Question about Sony KDF-E55A20 55 in. LCD Television
Losing picture and sound
The TV is approx. 18 months old. I bought it new and it has been great until today. When I turn on the TV it works normal for about 30 seconds. It then appears to turn off (no sound/no picture) but the little green power light remains on. After 35-45 seconds it turns back on (picture first, then sound). It remains on for about 15-20 seconds, then off again for 35-45 seconds. It will continue to toggle on/off indefinitely. I attempted the reset that I was advised by the Sony WebChat helper. (This is unplugging the TV for 60 seconds then trying again). After this did not work, he said I must take it to a certified repair shop. (2 hour drive) Please Help...
  • samson1961 Nov 11, 2007
    It happen to me.I bought this product two years ago.It jusy happen couple days ago.I turn it go after 10 to 15 min losing the picture and sound.but it coming back and then keep gonig again.the green signal is still on.so .you think is the lamp problem?
It needs a new bulb, same thing happen with me. jut get a bulb for this model and change it. if you call sony service, it will cost you about $500.
Posted on Aug 12, 2007
SOURCE:
WHY DOES MY TV HAVE A PICTURE BUT NO SOUND?
hi put some hear phones into the tv jack see if you can hear sound this test tells you the sound processor is working, also you can test the speakers with a meter, thanks
shaun
May 26, 2017 | Televison & Video
Sound quit working
after what incident the sound stopped /
Jan 19, 2008 | Dell W3201C 32 in. LCD Television
55" approx 5 months old.
The tv have a problems,with the board that call the Tuner signal board.This is the board,where the incomming broadcasting cable wire plug into this board.This a new tv,take it back where u bought it.Exchange it for a new tv replacement.
Mar 22, 2011 | Element ELC-HS321 32 in. LCD TV
We have a samsung DLP TV with various types of problems. This tv is approx 5 yrs old. Picture will freeze, sound will stop. We have unplugged and then plug back in which seems to help but is thi the way to...
There is at least one more part in the TV that needs to be replaced, perhaps more. To know for sure which part(s) you would want a repair tech to take a look at it so you're not buying parts you don't need; especially since parts for today's TVs aren't cheap. You can purchase a new 42" LCD from www.walmart.com starting at $578, so you really want to think hard before putting another few hundred or more into what you have.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Aug 05, 2009 | Televison & Video
Toshiba 43AX60: sound but no picture
try switching to a different video source and play a DVD or a game system. If the issue is still there try unplugging the TV for 5 min. and then plug it back in.If the problem works fine on all other devices except the video source that has the issue try hooking up the same device your having the issue with to a video source you know works if that works then you have a bad video source on the back of the TV, if it does not work it's either the cable going to the TV or the device itself.
Jul 08, 2009 | Toshiba 43H70 43" Rear Projection...
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
51F59A model hitachi rear projection tv
You may need to set your screens look at the picture when you have a real dark background if there is faint lines in the picture then the screens should be set correctly
Jun 11, 2008 | Hitachi 50V715 50" Rear Projection...
Sony Wega kdf-55wf655 rear projection set keeps turning on and off
If picture quality is poor, be sure you aligned the bulb in the correct manner and be sure the cover for the bulb is not loose. Also, you might want to re check you picture setting as it might have gotten reset when you pulled the plug (I hope you pulled the plug when replacing the bulb).
Heres another solution (maybe temporary) to the problem of no picture and no sound for 30 seconds. I had my tv's power saving setting on "standard" before. After I switched it to "reduced", the problem was fixed. It has been almost two weeks without the problem. I think its a good fix until the new bulb comes in the mail.
Jan 18, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Samsung 40 no picture
If it is only 6 months old you probably still have a warranty. This is definitely a hardware issue, and unless you are comfortable taking your new TV apart, I would contact Samsung for repair.
Dec 11, 2007 | Samsung LN-S4051D 40 in. LCD Television
TV will lose picture then go into standby!
Yes it is a temp problem as you found out for your self Great call on that BUD.. the best thing to do is contact sharp to see if they have had simular problems and if there are any recalls on this model . If not they will instruct you where to send the monitor into to be fixed.
Mar 31, 2006 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sony KDF-E55A20 55 in. LCD Television Logo
360 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
