Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Sub-zero 650 / bottom freezer
The desplay is flashing " vacuum condenser " although the unit seems to be working fine. What does this meen?
  • 4 more comments
  • Anonymous Jun 01, 2008
    How do I get the grate off the top of the refrigerator to get into the condenser.
  • Anonymous Oct 25, 2008
    We had the same problem. A "sub-zero certified" technician came, said we needed a new compressor. We are still under factor warranty for parts, but we paid for labor, etc. Anyway, about $1,000 later, we had a new compressor installed, a "leak" identified, and the "vacuum condenrser" off. Now (three months later) we have the exact same problem and the fridge won't go below 41 degrees. We're reluctant to "invest" another $1,000 on this, and are thinking about switching to a more "ordinary" but also more reliable model... any advise?
  • hildib Nov 17, 2008
    I had the same problem with my sub zero 650. I had to turn off the fuse power since the on off just wasn't enough. However, I too had to get a new condensor. You have to vacuum the condensor but I was doing that & it was all clean. I will NEVER get another subzero. The suction on the door doesn't work, the ice maker won't go on & off auto. anymore. My son cut his arm on the sharp edging and just missed his main artery & all sub zero did was come & "file the edge down". I've had too many services on it and now sometimes it runs loud. The suction thing is the worst, they said "to wipe it down" but that's not the problem, it just doesn't suction closed. I liked my GE Profile much better and never had issues with it.
  • laurie k Dec 16, 2008
    I too have the vacuum light and a warm freezer. Repair came last week and said there was a blockage in the line, which they cleared. Next day light was back and unit warm. Now service says I need a new condenser and compressor. the parts are covered but labor($500.00) isn't. Is this unit worth it? It is 8 yrs. old and was a replacement under warranty for a 5 yr. old 550 from sub-zero.
  • thomasr686 Feb 21, 2009
    The desplay is flashing " vacuum condenser " although the unit seems to be working fine. I have vacuumed it a number of times but the light still flashes. The refrigerator is maintaining 34 degrees; the freezer 5 below zero.
  • Anonymous Mar 16, 2009
    refer wont get cold
  • 183 Answers
Clean fluff from condensor, turn off overnight and defrost, turn back on following day should start to work ok within 24hrs. Regards Advisor
Posted on Aug 23, 2007
SOURCE:
My 650 sub zero keeps alerting me to vacuum condenser even after I do so. What should I do?? My condenser is at the top of the frig.
I have found the users manual for this unit, and that my give you more information. Click HERE
Hope this gives you some relief
Joe
Aug 30, 2011 | Sub-Zero 650 / O Bottom Freezer...
When the weather is hot and humid, our sub-zero seems to barely work. Freezer works fine, but the upper part is a joke.
the leading thing causing that is a dusty condenser coil. to clean that remove the grill above the refrig, and the white painted plate behind that and vacuum the coil on right side ,typically the grill is held on by springs and a either 1 screw in the center or 2 screws on the corners of the rim above the door,remove grill by opening refrig. door and remove screw tilt grill down and disattact springs
Good luck, i hope this helps
Gene
Jul 31, 2011 | Sub-Zero 650 / O Bottom Freezer...
Vacuum condenser keeps flashing
Clean the coils, usually at the bottom of the unit, remove the cover and use a vacuum and a bottle brush and clean away, use a crevice tool on the vac. hose but do not force it between the coils.
Jun 26, 2011 | Sub-Zero 650 / O Bottom Freezer...
My 12 year old subzero fridge (650) is not getting cold. this morning i discovered ice behind the fresh food drawer, removed it, it was running fine, temp 35. now tonight the temp is 51. freezer is fine....
Is it flashing vacuum condenser? Ice behind the crisper drawer shouldn't effect the temp. What is it set at? You can go to www.subzerospecialists.com and click on Tech Help for additional info.
Feb 23, 2011 | Sub-Zero 650 / O Bottom Freezer...
Vacuum condenser warning flashes despite my having vacuumed.
unit is running 6 cycles without a defost time...you may have a leak in the evapator have a subzero tech check it if 12yr or younger parts are under WTY
Sep 14, 2009 | Sub-Zero 650 / O Bottom Freezer...
Subzero--Vacuum Condenser Signal Won't Turn Off
The vacuum condenser indicator keeps flashing on and off. I did vacuum the unit, the the indicator lights keeps flashing on and off. How can I reset it and keep it off?
Thanks,
Rob
Aug 22, 2009 | Sub-Zero 650 / O Bottom Freezer...
Vacuum condenser is flashing
this means your condensor on the back of the unit that pumps the freon needs to be vacuumed. It may be dusty or not getting air flow to cool it off. Also vacuum all your coils on back of unit
Jul 11, 2009 | Sub-Zero 650 / O Bottom Freezer...
I have a ten year old Sub-Zero 650. The "vacuum condenser" has been displayed for over a year even though the coils have been vacuumed and are kept clean. The fridge has been working fine despite the...
Look on your sub zero for more model numbers. I have found some information indicating that the refrigerator thermostat may be the problem but need those numbers to confirm. Thanks, Sea Breeze
You can also find a user manual at this link
http://safemanuals.com/zearchres_663.php
http://servicepartstec.blogspot.com/
Apr 27, 2009 | Sub-Zero 650 / O Bottom Freezer...
Vacuum condenser message flashing
Your evaporator needs replacing. covered under 12 yr. warranty parts only.
Jul 25, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
1,052 people viewed this question
Top Sub-Zero Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
louis_benton
Level 1 Expert
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
