Question about Linksys Wireless-G WRT54GL Router
Not connecting My router do not connect to internet.Do i have to use any special configuration for PPPoE?
5 Suggested Answers
  • 196 Answers
SOURCE: How To Set Up PPPoE DSL Connections with a WRT55AG Router
STEP 1: Before You Begin In order to set up your Linksys Router, be sure to first have the following: 1. A Linksys Router. 2. A DSL modem. 3. A working computer that can be wired in directly to the router for initial configuration and testing. 4. Two (2) standard Ethernet network cables. Linksys Routers come with one (1) standard network cable that you can use. 5. The PPPoE DSL username and password assigned by your Internet Service Provider. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. STEP 2: Check Your Internet Connection Before installing your Linksys Router, it is important to first verify that you can successfully access the Internet by connecting directly to your modem (without your Linksys Router installed). 1. If you are connecting for the first time, follow the instructions provided by your provider to set up your modem and computer for online access. 2. Verify that you are able to access the Internet without any problems. If you are not able to get a connection, contact your Internet Service Provider for assistance. When you are able to access the Internet using your modem, continue to Step 3 and proceed with the installation of your Linksys Router. STEP 3: Connect the Hardware Follow these steps to connect your Linksys Router to your modem and computer. 1. Shut down your computer and unplug the power cords connected to your modem and Linksys Router if they are currently powered on. 2. Disconnect the network cable that connects to the back of your computer. 3. Connect the network cable that you just removed to the Internet port (or WAN port) located on the back of your Linksys Router. Your modem should now be connected to your Linksys Router. 4. Connect a second network cable back into your computer (into the same port that was disconnected in #2). 5. Connect the other end of the second network cable to one of the numbered ports located on the back of your Linksys Router (labeled 1, 2, 3, 4, etc.). Your computer should now be connected to your Linksys Router. The following diagram shows how your network should be connected. Verify that your connections are correct, and continue to the next step. 6. Plug the included power adapter into the router?s Power port. Then, plug the other end of the power adapter into a nearby electrical outlet to supply power to your router. 7. Turn on your computer. Do not turn on your modem at this time. Only your router and computer should be turned on for Step 4. STEP 4: Configure the Router Follow these steps to configure your Linksys Router. 1. On the computer that is connected to the Linksys Router, open a web browser such as Internet Explorer or Netscape. 2. Type http://192.168.1.1 into your browser?s Address or Location bar and click Go or press the [Enter] key on your keyboard. The IP address 192.168.1.1 is the default IP address of Linksys Routers. 3. A user name and password prompt will appear. Leave the user name field blank (empty), and type in admin (lowercase) for the password. The password admin is the default password of Linksys Routers. NOTE: The following username/password prompt screen will vary by operating system. 4. Once logged in, the router?s web-based Setup utility should load. In the section labeled Internet Connection Type, or WAN Connection Type depending on router model and firmware version, select the PPPoE option on the drop down list. Click here to view what an older Linksys router interface looks like. 5. Once PPPoE is selected, enter your PPPoE DSL username and password provided by your Internet Service Provider into the router?s User Name and Password fields. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. NOTE: Be sure to clear the ?Password? field before entering your account password. AOL USERS: Enter in your PPPoE username as screenname@aol.com. 6. If the Keep Alive option is not selected, be sure to select it instead of the ?Connect on Demand? option. The ?Keep Alive? option will ensure that your connection stays connected even when it is not in use. 7. Scroll down to the bottom of the page and click on the Save Settings, or Apply button depending on router model, to save your changes. OR 8. Once your changes are saved, you will be presented with a button to return or you will be returned to the previous page automatically. If prompted, press Continue to return to the router?s Setup page. 9. Close and exit the web browser. STEP 5: Power Cycle Follow these steps to power on and off your devices in the correct o
Posted on Feb 16, 2006
  • 196 Answers
SOURCE: How To Set Up PPPoE DSL Connections with a Linksys Router
This article describes how to manually configure a Linksys Router for broadband DSL that uses PPPoE (Point-to-Point Protocol over Ethernet) for authentication. For automatic configuration options, please try: 1. Linksys Easy Connect (see Answer ID 1650 for more information), or 2. The Linksys Setup Wizard CD-ROM software that came with your Linksys Router. Simply insert this CD-ROM into an online computer before connecting your Linksys Router, and the Wizard will provide step-by-step instructions on how to install and configure your router. If you are unable to set up your Linksys Router by using one of the above options, use the steps below to manually configure your router. NOTE: It is recommended that you print this article for offline reference. STEP 1: Before You Begin In order to set up your Linksys Router, be sure to first have the following: 1. A Linksys Router. 2. A DSL modem. 3. A working computer that can be wired in directly to the router for initial configuration and testing. 4. Two (2) standard Ethernet network cables. Linksys Routers come with one (1) standard network cable that you can use. 5. The PPPoE DSL username and password assigned by your Internet Service Provider. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. STEP 2: Check Your Internet Connection Before installing your Linksys Router, it is important to first verify that you can successfully access the Internet by connecting directly to your modem (without your Linksys Router installed). 1. If you are connecting for the first time, follow the instructions provided by your provider to set up your modem and computer for online access. 2. Verify that you are able to access the Internet without any problems. If you are not able to get a connection, contact your Internet Service Provider for assistance. When you are able to access the Internet using your modem, continue to Step 3 and proceed with the installation of your Linksys Router. STEP 3: Connect the Hardware Follow these steps to connect your Linksys Router to your modem and computer. 1. Shut down your computer and unplug the power cords connected to your modem and Linksys Router if they are currently powered on. 2. Disconnect the network cable that connects to the back of your computer. 3. Connect the network cable that you just removed to the Internet port (or WAN port) located on the back of your Linksys Router. Your modem should now be connected to your Linksys Router. 4. Connect a second network cable back into your computer (into the same port that was disconnected in #2). 5. Connect the other end of the second network cable to one of the numbered ports located on the back of your Linksys Router (labeled 1, 2, 3, 4, etc.). Your computer should now be connected to your Linksys Router. The following diagram shows how your network should be connected. Verify that your connections are correct, and continue to the next step. 6. Plug the included power adapter into the router?s Power port. Then, plug the other end of the power adapter into a nearby electrical outlet to supply power to your router. 7. Turn on your computer. Do not turn on your modem at this time. Only your router and computer should be turned on for Step 4. STEP 4: Configure the Router Follow these steps to configure your Linksys Router. 1. On the computer that is connected to the Linksys Router, open a web browser such as Internet Explorer or Netscape. 2. Type http://192.168.1.1 into your browser?s Address or Location bar and click Go or press the [Enter] key on your keyboard. The IP address 192.168.1.1 is the default IP address of Linksys Routers. 3. A user name and password prompt will appear. Leave the user name field blank (empty), and type in admin (lowercase) for the password. The password admin is the default password of Linksys Routers. NOTE: The following username/password prompt screen will vary by operating system. 4. Once logged in, the router?s web-based Setup utility should load. In the section labeled Internet Connection Type, or WAN Connection Type depending on router model and firmware version, select the PPPoE option on the drop down list. Click here to view what an older Linksys router interface looks like. 5. Once PPPoE is selected, enter your PPPoE DSL username and password provided by your Internet Service Provider into the router?s User Name and Password fields. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. NOTE: Be sure to
SOURCE: configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
Posted on Aug 05, 2007
2Gigs
  • 141 Answers
SOURCE: Linksys wireless-G router configuration on PPPoE internet connection
Connect modem to the internet port of the wrt54g
Connect pc to port 2 of the wrt54g
Reset the wrt54g, push reset button for 30seconds with the power on, uplug the power for 10 seconds
Open internet explorer, type 192.168.1.1, you will be asked to login, no username, password is admin. This will take you to the router page. On the page you will se AUTOMATIC CONFIGURATION DHCP, change that to PPPOe, enter your broadband username and password. Click save settings at the buttom of the page. YOU WILL ONLY GET CONNECTION IF YOUR USERNAME AND PASSWORD IS CORRECT.
GOOD LUCK
Posted on Mar 15, 2008
Cant setup or connect to internet through router
Different ISPs require different configurations. If you have a Linksys router, such as the WRT54G, there are 2 ways on how you can configure it, either by running the Setup CD or by doing manual configuration. This particular router has its own web utility and you can access it by typing its IP addres on your web browser, ex. http://192.168.1.1. By default, it doesn’t have any username and its password is admin.
Once you’re inside the setup page, you can configure now the router for DHCP, PPPoE or STATIC IP settings. For DSL customers using a PPPoE account, some modem needs to be configured into BRIDGE MODE first and then the router will be set to PPPoE with the correct username and password (given by ISP). If your a DHCP account, modem doesn’t require any configuration. It will work with its default setting and the router would be set to DHCP. Once done, powercycle your devices to establish internet connection.
Jul 02, 2010 | Linksys Wireless-G WRT54G Router
I have a belkin router N-150 F6D4230-4 and it has been hooked up for a while. Well, I had to get my internet turned back on today and now my wireless internet does not work. The modem light is flashing on...
It would be best if you setup the router again. Restore the router to factory defaults. Note: This will remove all previously configured settings "some router has reset button on the back of the router cover by a sticker. The reset button is small that you need a pen to reset it."
1.Unplug the power to the cable / DSL modem
2.Connect the power to the router.
3.Connect a computer to one of the LAN ports of the router.
4.Restart your computer.
5.From the computer connected to the router, open your web browser (internet explorer).
6.Enter the router's address, http://192.168.2.1
7.Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
To configure the router to connect to the Internet, you must enter information provided by your Internet Service Provider (ISP) into the "Connection Type" section in the left-hand column under the "Internet WAN" heading of the router's configuration page. If using DSL Internet, you may need to enter the PPPoE username and password. Likewise, if you have been issued a static IP address by your provider, the static IP fields (including network mask and gateway) must also must be set in the router.
ISP Connection Type
AT&T PPPoE
Charter PPPoE, Dynamic
Comcast Dynamic
Earthlink PPPoE, Dynamic
Qwest PPPoE
Road Runner PPPoE, Dynamic
Verizon PPPoE, Dynamic
8.Plug the power back into your Internet modem.
9.Verify that this computer can connect to the Internet properly. Open a new web browser and visit a few Internet sites such as Google.com or Yahoo.com.
10.Finally, configure additional network security features as desired to guard your systems against Internet attackers
If issue is not resolve you can contact your Internet Service Provider for assiatnce.
Nov 20, 2009 | Belkin Computers & Internet
I'm having trouble with my DLINK dir-615 router. I can get a connection to the router through a wired connection and I also can connect to the router via wireless. I CANNOT get access to the internet...
I believe you have an IP Address conflict or the router needs to be configured for PPPoE. Here's how:
Basic DSL Setup - PPPoE
Most Internet Service Providers offer PPPoE authentication. Please consult your ISP if you are not sure if PPPoE could be used.
To configure your router for PPPoE you will need to set your router's WAN (INTERNET) port to 'PPPoE' option. However majority of Modems nowadays already have PPPoE enabled. If your modem has PPPoE client built-in, you need to select the 'DHCP' option in your router. The router is set to this option by default.
Configuration steps:
Step 1
Connect the broadband modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to it wirelessly.
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.0.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default is `admin' (optional) and password is blank (nothing).
Step 3
After logging into the router select Setup. Set Internet Connection to 'PPPoE' option.
This can be done by either clicking on Internet Connection Setup Wizard or if you want to set it up manually, then click on 'Manual Internet Connection Setup'. Note that it is very common for broadband modems to carry out the PPPoE authentication for you. In this case you need to select the 'Dynamic IP' option (DHCP) in your router, do not select PPPoE. If you have such modem proceed to Step 5
Step 4
If your broadband modem does not have PPPoE function, select the 'PPPoE' option in the router and enter your account details (username and password given by your ISP). Note that some ISP's require username to be as your full e-mail address (ex: username@ispname.com).
Step 5
Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration. Recycle power to modem.
You do not have to run any login client (like PPPoE) on your computer in order to connect to the Internet. If you had it setup when using the modem without the router, disable it in Internet Explorer under Tools > Internet Options > Connections > set to 'Never dial a connection'.
If you did not have to run PPPoE login client on your computer when modem was directly connected to your PC, your ADSL modem has PPPoE built-in. In this case set the router's WAN (INTERNET) port should be set to the 'Dynamic IP' option.
If your ISP requires PPPoA connection you need to make sure that your ADSL modem supports PPPoA (PPPoA can not be used on Routers which do not have ADSL Modem built-in). If your modem will be carrying out PPPoA connection you need to set your router's WAN (INTERNET) port to the 'DHCP' option.
If you are having difficulties accessing the Internet:
- Turn the modem and the router off for a minute and then turn the modem first and then the router.
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.0.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the broadband modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your broadband modem as well.
- Uninstall your antivirus software (sometimes disabling or closing the software is not enough) and reboot your PC.
Oct 22, 2009 | Computers & Internet
I downloaded latest security software from apple. now my wireless linsys g wrt54g won't work. I can connect directly to dsl, but can't make any connections with the router. I reset the router since it...
Step 1
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.1.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default password is `admin' (optional) and username is blank (nothing).
Step 3
Step 4
Step 5
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.1.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
Oct 06, 2009 | Linksys Wireless-G WRT54G Router
Can connect to router, but router wont connect to internet
The router needs to be configured manually. Follow the steps below.
Step 1
Step 2
Step 3
Step 4
Step 5
Configuring router for Cable Internet
To configure your router for Cable you will need to set your router's WAN (INTERNET) port to 'Dynamic IP' (DHCP) option. The router is set to this option by default.
Step 1 Connect the cable modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Step 2 Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.0.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, default is `admin' and password is blank (nothing).
Step 3 After logging into the router select Setup. Set Internet Connection to 'Dynamic IP (DHCP)' option.
Step 4 Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration.
If you are having difficulties accessing the Internet, you need to:
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the cable modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your cable modem as well.
- Uninstall your antivirus/firewall software (sometimes disabling or closing the software is not enough) and reboot your PC. After establishing the Internet connection through the router, reinstall your antivirus/firewall software.
Oct 06, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
I am trying to install a Netgear WGR614v9 router. Disk will not install it, so tried a manual install. Shut down all firewalls, used no passwords or security settings. It keeps throwing me back to the...
Step 1
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.1.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default is `admin' (optional) and password is blank (nothing). Or password is admin also.
Step 3
Step 4
Step 5
Step 2 Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.1.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, default is `admin' and password is blank (nothing). Or password is admin as well.
Oct 06, 2009 | NetGear WGR614 Wireless Router
Problem using Wa1003A and Tew 432 brp to share my internet
lan wires are the same. lan wires used to connect your computer to your modem can also be used to connect your Wa1003A adsl router and TEW 432 brp.
you just got some things mixed up.
1. you should set your Wa1003A adsl router to bridge mode. At this point, it will just be "pass through" device and will not be the one who will ask for IP adds from your ISP.
2. configure your TEW 432 brp with your pppoe username and password. Your TEW 432 brp will now ask the network for the IP address to that it can connect to your ISP.
3. leave your lan wires the same.
Apr 24, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
GOOD LUCK
Mar 14, 2008 | Linksys Wireless-G Broadband Router
PPPoE over Edimax BR-6104K without a modem
HI,
  Actually in short  "you NEED A MODEM;"
In order to connect your router you need to connect a modem in "bridge mode'( bridge mode is nothing but a configuration on the modem)..
this is a picture of  rear side of a  router,,, you have to connect the modem into the wan port of the router (above),, and in port number 1,2,3,4 you can connect your computers,
Nov 01, 2007 | Edimax BR-6104K Router (br6104k)
Linksys Wireless-G WRT54GL Router Logo
19 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
