Question about Whirlpool RBD305PD Electric Double Oven
Rbd305pdb14 error code F5
My control panel was not functioning (was not lighting up but would still beep when pushing buttons....oven did not work). I replaced the control board. The oven now works, sort of. The clock works and the upper oven works, however, the lower oven dose not work. I originally received the codes E1 and F2......but now the only code I am getting is F5. When I push 'lower oven'.....there is no beep at all. There is a chance when I plugged in all of the wiring, I didn't seat one well enough, but I double checked them before I put back together. Any ideas??
  • Official Brand Answer
  • 362 Answers
Dear Valued Consumer, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Dear Valued Consumer), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Posted on Apr 25, 2017
SOURCE: Whirlpool Gold Electric Oven F5 E1 code on bar code
For some reason I get the same error code every time we have a power outage. If you push and hold the "lower off" button for about ten or 15 seconds it will unlock and reset. Hope this helps.
Posted on May 29, 2009
localwonder
  • 6784 Answers
SOURCE: beeping driving me crazy
Ok, the first issue is the oven temp sensor. it is shorted. you will need to replace this device asap. Now, the second is is concerning the Self clean latch. it is not functioning and it is unable to be locked by the control(shorted). Use the procedure below to test this device.
1. If door latched:
1. Disconnect power from unit.
2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
3. Replace door switch.
4. Re-apply power.
5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
blueextc3221
  • 15935 Answers
SOURCE: E1 F5 Error Code RPD-305-PDS14 Whirlpool Double
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$RTYH
Posted on Oct 01, 2010
blueextc3221
  • 15935 Answers
SOURCE: replaced control panel on whirlpool electric
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$RED
burkcs
SOURCE: Whirlpool Double oven control panel
A lot of people seem to have ran into this problem. I had no luck finding a solution to this problem anywhere on the internet. I finally fixed this problem by replacing the control board. Wanted to put this info out here for others. The part swaps out fairly easy for all of you considering the fix yourself. Sears direct had the cheapest price.
Posted on Dec 24, 2012
Error codes/oven functionality
Hi this sounds like the electronic clock has failed. Either replace or bypass possible.
Oct 22, 2017 | Whirlpool RBD245PRS Stainless Steel Oven
Ge oven jkp27 code f5
Hello Donald,
The F5 error code means that the control board has detecteda error within it self and theirfore the control(also called clock or EOC) needs to be replaced. The F5 error code can be cleared by pushing the cancel/off button and if it returns a short time later their is defiently a malfunction inside of the clock and it would need to be replaced.
GENE
Sep 28, 2011 | GE JKP27 Electric Double Oven
What is F5 Frigidaire oven unit, it's beeping and
The F5 ERROR code means that the self check that the control (also called clock)board runs to check itself has failed and the control has detected a problem within itself and the control must be repalced.
Gene
Aug 10, 2011 | Frigidaire Ovens
Self cleaning keeps popping up beeping with F5
Hello,the F5 beeping is all about the Push button stuck.
Check for the binding of Push button and control panel glass.If OK,replace the touch panel.
Thanks
Jun 02, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Getting F7 code on a ge profile performance oven , oven light will not turn off and control panel will not respone.....beeps when I push CLEAR OFF button.
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Try gliding your finger flat across the keypad rapidly and see if you can unstick the key / touch pad. Usually once this code appears it will repeat.
On self cleaning ovens this is the service check:
Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Thanks for using FixYa!
Kelly
Mar 09, 2010 | GE Profile JTP56 Electric Double Oven
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 | Ovens
Jan 26, 2009 | Whirlpool GBD307PDS Electric Double Oven
Unable to clear error message on panel...oven not operating
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#RET
Nov 25, 2008 | Whirlpool SB160PEE Gas Single Oven
Oven failed to work; F5 error message
please tell about the make & serial no. of oven.
Sep 30, 2007 | Ovens
Whirlpool RBD305PD Electric Double Oven Logo
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
