Question about General Electric GE Security Digia II DVR
How can I upgrade digia2 ocx - General Electric GE Security Digia II DVR
5 Suggested Answers
SOURCE: I can't access via browser to the Digia II because
I can't access via browser to the Digia II because appears the message: 'Please check the Digia2.ocx installation. Current version is 1.0.0.61.I'm using Internet Expplorer SP2
Posted on Oct 28, 2010
  • 11800 Answers
SOURCE: Digia II DVR is not
It's what the warning says - the file is missing or corrupted and you must reinstall it.
Because the installer is used to load a file that can be dangerous to your browser the security system is blocking it . To fix that you must launch the download manually : when that message appears on the yellow band on the top of the window click on it, a new window will open warning you of the danger and asking you what to do accept the download and select Run.
Posted on Jun 06, 2011
alpug
  • 1961 Answers
SOURCE: I cannot get to the
You must reinstall the software.
A flash upgrade is also necessary for your system.
Here is the link where you can obtain a firmware update necessary too for selecting the flash upgrade needed.
http://www.utcfssecurityproductspages.eu/videoupgrades/
The Digia II model you are upgrading will select the correct flash upgrade file needed. If you have existing Digia II flash upgrade files on the PC or USB drive a message may be displayed asking if you want to overwrite the existing file. Overwrite it.
Posted on Jun 24, 2011
  • 6 Answers
SOURCE: How to solve the error: please
First you need to be using Internet explorer as your browser as it does not support anything else.
Second, temporarly reduce your security settings in the browser. You may need to manually customize the setting rather than using the preset slider bar. Low/Medium/High etc.
The software is trying to install itself using active x but I believe the software is unsigned and will not install unless you reduce the security settings in the browser accordingly.
You will need to click the custom section, then find the box that says "download UNSIGNED activeX controls and chose the "PROMPT" setting. Hit apply, ok then restart the browser and try to log in to the DVR again.
Once the software installs on the machine and you are able to log in, reset the security setting back to the default levels. (THIS IS IMPORTANT)
DONT LEAVE THAT SETTING OR YOU MAY BE EXTREMELY VULNERABLE TO VIRUS, BROWSER ****** and TROJANS!!!!!!
Posted on Sep 04, 2011
How to solve the error: please check the digia2.ocx installation. current version is 1.0.0.80. that apper when i try to connect to the GE DVR Digia2 remotly.
Aug 22, 2011 | General Electric GE Security Digia II DVR
I can't access via browser to the Digia II because appears the message: "Please check the Digia2.ocx installation. Current version is 1.0.0.70. I'm using Internet Expplorer 8.
Jun 24, 2010 | General Electric GE Security Digia II DVR
Htmlmarq.ocx unable to register in systems registry
Open regedit and browse to this key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options
You should see htmlmarq.ocx and htmlmm.ocx separate keys. Rename them to something else, ie. htmlmarq.tmp and htmlmm.tmp.
You will now be able to install Office 97, including the HTML option, without incident.
Mar 05, 2010 | Microsoft Word 97 Upgrade Version for PC
Error message- flash.ocx not found
http://www.ocxdump.com/download-ocx-files_new.php/ocxfiles/F/Flash.ocx/6,0,79,0/download.html
Jan 03, 2010 | Dell Inspiron 1525 Laptop
How to register ocx on vista
[Solution # 1]
Drag and drop it onto regsvr32.exe in Windows\system32 folder. Make a shortcut for regsvr32.exe in the same folder the OCX is in and drag and drop it that way
[Solution # 2] Just run cmd.exe as administrator and try again. This is the key.
Here, step by step:
1. find the folder of cmd: it is usually on C:\windows\system32\cmd.exe
2. Do right click over cmd.exe and click on "run as Administrator"
3. now just use regsvr32.exe as you used to do!
For example, to register most Blackd Proxy ocxs, you might need to type this in "Administrator" cmd:
regsvr32.exe c:\windows\system32\richtx32.ocx
regsvr32.exe c:\windows\system32\comdlg32.ocx
regsvr32.exe c:\windows\system32\mswinsck.ocx
regsvr32.exe c:\windows\system32\msflxgrd.ocx
regsvr32.exe c:\windows\system32\msinet.ocx
regsvr32.exe C:\windows\system32\comctl32.ocx
A side result for Visual Basic 6.0 users: this seems to be the way to use components in Windows Vista properly. Just register the components of your proyect with "Administrator" cmd before adding them to your proyect (or before opening a proyect that already had such components)
[Solution # 3]
use this in command line
REGSVR32 /V then ur ocx or dll name
ex:
REGSVR32 /V CRPAIG32.DLL
[Solution # 4]
right-clicking the batch file and selecting
'run as administrator'.
richtx32.ocx
comdlg32.ocx
mscomctl.ocx
dxtmeta2.dll
Good luck
Mar 03, 2009 | Microsoft Windows Vista Ultimate Edition
Time ocx
try this
http://www.snapfiles.com/help/missingfiles.html
or try this also
http://www.visual-basic.com.ar/vb-ocx-files.htm
http://www.bigresource.com/VB-Created-activex-ocx-but-browser-wont-load-DEl2srDlaG.html
it might help u good luck
Jan 27, 2009 | Microsoft Visual Basic 6.0 for PC
Could not find flash.ocx
download the latest version of flash from www.adobe.com and you should be good to go.
May 24, 2008 | ASUS P5PE-VM Motherboard
1)error message upon clicking on an .exe/it says my Msinit.ocx is wrong/more details ff; 2) what program do I need if i wish to open a .ppl thingey
What was the error message, also you are stating only problems, not questions, please be more specific into what you want to do so people can help you.
the only solution I can think of for the OCX error is to re-register it
Go to 'Start' -> 'Run', type (or copy/paste from here) 'regsvr32 C:\Windows\System32\MSINET.OCX' and press Enter (a message box normally appears containing 'DllRegisterServer in C:\Windows\System32\MSINET.OCX succeeded.')
Also you might have to update your .net frameworks (check microsoft update.
I went to the bridge barron site and only found this
http://www.greatgameproducts.com/weeklydeals/dealoftheweek.cfm
please link to the PPL file.
Mar 03, 2008 | Computers & Internet
Registering msdatlst.ocx and msdatrep.ocx in Vista
This may help to find the reason why msdatrep.ocx is not registering. Try http://www.dependencywalker.com/ download, run it and tell it to be associated with .ocx files too. Than you can right mouse click on msdatrep.ocx and say "View Dependencies" - any missing dlls will be in red. This may help to find the reason why regsvr32 is not working.
Sep 09, 2007 | Microsoft Windows XP Professional With...
General Electric GE Security Digia II DVR Logo
41 people viewed this question
Top General Electric Home Security Experts
Lawrence Oravetz
Are you a General Electric Home Security Expert? Answer questions, earn points and help others
