I have a carrier weathermaker 8000 58wav. The blower motor does not turn and I get a 33 code. Any help would be greatly appreciated, we just had a cold snap and my fireplace isnt cutting it.
rockitman187
  • 2559 Answers
SOURCE: I have a Carrier Weathermaker
Emergency heat is made for this kind of situation.So yes you can.
now for the codes.
code 12= Blower on after power up
code 31=High heat pressure switch or relay didn't close or reopened
code 32=Low heat pressure switch or relay didn't close or reopened
code 33=limit circuit fault(Flame rollout switch is open)
code 41=board fault
code 42=control lockout
Please rate this solution
Posted on Jan 17, 2009
  • 15 Answers
SOURCE: how do i locate and replace the blower motor on # 58ZAV096
not sure if you have fixed the problem. There is a web site to get this motor... www.arnoldservice .com he should have the motor. I recomend a generic 3 speed mtr. you will have to cut the plug on the original as it may be a 4 speed but you only need 3 speeds. The oem motor will be more expensive then an aftermarket.
Posted on Feb 02, 2009
pilungu
  • 30 Answers
SOURCE: carrier weathermaker 8000 won't turn on blinks red
check the filter. If its dirt, clean it, put it back and switch your unit on.
Posted on Oct 11, 2009
  • 232 Answers
SOURCE: Carrier Weathermaker 8000 furnace blowing COLD AIR
you have a dirty flame sensor. just needs mantenance.
Posted on Dec 28, 2009
  • 86 Answers
SOURCE: Hello all~ I have a Carrier WeatherMaker 8000
It sounds like the control box or ECM is going bad.
Posted on Apr 19, 2010
Carrier 8000 weathermaker 92000 btu
If it works with blower door off sounds like it's not getting enough return. What's the statics? Try an adjustable limit, I think they go to 210. Good Luck!!
Jun 13, 2017 | Carrier Heating & Cooling
I have a Carrier Weathermaker SX HVAC unit with a Honeywell thermostat. Even if the thermostat is turned "off", my fan keeps blowing!
Hello, usually this is a sign of a bad blower relay on the intergrated control board. The only option is to replace the control board.
May 09, 2012 | Heating & Cooling
Weathermaker 8000 furnance flashing code 31 blower comes on for 90 sec .. then shuts off .. then other fan goes on.. don't see any flames or lighting goin on can you help?
31 PRESSURE SWITCH DID NOT CLOSE OR REOPENED - If open longer than five minutes,
inducer shuts off for 15 minutes before retry. Check for: - Excessive wind
- Proper vent sizing - Defective inducer motor
- Low inducer voltage (115VAC) - Defective pressure switch
- Inadequate combustion air supply - Disconnected or obstructed pressure tubing
- Low inlet gas pressure (if LGPS used) - Restricted vent
If it opens during blower on-delay period, blower will come on for the selected blower
off-delay.
33 LIMIT CIRCUIT FAULT - Indicates
Nov 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
BLOWER NOISE
Could be a loose blower wheel. It has slipped and touching the sides of the blower housing.
Turn off the power to the nit.
Remove the 2 bolts holding the blower in place.
Make yourself a wiring schematic.
Remove the wires.
Be careful not to touch the capacitor.
Remove the blower housing.
Clean the blower blades.
Spin the wheel to see where it is hitting.
Loosen the set screw on the motor shaft and adjust your blower wheel.
Mar 10, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
I have a Carrier Weathermaker SXi. Furnance will not turn on. I shut power off and waited ten minutes and tried to restart. Codes flashing are 12, 31, 32, 33, 41, 42. Can this be started in emergency mode?
now for the codes.
code 41=board fault
Jan 17, 2009 | Heating & Cooling
NO HEAT???? freezing
go to the furnace, there should be a service switch on the outside of the unit.  make sure the door is on good, does the blower motor come on?
Nov 15, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker 8000Vs
This is nothing short of a circuit board fan relay of a bad motor.. to find out if the motor is good, unplugg the black & white wire , in which white =ground black=hi-speed 120volts and conect them to power -ground and see if the motor works..if does, then its the fan circuit board if not then its a bad motor...
Jul 18, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Weathermaker SX Carrier 58SX060-cc-1
Your blower motor may have failed. Check the blower motor for the air circulation and you may find it is hot but not running. Have the motor replaced if this is the case.
Jun 11, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
139 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
