Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
Engine surging I have a John Deer 175 Hydro Lawn Tractor. Had it tuned up for the year locally (not dealer). Ran fine for about 2+ hrs. It still starts fine and runs for 10-20 min. then starts to surge. I have drained the gas, cleaned out the carb bowl, and tried to clean the float needle without removing it. The is some grit in the fuel filter that appears to be on the outgoing side of the fuel filter. Any ideas?
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 104 Answers
Check the vent hole in the fuel cap.
Posted on Sep 25, 2017
    Loyalty:
    Visited the website for 30 consecutive days.
  • Tecumseh Master
  • 1,421 Answers
Drain the gas replace fuel filter then see if that helps if not clean the whole carburator should stop it.
3 Suggested Answers
SOURCE: mower surging
let it surge, it will usually get better as it warms up. These 6.5 Hp engines are fine except they have an cheap badly designed carburator. Nothing can be done about this problem. They all surge eventually.
Posted on Jun 16, 2009
  • 66 Answers
SOURCE: 13 hp tecumseh riding mower won't start unless gas is poured into carb. removed the bowl from carb has a wire snap holder float and needle and seat works OK and all passageways seem to be clean
hi
remove the bowl again and get the centre jet out and lok very closely use a jewlers eye piece you wll find a passage that is plugged on the side of the jet look around it you ll see some sign of a hole that is not clear through its pretty small use a welders torch cleanng tool with various size rods use very thin one dont make the hole bigger
Joe
Posted on Oct 10, 2012
Testimonial: "thanks for the ideas on fixing my problem I'm going over to my neighbors on Sunday and I'll try out your suggestions thanks again Al"
John Deer 175 hydro garden tractor, Kawasaki FC420V engine wont crank when key is turned. Stopped cranking yesterday. Previously on occasion had to turn key on and off a few times to crank.
bad starter or bad ignition switch. try putting it in gear and rock it back and forth, if it starts then you have a dead spot in the starter.
Jun 11, 2017 | kawasaki Garden
Keep burning up deck belts on 20yr old John Deere rider rx75. What size belt should I be using
1/2 x 60
Check all deck idler pulleys and make sure no bad bearings or flat spots
Apr 24, 2015 | John Deere Garden
JD 4310 tractor hydro problem
Jeff I am having the same problem. Have you found a fix for this yet? your post is right on but for some reason we are the only two withthis problem and my local jd dealers have never seen this. , Brent
Jun 16, 2012 | John Deere Seat 4210 4310 4410 4510 4610...
John Deer L130 lawn tractor: Start with jumper on solenoid.
i would check the safety switches you can jump them and find the bad one
Mar 28, 2012 | John Deere Garden
I have a 21 year old john deere 175 hydro lawn tractor with a 38 inch deck and it needs a new motor and a new swith to engage the lawn mower deck how much is it worth with those being broke ?
Trans 150$.Mower deck 50$.Hood 50$.Fender deck and seat 75$.Front axle and spindles 75$.Electric clutch 40$.This is what you can expect to get if you part it out or you can trade it in for 250$ on a new Deere.
Mar 21, 2010 | Peg Perego John Deere Turf Tractor
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
88 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
