Question about Dryers
Windsor Browne Celing Fan Manual
Ceiling mounting brackets - hot to install? Do you have an installation manual for this model?
5 Suggested Answers
  • 25 Answers
SOURCE: need a ceiling fan hanger bracket for 12/6 pitch roof (ceiling).
cut a wood shim.
Posted on Jan 15, 2009
SOURCE: i need a celing mounting bracket for 52in 5 blade
I just uninstalled my 29 year old Encon flush mount fan light. The number on the base is E101004. It was a lighted base. The mount bracket is built into the base. It is the 4 prong and hook style the allows the motor to hang suspended while wiring and then swings up. There is a glass ring that is sandwiched between the base plate and decorative bottom.
It's the only usable part besides the 4 glass light covers. You can save this from the land fill if you haven't purchased a replacement fan.
Posted on Jun 28, 2009
  • 7 Answers
SOURCE: light does not come on in the ceiling fan
make sure you check the light kit attachement...there generally is a pinned plug that plugs in. make sure it is pushed in all the way
Posted on Feb 27, 2010
SOURCE: need the manual for our ceiling fan, Hunter, Park
i have to fans close to each other i would like to change the code on the remote
Posted on Oct 10, 2010
Wiring diagram for harbor breeze celing fan
The colors of the wires in the Harbor Breeze ceiling fan kits tell you what their functions are. The black wire is hot for the fan, the white is a common wire for both the fan and the light kit, green is ground and blue is hot for the light kit. locate the black and blue wires from the ceiling fan and connect them to the black wire inside the electrical junction box by twisting an orange wire connector onto all three wires. Locate the white wire from the ceiling fan and the white wire from the junction box and attach the two wires together with a wire connector. Connect the bare copper wire onto the green wire from the ceiling fan mounting bracket by twisting an orange wire connector onto the two wires. Push all wiring inside the electrical box. good-day !
Nov 26, 2011 | Hunter 52" Ceiling Fan With Light And...
I wish to install a ceiling fan in my bedroom. The roughing is already installed in my ceiling. The problem is the electrical box is recessed a half inch into the ceiling. Could I mount the ceiling fan if...
a celing fan should only be mounted on a box rated for a ceiling fan. This is a NEC code requirement. You could remove your existing box, and install a new box rated for a ceiling fan. You install the adjustable cross bar, and then attach the box to it. It also has stronger threaded inserts for the fan attaching bolts. Better than having a fan flying through the room.
Jul 25, 2010 | Lamson Electrical Box Extender
Our ceiling fan is having a major problem it has an ac hum that goes right through you can you please help us to solve this problem?
Put a small piece of card board between the mounting bracket and the celing/outlet box. this will dampen the noise, and hopefully fix your problem.
Jul 11, 2010 | Aloha Housewares (93645) Ceiling Fan
Light does not come on in the ceiling fan
"from the ceiling fan we have black, blue, and white. On the mounting bracket is green. We installed black and blue from the fan motor to the black in the ceiling."
If your fan is working and the light isn't and they are tied to the same wire (black wire), then you might have a bad pull chain switch or bulb.
Feb 18, 2010 | Hampton Bay 56 In. Florentine IV, Brushed...
Do not have room for a remote control receiver in my ceiling fan. Can i just buy a new hanger bracket that has the mounting room.
Hello, your installation will determine if you can use another type of hanging bracket. If you require that the fan must be mounted close to the ceiling there might be a way to install the remote by using plastic wire ties to sucure the receiver. There are many fans that state NOT FOR USE WITH REMOTE. Please check to see if your fan is one of thoes. If ceiling height is not a issue then a new hanger bracket should do the trick. Make sure that the bracket and the installation location will support the weight of your fan. SAFETY FIRST
Aug 25, 2009 | Dryers
I need a celing mounting bracket for 52in 5 blade encon ceiling fan. where can i get one the model # is 94b03-0395
May 08, 2009 | Encon Industries 78716 Contempra Ceiling...
Instalation tips, no manual with used fan
Hi, The bracket is like a cup with the downrod fitting into in with a ball and socket type arrangement. When the downrod ball is in the socket there is enough room to slide the receiver in, fold the antenna over the receiver when you put it in. It does not need to stick out. The whole thing is covered with the bracket cover and nothing shows. Good Luck, this should Fixya!
Mar 25, 2009 | Universal Remote Control Hampton Bay...
Hello, Just had a casabalanca 84u45d ceiling fan installed. Seems to low. Installer said cannot go any closer to ceiling.Store said it should. Who is correct.Need as close to ceiling as apossible.tks
According to the model # you gave the fan has a 2-3" down rod. You can not get ride of that or you can not mount the fan. here is a manual for the fan that you listed. On page 3 you will see how to mount to ceiling. If this is not the fan give me the right one so I can see if it can be flush mounted to the ceiling.
http://www.casablancafancompany.net/services/omans/oman_fourseas3.pdf
Good Luck
Jan 10, 2009 | Casablanca Fan 84U45D Four SeasonsĀ® III...
Aloha breeze 52 white ceiling fan
Is there something specific you need to know?
Kill power at the breaker for saftey. Mount the bracket to the ceiling first. there should be a small hook on the ceiling bracket that you can hang the fan motor from while you do the wiring.
The blue wire and black wire on the fan should both be connected to the black wire in your house wiring. Attach the fan blades to the motor once it is in place.
Aug 02, 2008 | Aloha Housewares (93645) Ceiling Fan
Dryers Logo
162 people viewed this question
Top Dryers Experts
