Question about Craftsman 25cc Gas Line Trimmer
Why won't the trimmer head spin
The model 316.791190 trimmer starts with one pull. the trimmer head stopped. no noise or grinding. suggestions
3 Suggested Answers
  • 6468 Answers
SOURCE: I replaced head gasket on my craftsman 18.5 rider
does it spin like these no compression?did you adjust the valves the right way?did you short out the kill switch wire that goes to the coil?did you leave aground wire of that grounds out the solenoid on the bottom of the carb?this should get you started let me know if you need more direction
Posted on Apr 28, 2012
  • 6468 Answers
SOURCE: grinding noise and then stop working, wont start
can you turn the engine by hand?is there any oil in it?is there metal in the oil?
Posted on Jul 13, 2012
STIHL WEED TRIMMER
With the plug removed the starter should pull very easily. When trying start did the cutter head try to spin? If yes clutch springs may need replacement
Jul 24, 2013 | Garden
When I pull the trigger on gas Trimmer the head does not rotate?
sounds like the wire inside the two piece shaft is not making proper contact or that drive wire snapped. loosen the plastic knob and pull them apart then push the two pieces back together again. if it still doesn't spin, listen for a rattling noise somewhere inside the shaft, it could be a break.
Sep 13, 2012 | Troy Bilt Tb70ss Gas Trimmer
Ryobi 975R head won't stop turning.
sounds like the idde is to high
Aug 06, 2012 | Garden
Grinding Noise from Trimmer
with a strieght shaft trimmer there is a gear at the trimmer head that gear could be bad if it has a arched shaft then its driven by a cable if you spin the head by hand while without it running you might feel some roughness
Jul 28, 2012 | Garden
I have a Ryobi RLT30CESNB whipper snipper. Had it for about a year. The motor starts and runs okay. Just yesterday, all of a sudden, the head stopped spinning when I gave it some throttle. The motor still...
hello,,There are only three things to cause trimmer head not to turn.
1.Outer shaft has sliped down from engine because screw has fallen out and ring has come loose,
2.Shaft has broken due to excess stress,such as putting on a differant trimmer head or binding up,
3.Trimmer head striped.
hope this helps,any comments welcome,thank you.
Jan 05, 2012 | Ryobi Garden
How do I replace the old head with a new one?
Your old head should simply unscrew from the gear box. You should not have to disassemble the head to get it off. Some models have a small hole above the gear box where you can insert a small screwdriver to lock the drive shaft so that the entire unit stops spinning. Keep in mind that some models have left-hand threaded heads while others have right-hand threaded heads. In most cases, you'll unscrew the head opposite of whichever way the head normally turns while you're trimming. This is by design so that the machine doesn't unscrew the head itself while you're using it. You can find replacement heads for most makes and models of trimmers at PartsBuggy.com.
Aug 25, 2011 | Husqvarna 28cc Gas Line Trimmer
Just bought a brand new Husqvarna 224L Trimmer. Started it up and it runs fine. But the trimmer head will not turn. It just makes a grinding noise. The manual that came with the trimmer is useless. It says...
Hi, take it back to the dealer as the powered or gear box have not been fitted correctly. The noise you can hear is most likely the clutch drive grinding on the drive shaft. Hope this helps, regards Phil.
Jul 21, 2011 | Husqvarna 28cc Gas Line Trimmer
Craftsman 25cc Gas Line Trimmer Logo
19 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
