, click on 'Service Centres' and look for one close to you. Perhaps you can order a new cord and use the old cord as a chew-toy decoy.
Good luck from Detroit, MI.
Jul 11, 2011 | Vacuums
How do i clean my iron so brown dirt won't come out of it when i iron
Brown water and white scale are often the result of the water you use in the iron...
If you have scale, white vinegar will clean that...
For brown water, empty the iron, rinse out the insides with bottled water,
and then use the bottled water instead...
Also check out this tip...
Cleaning a Steam Iron White Scale and Brown Water
heatman101
Mar 23, 2011 | Sunbeam Vacuums
The cord on my iron is worn at the swivel near the base and at the plug...can this be replaced since this is such an expensive iron...thanks for your help.
sure it can, first find the teg on the iron that shows the power rating. Then just go but a cord with compatable rating
Mar 10, 2011 | Vacuums
How to clean sunbeam ultra 60 platinum iron. Can't find instruction booklet!!!!!
Do you mean the Sunbeam Ultura 60 Platinum iron? Wipe the exterior of the iron with a damp soft cloth and then dry the iron. To clean the steam valve, turn the Steam/Dry dial to Clean so that the tip pops up. Gently scrub the tip of the valve with a steel wool pad moistened with warm water. Rinse and dry with a soft cloth. Replace the valve and turn clockwise to lock into place (reset the dial to Dry when storing the iron). Clean the steam holes of any build up, use a cotton wool tip moistened with methylated spirits. The teflon plate should be cleaned with the damp soft cloth, just like the rest of the exterior of the iron. If you have ironed a polyester that melted onto the iron, then iron a damp cotton cloth when the iron is hot.
The manual for several Ultura irons, including the 60, is available here: http://www.sunbeam.com.au/Pages/Browse/ProductDetail.aspx?pid=1485 . The link for the manual is in the center of the page above the Image Gallery.
I hope this helps.
Mar 06, 2011 | Sunbeam Vacuums
My Sunbeam Pro Stream II Teflon shot and spray iron consistently spits water as I try to iron. I don't overfill it and the temperature and steam dials are set correctly. help!
How old is the steam iron?
And what type of water have you been using in it during its life?
The reason I ask, is that my Wife's was doing this, and we have fairly 'hard' water,
and she was using water directly from the tap.
After a year or so of this 'hard' water, calcium and minerals build up in the heating chamber in the iron-- Also passageways get clogged, and instead of smooth flowing steam, you get build-up of pressure, and then sputtering and spurting take place, as the clogged passageways try to pass the steam to where it needs to be.
Tell us more--
Mack B
Dec 28, 2010 | Vacuums
I need a replacement cap for the water tank Sunbeam humidifier model swm5251
Official instruction from this device suggests to call Sunbeam consumer service at 1-888-264-9669 to order replacement accessories.
Nov 28, 2010 | Sunbeam Vacuums
I have a Euro Pro Compact Performer model # EP 171 which I love. It is the best iron I have found for my quilting class. When I went to use it, I found my cats had chewed the cord to the point that it is...
HI. All appliances has warranty on it. Default would be 1 year warranty. If your device is within the one year warranty. you can have it repaired by your manufacturer withut a charge. If device is alraedy out of warranty. you can still have it repaired but you will cover for the damaged part that need to be replaced or repaired in your device. Check the store where you purchased the unit. Maybe they can do something about it.
Jul 01, 2010 | Euro-Pro Vacuums
Vacuums Logo
21 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
