Siemens s1676 f23 - Washing Machines
2 Suggested Answers
  • 154 Answers
SOURCE: I have a siemens WM14S794GB washing machine and F23 is flashing
F:23 means that your machine is leaking and should be repaired. This is often a bad seal and if you are competent or know a friend who is they can inspect the source of the leak for you. Needless to say you should make sure that you unplug your machine before attempting any repairs.
Hope this helps you.
Posted on Jun 22, 2010
Siemens front load washing machine. Cloth stuck between the door and the panel. Can't open the door. F23 appears.
the tub beneath the washer is full and is not draining. the clothes have probably opened up the seal between the door and washer allowing water to leak. tip the machine and empty the sump to clear error.
Jun 09, 2016 | Siemens Washing Machines
Nevers stops...
check your pump is not worn (how old is it)
or
check your brushes
Jan 12, 2014 | Siemens Washing Machines
F 23
The meaning of the code depends on the machine's manufacturer.
On Siemens built machines (Siemens, Electrolux, hotpoints etc.) F23 Means that there is overflow and anti flood device has been activated.
In this case:
Disconnect power.
Remove all water at the base of the machine.
Take off the rear panel, or access the drain pump from front door(depends on model).
Check drain hose height and check hose connected to drain pump.
Connect power back.
If problem does not clear after connecting back, replace pressure switch.
With Wirlpool built machines instead (Whirlpool, Maytag, Kenmore etc.) f23 means there is a communication within the CCU and the MCU.
CCU is the main control module (central control unit), and MCU is the Motor Control Unit. MCU is a sealed module located deep inside the appliance, and connected on one side to the motor, and on the other to the CCU. Testing F23 on a Whirlpool is more difficult and requires a technician. In this case all you can do is disconnecting power, if error does not go away call the service number listed on manual.
Regards.
Ginko
May 19, 2011 | Washing Machines
The washer is flashing F23 and won't run. Why?
Hi
F: 23 means that your machine is leaking and should be repaired. This is often a due to a bad seal.You need to unplug your machine to check for any leak.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 01, 2011 | Siemens WE61021GB Front Load Washer
Sep 11, 2009 | Siemens WM14S794GB Front Load Washer
F23 error
Your washine machine has sprung an internal leak and is leaking water into the base pan, this should be checked by a competent repair person.
Jun 14, 2009 | Siemens WM14S794GB Front Load Washer
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
