Question about GE 27923GE1 Cordless Phone
Handset will not work, already changed battery, still not working, what could be wrong?
My vtech dect 6.0 keeps saying unable to call try again
I had this happen suddenly on 2 out of 3 handsets with a DS6151 base and DS6101 handsets. Well, what happened is there was no dial tone on either of the 2 handsets on either of the 2 lines and a message appeared on the display "Unable to Call Try Again" after some delay, if Line1 or Line2 button was pressed.
Oddly, the 2 that did not work were the ones normally on "extension" chargers and the 1 that did work was the one on the base unit. That caused me to suspect the base unit .. which it still may have been but the solution was NOT. And, also odd, the handsets seemed to still be synched with the base unit in many respects.
Cycling the power on the base unit did nothing.
These are fairly new units and battery life is generally much longer in my experience.
The Solution:
- Remove the battery from the handset that doesn't work properly.
- Re-install the same battery.
Whatever was wrong, this reset it and the handsets started working again.
Easy fix.
Mar 18, 2012 | Vtech DECT 6.0 Digital Cordless Phone
Uniden PowerMAX 5.8GHz TRU8880 Series
does the phone do anything? if not charge battery, if you have already did that, then try to change the battery by getting a replacment from your local radio shack.
Apr 14, 2008 | Lands Phones
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
I have a new dead phone
You need to make sure the phone is on the cradel half on half off is not the units fault its the users, in saying the the unit will charge the battery if you dod not kiill it already, leave the phone on the cradel if that does not charge the battery a nice day trip to radioshack for a new battery might be what you have to do, Sorry to hear you misfortuens with uniden there a good company but make things that people just do not understand.
Jan 11, 2010 | Uniden DECT 6.0 Cordless Phone ID
My motoflip is not charging
Your battery is dead. You need to change it. One more thing you can check before changing your battery put your battery in some other handset and try to charge it through that charger if it works then your chargers output voltage is wrong change it.
Jun 16, 2009 | Cell Phones
My siemens 4010 cordless phone is saying "Base Search" recently
"Base Search" will display for several reasons.
  1. The base station is turned off or not working properly.
  2. The handset is not registered.
  3. The handset may be registered somewhere else, de-register it.
  4. The units (both base and handset/s) may need to be reset to factory default.
You may have already tried this.
Jan 15, 2009 | Siemens Gigaset 4010 Cordless Phone
Problems with C110 & A110 Vtech Mirage Dect Home phones
Have strangely got the same problem - about the same time you posted this, but intermitently. I have isolated that the problem is in fact the handset itself, not the base unit. I eliminated a problem with the base unit by a) registering a different DECT phone to it. - The base still works fine. b) Leaving the handset switched off for an hour or so (press and hold the "OK" botton to switch off / on); then whislt it was working, registering the handset to a different base (Base 2). And guess what, after 30 mins the "BASE 2" message started flashing on the faulty handset.
So, if you already have an A110 extension handset, make sure it's also registered to base 1 and maybe try to get just the handset repaired via VTECH. (or just buy a new handset if they are available).
Jun 21, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
GE 900mhz model 26936GE2-C
Sounds like a defective battery or low battery.
1. Have you replaced the battery?
2. Have you changed the channel?
3. Have you dropped it?
Answer these few questions and we'll see if we can figure it out.
Let me know.
Feb 18, 2008 | Xact Communication XG2200 Cordless Phone
Phone rings, but once answered its not possible to hear a voice.
Similar issue - brand new phone - but incoming calls (skype or landline) would ring - and then nothing, and outgoing calls the handset would just reset.
The handset would just lose signal constantly (less than 2 meters from the base station).
The phone shipped with the latest software - but eventually I reinstalled it - no change, then de-registered the handset, powered everything down and re-registered the handset and that *seems* to have done it .....
So
1 - reflash / re-install latest software from philips website (even if the phone already has the same version)
2 - de-register handset (follow instructions)
3 - unplug base station and remove batteries from handset
4 - turn on base station, put batteries in handset
5 - re register handset (follow instructions in manual)
and that seems to do it.
Nov 18, 2007 | Philips VOIP8411B/37 IP Phone
GE 27923GE1 Cordless Phone Logo
18 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
