Question about Samsung TXN3071WHF 30" TV
Red "not available" message on screen
Hello! When we watch movies on DVD or VHS or watch TV a red "not available" message appears in the middle of the screen on top of whatever it is we're watching... Now the remote has gone funny as well - won't activate the TV, though it makes the red light on the console flicker -- and if you try to access the menu from the console, it just scrolls through all the options and won't let you select anything. We tried unplugging and checked cables... I googled this and found one opinion that the processor was bad... any insight?
  • Elana Aug 16, 2007
    An expert TV repair in Billings, MT gave me this advice. On the Samsung televisions with touch sensor buttons on the front bottom panel, sometimes the buttons get messed up, which sends conflicting signals to the computer and it can't receive input correctly. We removed this panel with a hairdryer and a pen knife (it's hard to tell it's there, but it's smoother than the TV and you can feel the edge at the bottom) and then carefully put it back on. Everything now works fine.
  • Anonymous Jan 01, 2008
    This happens to ours as well. It is trying to change channels by itself, so when it is in component mode, changing channels is not an option.
    I will try removing the front cover and checking it out.
The reason the TV doesn't respond to the remote is that the set is busy trying to change channels (or scroll through menu options.) because one of the channel-- up/down "button" is stuck on the front panel of the TV. They are very delicate, and respond to the slightest input. (You should see the CH light on the front of the set.)
So, I had the same problem, and just finished following the advice for fixing this problem by using a hair dryer and pen knife to remove the strip covering the "buttons."
I have to admit that I was afraid of what damage I might do in removing the little strip from the face of the TV, but I only paid $114 for the set at Salvation Army, and it's otherwise a great set, so I had little to lose.
Trust me, you can't hurt anything by removing the little panel. Just take your time, and let the heat do the work, lest you crease the strip. (It took about five minutes for me to get it off.)
I chose to disable the front-panel controls altogether by simply removing the little pads that activate the switches.
The pads look like tiny little rubber bands, about 3/8" across, and will stick to the double-sided adhesive when you remove the strip. (Don't worry, they are not attached to the set, and you won't be destroying anything in this process.)
I suppose you could always get replacement rubber thingies, but I'd just as soon use the remote, and avoid future hassles.
Posted on Jan 02, 2008
  • cameronscott Jan 05, 2009
    It has been over one year since I posted the above solution.
    There have been no further problems whatsoever with this set, and we enjoy the 1080i picture enormously.
    Obviously, with the pen-knife solution, you are forced to use the remote for everything but on/off, but the soft-touch buttons are absolutely the cause of the "not available" problem, and the solution is very straightforward.
  • cameronscott Jan 01, 2010
    This TV just died over Christmas, and it won't turn on. We bought a new flat-panel yesterday at Costco.
    I briefly checked the posts about power failure, and saw something about flyback transformer solder connections.
    My wife won't let me take it in for repair, but insists that we get it out of the house and recycle it :-(
    The new TV is calibrated properly, and the digital cable-converter box has been set up properly, but the picture is nowhere near the high quality we have become accustomed to with the tube set... I'm gonna miss this TV!
Have connected cable (white, yellow, red) from Conia DVD player to TV as component 1 and connected Sony VHS cable (white, yellow, red) to TV as component 2. What other steps need to be taken for the...
component video needs Red, Green, Blue to be connected on the DVD end and to the TV for video to display, also the Red and White audio out needs to be connected to the TV for audio to work .
VHS has Red, White an yellow for Right Audio, Left Audio and video respectively.
You need to switch the inputs on the TV to the corresponding Component and Video inputs. Most TV's have a source or Input button to switch between the inputs. simply press the button until you have the input you are looking for.
Mar 13, 2011 | Televison & Video
Image split with black bar in middle
check leads if they are connect in the normal video slot on dvd player and chek the player settings what out pot it is on
Aug 21, 2009 | JVC HR-XVC18B DVD Player/VCR
Sharp Aquos LC-37D44U only shows B&W images from DVD & VHS source
First thing- why not just use the HDMI instead of standard def cables in the first place? Anyway- If the RCA-video (yellow composite cable) is not producing color, 1 of 2 things may be wrong: 1. You accidentally connected the a/v cables [yellow white and red] to [red green and blue] component inputs or vice versa, or.. 2. Your TV or DVD player is somehow set to the wrong video format. Check the DVD settings for video output format and video connector type. Format should be NTSC, and connector should be composite and/or s-video for the cables you're using.
If this is only happening when connecting the DVD player through the VCR, then check to make sure the same cables connecting the DVD player to the the VCR are also connected to the TV from the VCR.
BTW- if this is just to record DVDs to a VCR, I'll tell you it's not worth it. If your DVD player has an HDMI port, your picture quality will be so much better than if you're watching a VCR copy of one. Your new HDTV will look worse than an old standard def TV. Worse; I'm not kidding.
I hope some of this helps.
Jun 01, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Unable to properly connect sony dvd to tv to play movie
DVD-3 RCA phono outputs(red & white=audio,yellow=video
I have a DVP-NS700,the same happens on mine.Turn it on,goes green to red(standby),then press eject,it will then power up properly.
Jan 03, 2009 | Sony DVP-NS300 DVD Player
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Copying vhs to dvd using samsung vr357 ??
I do not think you would have to worry about a way to disable the copy protection that is on the vhs tapes. you are not going to record over them. You are just going to transfer information to the dvd side. jh
Nov 18, 2007 | Samsung DVD-VR357
RE; Remote control TV/AV button doesn't work LXI series
Hi, Based on your post/description: 1. the TV is stuck to A/V; 2. you have two video sources - VHS & DVD (assuming both are external and both have A/V outputs with the VCR also with inputs); 3. you want to use either VHS & DVD, one at a time. You can do it the old fashion way, remove yellow, red, white RCA connectors from DVD and plug them at the outputs of the VHS when you want to use the VCR; or Connect the A/V outputs of the DVD to the inputs of the VCR, connect the outputs of the VCR to the A/V inputs of the LXI TV. Hopes this give you an idea. Post back how things are or should you need further information. Good luck and kind regards.
Aug 23, 2007 | Rio Go Video DDV9475 Dual Deck VCR
DVD/vhs combo
how is the vhs? if is ok, then the problem is the dvd and theres nothing to do with remotes, all point to a bad chip(Ic) and you gona need a tech, if the problem is with the vhs too, then try with another set of cable from the set to the tv...good luck
Aug 06, 2006 | Philips VPX210AT Dual Deck VCR
Open Questions:
See all Samsung TXN3071WHF 30" TV Questions
Samsung TXN3071WHF 30" TV Logo
244 people viewed this question
Jerry Greenberg
Jerry Greenberg
