Question about Dell Inspiron Computers & Internet
Me aparece a hard disk is preventing windows from starting
3 Suggested Answers
SOURCE: windows error recovery on toshiba satellite
Sounds like your hard drive has crashed. You will need to replace it.
You can try to run the Check Disk Utility to see if it can repair the drive.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Posted on May 02, 2012
jadiazq
  • 2878 Answers
SOURCE: windows detected a hard disk problem
It is predictive failure. Start backing up your files and replace drive. You can also run chkdsk c: /f/r to fix errors on the drive from the command prompt. C being the drive letter or whatever your is.
Posted on Feb 27, 2013
WINDOWS DETECTED A HARD DISK PROBLEM Backup your data to prevent information loss, then contact the computer manufacturer if you need to repair or replace the disk
Feb 27, 2013 | Toshiba satellite c660
Tip
10 reasons why PCs crash-You must know tip 4
4 Hard disk drives
After a few weeks, the information on a hard disk drive starts to become piecemeal or fragmented. It is a good idea to defragment the hard disk every week or so, to prevent the disk from causing a screen freeze. Go to
* Start-Programs-Accessories-System Tools-Disk Defragmenter
This will start the procedure. You will be unable to write data to the hard drive (to save it) while the disk is defragmenting, so it is a good idea to schedule the procedure for a period of inactivity using the Task Scheduler.
The Task Scheduler should be one of the small icons on the bottom right of the Windows opening page (the desktop).
Some lockups and screen freezes caused by hard disk problems can be solved by reducing the read-ahead optimisation. This can be adjusted by going to
* Start-Settings-Control Panel-System Icon-Performance-File System-Hard Disk.
Hard disks will slow down and crash if they are too full. Do some housekeeping on your hard drive every few months and free some space on it. Open the Windows folder on the C drive and find the Temporary Internet Files folder. Deleting the contents (not the folder) can free a lot of space.
Empty the Recycle Bin every week to free more space. Hard disk drives should be scanned every week for errors or bad sectors. Go to
* Start-Programs-Accessories-System Tools-ScanDisk
Otherwise assign the Task Scheduler to perform this operation at night when the computer is not in use.
on Mar 04, 2010 | Computers & Internet
AL INICIAR MI COMPUTADORA DEL INSPIRION 530 APARECE EN EL MONITOR UN AVISO ASI: REMOVE DISKS OR TOHER MEDIA PRESS ANY KEY TO RESTART. QUE PUEDO HACER?
The computer is indicating that something is preventing it from booting to the hard disk drive. Ensure that if the system has a floppy diskette drive, there is no diskette in the drive as the system may be trying to boot to it and failing.
If no floppy or no other Media (DVD/CD) in any drive then the Hard Disk Drive may be having problems and need repair.
(La computadora est? indicando que algo est? evitando que pateara a la impulsi?n de disco duro. Aseg?rese de que si el sistema tiene una disquetera floja, no haya diskette en la impulsi?n pues el sistema puede intentar patear a ?l y a fallar. Si ningu?n disco blando o ningunos otros medios (DVD/CD) en cualquier impulsi?n entonces la impulsi?n de disco duro puede tener problemas y necesitar la reparaci?n.)
more info here:
http://www.fixya.com/support/r3728860-troubleshoot_system_will_not_boot_hard
Jul 24, 2011 | Dell Inspiron 530 Desktop Computer
When I am starting my Lenovo G550,Model Name-20023 it restart with blue scrren. I am trying to start it in safe mode but same problems appears. Then I am trying to format the system with windows XP-2 but...
If you get a blue screen then you have a piece of hardware loose inside your lappy or could be a loose cable on the hard drive or cd/dvd rom, since lappy's are very hard to take apart it's best to take it to a shop to get fixed sorry.
Jul 08, 2011 | Computers & Internet
I want to replace hard disk of my presario v6700, which has a buitin recovery disk from the company. i made recovery disks already. but when i want to install windows from the recovery disk on the new hard...
This error is when you try to use OEM recovery disks with a non OEM hard drive. The company recovery disks will not work, they do this to prevent software fraud. Sorry to say you will have to purchase a copy of windows and start over :(
May 05, 2011 | Computers & Internet
No puedo instalar, hasta hace unos dias estaba instalada. Se desinstalo por error y ahora al introducir el cd de intalacion realiza todo el proceso, pero aparece al final un cartel que dice que no es...
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Feb 04, 2011 | A4tech PK-7ma Flexi Webcam
My startup disk is full and the page is blue...what can i do..?
Start the laptop using the install disk by inserting it and pressing (and holding) the "C" key immediately after you turn on the computer. This will allow you to inspect your hard drive, clear some space and run Disk Utility to verify the internal hard drive.
Once you have a desktop, press command (apple) and "N",
1. Open the Applications folder.
2. Open the Utilities folder.
3. Launch Disk Utility.
4. Select "First Aid" in the bar in the upper middle of the window.
5. Select your laptop's internal hard drive from the list on the left of the window.
6. Select "Repair Permissions" in the lower center of the window. The software will check your permissions files, correcting any errors. This should include the kenell issue that is preventing your laptop from starting.
This may take several minutes, so you can check the capacity of your hard drive to see if it is actually full (simply open the hard drive, the capacity should be listed at the bottom of the window).
If it is full, consider what to remove while permissions repair is underway.
Oct 11, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Tenho um pen drive Dane-Elec de 2 Giga quando conecto na entrada de USB aparece uma mensagen deseja formata-lo, quando digo sim, vem outra mensagen o Windows não conseguiu formata-lo meu...
connect it to PC then... go to My Computer icon on desk top >> right click >> manage >> Disk management >> select ur USB Flash Drive/pen drive >> right click >>format ....ok......
Sep 26, 2010 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
Changed rights in Vista -> Can not change them back! (disk drive)
download active boot disk pro. it is free. run the disk and remove all passwords and start over. :)
Feb 11, 2010 | Microsoft Windows Vista Home Premium...
A hard disk problem is preventing windows from starting.
The black screen with flashing cursor can be caused by the files needed to boot being located in sectors of the hard drive that can no longer be read.
You can try booting to the XP CD, and go to recovery console and RUN CHKDSK /F See if that fixes the file structure and allows the system to boot. If that fails, you can try a repair installation of Windows. If that fails, the most likely resolution is replacing the HDD and reloading Windows and the drivers.
Jan 31, 2009 | Acer Aspire 5520-5908 Notebook
Computers & Internet Logo
20 people viewed this question
Alun Cox
